[GRASS-SVN] r64948 - in grass/trunk: demolocation lib/init lib/python/script
svn_grass at osgeo.org
Mon Mar 30 14:43:19 PDT 2015
Author: martinl
Date: 2015-03-30 14:43:19 -0700 (Mon, 30 Mar 2015)
New Revision: 64948
grass/trunk/demolocation/grassrc.tmpl
grass/trunk/lib/init/variables.html
grass/trunk/lib/python/script/core.py
GRASS_DB_ENCODING is environmental variable
Modified: grass/trunk/demolocation/grassrc.tmpl
--- grass/trunk/demolocation/grassrc.tmpl 2015-03-30 21:12:38 UTC (rev 64947)
+++ grass/trunk/demolocation/grassrc.tmpl 2015-03-30 21:43:19 UTC (rev 64948)
@@ -1,6 +1,4 @@
GISDBASE: @GISDBASE@
LOCATION_NAME: demolocation
MAPSET: PERMANENT
-GRASS_DB_ENCODING: utf-8
-DEBUG: 0
GUI: text
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2015-03-30 21:12:38 UTC (rev 64947)
+++ grass/trunk/lib/init/variables.html 2015-03-30 21:43:19 UTC (rev 64948)
@@ -107,6 +107,10 @@
<dd>defines the name (path) of a shell script to be processed as
batch job.</dd>
+ <dt>GRASS_DB_ENCODING</dt>
+ <dd>[various modules, wxGUI]<br>
+ encoding for vector attribute data (utf-8, ascii, iso8859-1, koi8-r)</dd>
<dt>GIS_ERROR_LOG</dt>
<dd>If set, GIS_ERROR_LOG should be the absolute path to the log
file (a relative path will be interpreted relative to the process'
@@ -476,10 +480,6 @@
<dd>lock ID to prevent parallel GRASS use,
<br>process id of the start-up shell script</dd>
- <dt>GRASS_DB_ENCODING</dt>
- <dd>[d.what.vect/forms library]<br>
- encoding of query form (utf-8, ascii, iso8859-1, koi8-r)</dd>
<dt>GUI</dt>
<dd>See <tt>GRASS_GUI</tt> environmental variable for details.</dd>
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2015-03-30 21:12:38 UTC (rev 64947)
+++ grass/trunk/lib/python/script/core.py 2015-03-30 21:43:19 UTC (rev 64948)
@@ -324,7 +324,6 @@
GISDBASE='/opt/grass-data';
LOCATION_NAME='spearfish60';
MAPSET='glynn';
- GRASS_DB_ENCODING='ascii';
GUI='text';
MONITOR='x0';
@@ -388,7 +387,6 @@
MAPSET='glynn';
GUI='text';
MONITOR='x0';
