[GRASS-SVN] r64955 - in grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform: . images
svn_grass at osgeo.org
Mon Mar 30 19:51:31 PDT 2015
Author: wenzeslaus
Date: 2015-03-30 19:51:31 -0700 (Mon, 30 Mar 2015)
New Revision: 64955
grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/images/damflood_tangible.jpg
grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/images/rsimwater_architects.jpg
grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.bib
grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.tex
new version of water box (based on the latest version of the abstract); whitespace to align bottom
Modified: grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/images/damflood_tangible.jpg
(Binary files differ)
Modified: grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/images/rsimwater_architects.jpg
Modified: grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.bib
--- grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.bib 2015-03-31 01:59:09 UTC (rev 64954)
+++ grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.bib 2015-03-31 02:51:31 UTC (rev 64955)
@@ -326,4 +326,4 @@
year = 2015,
url = {http://courses.ncsu.edu/gis582/common/grass/interpolation_2.html},
urldate = {2015-03-30}
\ No newline at end of file
Modified: grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.tex
--- grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.tex 2015-03-31 01:59:09 UTC (rev 64954)
+++ grass-promo/grassposter/2015_EGU_G7_PeerReview_SciPlatform/poster.tex 2015-03-31 02:51:31 UTC (rev 64955)
@@ -216,6 +216,8 @@
European Climate Assessment \& Dataset ECA\&D (Haylock et al. \cite{Haylock2008_climate_series})
for climate change indicators.
+\vspace*{1cm}
\begin{minipage}{0.5\linewidth}
\includegraphics[scale=0.5]{images/summer_mean_temp_slope.pdf}
The linear regression slope computed with t.rast.series of the temperate climate zone in the European Union
@@ -230,28 +232,42 @@
\gmodule{t.rast.univar} and the open source statistical software system R
were used to create this plot.
\end{minipage}
+\vspace*{1cm}
\block{\blocktitlewrap{Natural Hazards: Water, Floods and Erosion}}{
-GRASS GIS entails several modules that constitute the result of active research on
-natural hazard. The \gmodule{r.sim.water} simulation model (Mitas and Mitasova, 1998 \cite{Mitas1998b})
-for overland flow under rainfall excess conditions was integrated into the Emergency
-Routing Decision Planning system as a WPS (Raghavan et al., 2014 \cite{raghavan2014deploying}).
-It was also modified by Petrasova et al., 2014 \cite{Petrasova2014} and is now part of a
-specialised software called \textit{Tangible Landscape} (previously \textit{Tangible GIS}), which also
-incorporated the \gamodule{r.damflood} module.\newline\linebreak
+GRASS GIS entails several modules that constitute the result of active research on natural hazard.
+The \gmodule{r.sim.water} simulation model (Mitas and Mitasova, 1998 \cite{Mitas1998b})
+for overland flow with spatially variable rainfall excess conditions was integrated into the Emergency
+Routing Decision Planning system as a WPS (Raghavan et al., 2014 \cite{raghavan2014deploying}).
+The module \gmodule{r.sim.water} together with
+the module \gmodule{r.sim.sediment} for erosion-deposition modeling
+implements path sampling algorithm which is robust and easy to parallelize.
+The \gmodule{r.sim.water} module was also utilized by Petrasova et al., 2014 \cite{Petrasova2014} and is now part of
+\emph{Tangible Landscape}, a tangible GIS system, which also incorporated \gmodule{r.damflood},
+a dam break inundation simulation \cite{cannata2012two}.
+\bigskip
+\vspace*{1cm}
\includegraphics[width=\textwidth]{rsimwater_architects}
Overland flow used for landscape architecture design in Tangible Landscape environment
\end{minipage}
\includegraphics[width=\textwidth]{damflood_tangible}
Coal ash pond breach in Tangible Landscape environment using \gamodule{r.damflood} module
\end{minipage}
+\vspace*{1.4cm}
@@ -289,8 +305,11 @@
information available for more than twelve years (i.e. Aqua/Terra-MODIS) for each pixel
location, it becomes paramount to have a more complete comparison,
in space and time.
-\newline
+\bigskip
+\vspace*{1cm}
\begin{center}
\includegraphics[width=0.9\textwidth]{TonleSapTa}
@@ -307,6 +326,8 @@
Biological fraction of 2014 ET (cumul. mm/y) \& January average gap (mm/m), Tonle Sap, Cambodia.
\end{center}
+\bigskip
To address this new experimental requirement, a distributed computing framework was
designed and created (Chemin, 2012 \cite{chemin2012distributed}).
The architecture design was built from original satellite datasets to various levels
@@ -316,6 +337,9 @@
models to the models internals/specificities. All of the ET models are available in the
new GRASS GIS version 7 as imagery modules and replicability is complete for future
research.
+\vspace*{0.6cm}
