[GRASS-SVN] r65200 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Fri May 8 20:31:24 PDT 2015
Author: wenzeslaus
Date: 2015-05-08 20:31:24 -0700 (Fri, 08 May 2015)
New Revision: 65200
grass/trunk/lib/python/script/task.py
pythonlib: more error for script.task.parse_interface
Trying to avoid any possible unhandled excpetion when parsing modules. This helps modules which are parsed on startup to construct menus (toolboxes).
Motivation is an the following reported (http://lists.osgeo.org/pipermail/grass-dev/2015-May/074999.html) error:
ParseError: not well-formed (invalid token): line 17, column 19
which occured in parse_interface during _expandRuntimeModules in toolboxes.py
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py 2015-05-09 02:53:07 UTC (rev 65199)
+++ grass/trunk/lib/python/script/task.py 2015-05-09 03:31:24 UTC (rev 65200)
@@ -24,6 +24,13 @@
import xml.etree.ElementTree as etree
except ImportError:
import elementtree.ElementTree as etree # Python <= 2.4
+from xml.parsers import expat # TODO: works for any Python?
+# Get the XML parsing exceptions to catch. The behavior chnaged with Python 2.7
+# and ElementTree 1.3.
+if hasattr(etree, 'ParseError'):
+ ETREE_EXCEPTIONS = (etree.ParseError, expat.ExpatError)
+else:
+ ETREE_EXCEPTIONS = (expat.ExpatError)
from utils import decode, split
from core import *
@@ -506,7 +513,11 @@
:param parser:
:param blackList:
- tree = etree.fromstring(get_interface_description(name))
+ try:
+ tree = etree.fromstring(get_interface_description(name))
+ except ETREE_EXCEPTIONS as error:
+ raise ScriptError(_("Cannot parse interface description of"
+ "<{name}> module: {error}").format(name=name, error=error))
return parser(tree, blackList=blackList).get_task()
