[GRASS-SVN] r65175 - grass/branches/releasebranch_7_0/raster/r.carve
Sat May 2 14:27:12 PDT 2015
Author: hcho
Date: 2015-05-02 14:27:12 -0700 (Sat, 02 May 2015)
New Revision: 65175
   grass/branches/releasebranch_7_0/raster/r.carve/enforce_ds.c
r.carve: Backport r65165, r65165, r65166
Modified: grass/branches/releasebranch_7_0/raster/r.carve/enforce_ds.c
--- grass/branches/releasebranch_7_0/raster/r.carve/enforce_ds.c	2015-05-02 21:19:02 UTC (rev 65174)
+++ grass/branches/releasebranch_7_0/raster/r.carve/enforce_ds.c	2015-05-02 21:27:12 UTC (rev 65175)
@@ -453,7 +453,7 @@
     prevrow = Rast_northing_to_row(pgxypts[0][1], &wind);
     prevcol = Rast_easting_to_col(pgxypts[0][0], &wind);
-    for (i = 1; i < (npts - 1); i++) {
+    for (i = 1; i < npts; i++) {
 	int c, r;
 	int row = Rast_northing_to_row(pgxypts[i][1], &wind);
@@ -465,10 +465,12 @@
 	col1 = MAX(0, MIN(col, prevcol) - coloff);
 	col2 = MIN(Rast_window_cols() - 1, MAX(col, prevcol) + coloff);
-	for (r = row1; r < row2; r++) {
+	for (r = row1; r <= row2; r++) {
 	    cy = Rast_row_to_northing(r + 0.5, &wind);
-	    for (c = col1; c < col2; c++) {
+	    for (c = col1; c <= col2; c++) {
+		double distance;
 		cellx = Rast_col_to_easting(c + 0.5, &wind);
 		celly = cy;	/* gets written over in distance2... */
@@ -479,38 +481,36 @@
 		 * Here we use a bitmap and only change cells once
 		 * on the way down */
-		if (dig_distance2_point_to_line(cellx, celly, 0,
+		distance = sqrt(dig_distance2_point_to_line(cellx, celly, 0,
 						pgxypts[i - 1][0],
 						pgxypts[i - 1][1], 0,
 						pgxypts[i][0], pgxypts[i][1],
 						0, 0, &cellx, &celly, NULL,
-						NULL, NULL)) {
-		    if (!BM_get(bm, c, r)) {
-			double dist, elev;
+						NULL, NULL));
-			Vect_reset_line(points);
+		if (distance <= parm->swidth && !BM_get(bm, c, r)) {
+		    double dist, elev;
-			dist = G_distance(pgxypts[i][0], pgxypts[i][1],
-					  cellx, celly);
+		    Vect_reset_line(points);
-			elev = LINTERP(pgpts[i][1], pgpts[i - 1][1],
-				       (dist /
-					(pgpts[i][0] - pgpts[i - 1][0])));
+		    dist = G_distance(pgxypts[i][0], pgxypts[i][1],
+				      cellx, celly);
-			BM_set(bm, c, r, 1);
+		    elev = LINTERP(pgpts[i][1], pgpts[i - 1][1],
+				   (dist / (pgpts[i][0] - pgpts[i - 1][0])));
-			/* TODO - may want to use a function for the
-			 * cross section of stream */
-			set_min_point(rbuf, c, r, elev, parm->sdepth,
-				      parm->raster_type);
+		    BM_set(bm, c, r, 1);
-			/* Add point to output vector map */
-			if (parm->outvect->answer) {
-			    Vect_append_point(points, pgxypts[i][0],
-					      pgxypts[i][1],
-					      elev - parm->sdepth);
-			    Vect_write_line(outMap, GV_POINT, points, cats);
+		    /* TODO - may want to use a function for the
+		     * cross section of stream */
+		    set_min_point(rbuf, c, r, elev, parm->sdepth,
+				  parm->raster_type);
+		    /* Add point to output vector map */
+		    if (parm->outvect->answer) {
+			Vect_append_point(points, cellx, celly,
+					  elev - parm->sdepth);
+			Vect_write_line(outMap, GV_POINT, points, cats);
