[GRASS-SVN] r64917 - in grass-promo/grassposter/2015_EGU_G7_Python: . listings
Wed Mar 25 07:32:36 PDT 2015
Author: huhabla
Date: 2015-03-25 07:32:36 -0700 (Wed, 25 Mar 2015)
New Revision: 64917
Added:
   grass-promo/grassposter/2015_EGU_G7_Python/listings/tgrass_examples.tex
   grass-promo/grassposter/2015_EGU_G7_Python/Makefile
   grass-promo/grassposter/2015_EGU_G7_Python/main.tex
Added GRASS GIS Temporal Framework part
Modified: grass-promo/grassposter/2015_EGU_G7_Python/Makefile
--- grass-promo/grassposter/2015_EGU_G7_Python/Makefile	2015-03-25 14:11:52 UTC (rev 64916)
+++ grass-promo/grassposter/2015_EGU_G7_Python/Makefile	2015-03-25 14:32:36 UTC (rev 64917)
@@ -6,10 +6,10 @@
 ODPDIR = odp_slides
 TEXDIR = listings
-SVGFILES = $(shell ls $(SVGDIR)/*.svg)
-SVGPDF = $(patsubst %.svg, %.pdf, $(SVGFILES))
-ODPFILES = $(shell ls $(ODPDIR)/*.odp)
-ODPPDF = $(patsubst %.odp, %.pdf, $(ODPFILES))
+#SVGFILES = $(shell ls $(SVGDIR)/*.svg)
+#SVGPDF = $(patsubst %.svg, %.pdf, $(SVGFILES))
+#ODPFILES = $(shell ls $(ODPDIR)/*.odp)
+#ODPPDF = $(patsubst %.odp, %.pdf, $(ODPFILES))
 TEXFILES = $(shell ls $(TEXDIR)/*.tex)
 TEXPDF = $(patsubst %.tex, %.pdf, $(TEXFILES))
Added: grass-promo/grassposter/2015_EGU_G7_Python/listings/tgrass_examples.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/listings/tgrass_examples.tex	                        (rev 0)
+++ grass-promo/grassposter/2015_EGU_G7_Python/listings/tgrass_examples.tex	2015-03-25 14:32:36 UTC (rev 64917)
@@ -0,0 +1,41 @@
+% taken from grass-promo/grassposter, written by me I think
+\documentclass{standalone}
+\usepackage[active,tightpage]{preview}
+\usepackage{listings}
+\PreviewEnvironment{lstlisting}
+\usepackage[usenames,dvipsnames,svgnames,table]{xcolor}
+\input{listings_settings}
+\begin{document}
+\begin{lstlisting}[language=Python,linewidth=34.2em]
+# Import the GRASS GIS temporal framework
+import grass.temporal as tgis
+# Open an existing space time raster dataset (STRDS)
+temp_strds = tgis.open_old_stds(name="temp_daily",
+                                type="strds")
+# Shift all registered raster map layer 2 days in the future
+temp_strds.shift("2 days")
+# Open an exitsing time stamped raster map as map object
+temp_19770324 = tgis.open_new_map_dataset(type='raster',
+                                name='temp_1977_Mar_24')
+# Unregister the raster map from the STRDS
+temp_strds.unregister_map(temp_19770324)
+# Get a list of all registered raster map layers with
+# a start time later 1990-05-22 from the STRDS
+maps = temp_strds.get_registered_maps_as_objects(\
+                     where="start_time > '1990-05-22'")
+# Create a temporal buffer of 6h for each map in the list
+for map in maps:
+    map.temporal_buffer("6 hours", update=True)
+# Compute new spatio-temporal extent and granularity
+temp_strds.update_from_registered_maps()
+# Get the granuarity of the STRDS
+gran = temp_strds.get_granularity()
+\end{lstlisting}
+\end{document}
\ No newline at end of file
Modified: grass-promo/grassposter/2015_EGU_G7_Python/main.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/main.tex	2015-03-25 14:11:52 UTC (rev 64916)
+++ grass-promo/grassposter/2015_EGU_G7_Python/main.tex	2015-03-25 14:32:36 UTC (rev 64917)
@@ -229,9 +229,27 @@
+\block{\blocktitlewrap{GRASS GIS Addons}}{
+The GRASS GIS Addons ensures long-term preservation of the code.
+Well maintained modules in Addons can be moved to GRASS GIS itself.
+\block{\blocktitlewrap{Alternatives to Python}}{
+GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
+and as subprocesses virtually any language as long as proper environment is set.
+The GRASS GIS library has a C API which is often used to create GRASS modules in C and C++.
+GRASS GIS modules can be used in R using \pkg{rgrass7} package.
 \column{0.25}
@@ -312,6 +330,10 @@
 and running code from IDE
+\block{\blocktitlewrap{Testing the code}}{
+\cite{Petras2014}
@@ -320,32 +342,15 @@
 \column{0.25}
-\block{\blocktitlewrap{Temporal framework}}{
-\cite{Gebbert2014}
+\block{\blocktitlewrap{GRASS GIS Temporal Framework}}{
+The GRASS GIS Temporal Framework implements the temporal GIS functionality of GRASS GIS
+and provides a Python API to implement spatio-temporal processing modules.
+The framework introduces space time datasets that represent time series of raster,
+3D raster or vector maps. Some API examples:
+\includegraphics[width=1\linewidth, clip, trim=0 0 0 0]{tgrass_examples}
-\block{\blocktitlewrap{Testing the code}}{
-\cite{Petras2014}
-\block{\blocktitlewrap{GRASS GIS Addons}}{
-The GRASS GIS Addons ensures long-term preservation of the code.
-Well maintained modules in Addons can be moved to GRASS GIS itself.
-\block{\blocktitlewrap{Alternatives to Python}}{
-GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
-and as subprocesses virtually any language as long as proper environment is set.
-The GRASS GIS library has a C API which is often used to create GRASS modules in C and C++.
-GRASS GIS modules can be used in R using \pkg{rgrass7} package.
 \block{\blocktitlewrap{Acknowledgements}}{
 \newcommand{\listhspace}{\hspace{0.005\linewidth}}
