[GRASS-SVN] r64927 - grass-promo/grassposter/2015_EGU_G7_Python
svn_grass at osgeo.org
Sun Mar 29 04:21:59 PDT 2015
Author: neteler
Date: 2015-03-29 04:21:59 -0700 (Sun, 29 Mar 2015)
New Revision: 64927
grass-promo/grassposter/2015_EGU_G7_Python/main.tex
2015_EGU_G7_Python poster: minor cleanup; parser text addition
Modified: grass-promo/grassposter/2015_EGU_G7_Python/main.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/main.tex 2015-03-26 17:13:31 UTC (rev 64926)
+++ grass-promo/grassposter/2015_EGU_G7_Python/main.tex 2015-03-29 11:21:59 UTC (rev 64927)
@@ -1,5 +1,5 @@
% License: CC0
-% The license is CC0 but you can acknowledge the authors if you want to. See their names bellow.
+% The license is CC0 but you can acknowledge the authors if you want to. See their names below.
\documentclass[innermargin=10mm]{tikzposter}
\usepackage{enumitem}
@@ -197,6 +197,23 @@
% \end{itemize}
+\block{\blocktitlewrap{GRASS GIS Addons}}{
+The GRASS GIS Addons ensure long-term preservation of the code.
+Well maintained modules in Addons can be moved to GRASS GIS core.
+\block{\blocktitlewrap{Alternatives to Python}}{
+GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
+and as subprocesses virtually any language as long as proper environment is set.
+The GRASS GIS library povides a C API which is commonly used to create GRASS modules in C and C++.
+GRASS GIS modules can be used within R using the \pkg{rgrass7} package.
\block{\blocktitlewrap{More information}}{
\newcommand{\qrcodewidth}{1\linewidth}
\hspace{-0.02\linewidth}
@@ -229,27 +246,9 @@
-\block{\blocktitlewrap{GRASS GIS Addons}}{
-The GRASS GIS Addons ensures long-term preservation of the code.
-Well maintained modules in Addons can be moved to GRASS GIS itself.
-\block{\blocktitlewrap{Alternatives to Python}}{
-GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
-and as subprocesses virtually any language as long as proper environment is set.
-The GRASS GIS library has a C API which is often used to create GRASS modules in C and C++.
-GRASS GIS modules can be used in R using \pkg{rgrass7} package.
\column{0.25}
@@ -313,6 +312,13 @@
\block{\blocktitlewrap{Automatic creation of GUI and CLI}}{
+The g.parser module provides full parser support for GRASS GIS scripts.
+It provides the creation of help page template, and command line option
+checking. Each command and scripts which uses the GRASS GIS parser can
+publish its parameter and flags description in XML. Through the included
+XML parser this description can be turned into a graphical user interface with
+standardized styling.
\includegraphics[width=\linewidth, clip, trim=0 0 0 0]{grass_module}
\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{grass_module_gui}
@@ -342,10 +348,10 @@
\column{0.25}
-\block{\blocktitlewrap{GRASS GIS Temporal Framework}}{
-The GRASS GIS Temporal Framework implements the temporal GIS functionality of GRASS GIS
+\block{\blocktitlewrap{GRASS GIS 7 Temporal Framework}}{
+The GRASS GIS Temporal Framework offers the temporal GIS functionality of GRASS GIS
and provides a Python API to implement spatio-temporal processing modules.
-The framework introduces space time datasets that represent time series of raster,
+The framework introduces space-time datasets that represent time series of raster,
3D raster or vector maps. Some API examples:
\includegraphics[width=1\linewidth, clip, trim=0 0 0 0]{tgrass_examples}
@@ -362,7 +368,8 @@
\end{minipage}
\listhspace
\begin{minipage}{\listtextwidth}
-GRASS GIS is a OSGeo project. OSGeo provides infrastructure for websites and source code management.
+GRASS GIS is a OSGeo project. OSGeo provides infrastructure for project
+Web sites, mailing lists and source code management.
\end{minipage}
\bigskip
@@ -372,13 +379,13 @@
\end{minipage}
\listhspace
-Initial development of \pkg{pygrass} and \pkg{gunittest} packages was done during Google Summer of Code.
+Initial development of \pkg{pygrass} and \pkg{gunittest} packages was done during Google Summer of Code 2014.
\end{minipage}
\bigskip
-Luca Delucchi contributed significantly to development of Python interfaces for GRASS GIS
-by extensive testing in early stages of development, documenting the APIs
+Luca Delucchi, Italy, contributed significantly to development of Python interfaces for GRASS GIS 7
+through extensive testing in early stages of development, documenting the APIs
and general contributions to the code itself.
@@ -393,11 +400,11 @@
\bibitem{Neteler2012}
Neteler, M., Bowman, M. H., Landa, M., Metz, M., 2012.
\emph{GRASS GIS: A multi-purpose open source GIS.}
- Environmental Modelling \& Software, 31(0), 124-130.
+ Environmental Modelling \& Software, 31, 124--130.
\bibitem{Gebbert2014}
Gebbert, S., Pebesma, E., 2014. A temporal GIS for field based environmental modeling. Environmental
- Modelling \& Software 53, 1-12.
+ Modelling \& Software 53, 1--12.
\bibitem{Petras2014}
Petras, V., Gebbert, S., 2014. Testing framework for GRASS GIS: ensuring reproducibility of scientific
@@ -406,10 +413,10 @@
\bibitem{Zambelli2013}
Zambelli, P., Gebbert, S., Ciolli, M., 2013. Pygrass: An Object Oriented Python Application Programming
Interface (API) for Geographic Resources Analysis Support System (GRASS) Geographic Information System
- (GIS). ISPRS International Journal of Geo-Information 2, 201-219.
+ (GIS). ISPRS International Journal of Geo-Information 2, 201--219.
\end{thebibliography}
\end{columns}
-\end{document}
\ No newline at end of file
+\end{document}
