[GRASS-SVN] r65180 - in grass/trunk: lib/init mswindows mswindows/osgeo4w scripts/g.manual
svn_grass at osgeo.org
Sun May 3 04:24:33 PDT 2015
Author: martinl
Date: 2015-05-03 04:24:32 -0700 (Sun, 03 May 2015)
New Revision: 65180
grass/trunk/lib/init/grass.py
grass/trunk/mswindows/env.bat
grass/trunk/mswindows/osgeo4w/env.bat.tmpl
grass/trunk/scripts/g.manual/g.manual.py
attempt to fix g.manual on Windows (see also r65179)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-03 11:16:40 UTC (rev 65179)
+++ grass/trunk/lib/init/grass.py 2015-05-03 11:24:32 UTC (rev 65180)
@@ -478,8 +478,9 @@
browser = gfile('etc', "html_browser_mac.sh")
os.environ['GRASS_HTML_BROWSER_MACOSX'] = "-b com.apple.helpviewer"
- if windows or cygwin:
- # MinGW startup moved to into init.bat
+ if windows:
+ browser = "start"
+ elif cygwin:
browser = "explorer"
else:
# the usual suspects
Modified: grass/trunk/mswindows/env.bat
--- grass/trunk/mswindows/env.bat 2015-05-03 11:16:40 UTC (rev 65179)
+++ grass/trunk/mswindows/env.bat 2015-05-03 11:24:32 UTC (rev 65180)
@@ -6,8 +6,6 @@
REM To enable bash prompt please uncomment the line bellow
REM set GRASS_SH=%GISBASE%\msys\bin\sh.exe
-set GRASS_HTML_BROWSER=explorer
set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
set PYTHONHOME=%GISBASE%\Python27
Modified: grass/trunk/mswindows/osgeo4w/env.bat.tmpl
--- grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2015-05-03 11:16:40 UTC (rev 65179)
+++ grass/trunk/mswindows/osgeo4w/env.bat.tmpl 2015-05-03 11:24:32 UTC (rev 65180)
@@ -7,8 +7,6 @@
REM set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
set PYTHONHOME=%OSGEO4W_ROOT%\apps\Python27
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py 2015-05-03 11:16:40 UTC (rev 65179)
+++ grass/trunk/scripts/g.manual/g.manual.py 2015-05-03 11:24:32 UTC (rev 65180)
@@ -56,7 +56,7 @@
def start_browser(entry):
if browser and \
- browser not in ('xdg-open', 'explorer') and \
+ browser not in ('xdg-open', 'start') and \
not grass.find_program(browser):
grass.fatal(_("Browser '%s' not found") % browser)
@@ -75,7 +75,7 @@
url_path = 'file://' + path
- if browser:
+ if browser and browser not in ('xdg-open', 'start'):
webbrowser.register(browser_name, None)
grass.verbose(_("Starting browser '%(browser)s' for manual"
