[GRASS-SVN] r65212 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Sun May 10 05:16:54 PDT 2015
Author: martinl
Date: 2015-05-10 05:16:54 -0700 (Sun, 10 May 2015)
New Revision: 65212
grass/trunk/gui/wxpython/core/render.py
grass/trunk/gui/wxpython/core/ws.py
wxGUI: fix RenderWMSMgr to work with RenderMapMgr
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2015-05-10 11:31:25 UTC (rev 65211)
+++ grass/trunk/gui/wxpython/core/render.py 2015-05-10 12:16:54 UTC (rev 65212)
@@ -570,7 +570,7 @@
self.progressInfo['progresVal'] += 1
if layer in self.progressInfo['downloading']:
self.progressInfo['downloading'].remove(layer)
# for updating statusbar text
stText = ''
first = True
@@ -1124,9 +1124,10 @@
self._addLayer(layer, render, pos)
renderMgr = layer.GetRenderMgr()
+ Debug.msg(1, "Map.AddLayer(): ltype={}, command={}".format(ltype, ' '.join(command)))
if renderMgr:
if layer.type == 'wms':
- renderMgr.dataFetched.connect(self.layerChanged)
+ renderMgr.dataFetched.connect(self.renderMgr.ReportProgress)
renderMgr.updateProgress.connect(self.renderMgr.ReportProgress)
self.layerAdded.emit(layer=layer)
Modified: grass/trunk/gui/wxpython/core/ws.py
--- grass/trunk/gui/wxpython/core/ws.py 2015-05-10 11:31:25 UTC (rev 65211)
+++ grass/trunk/gui/wxpython/core/ws.py 2015-05-10 12:16:54 UTC (rev 65212)
@@ -86,6 +86,9 @@
if not haveGdal:
return
+ Debug.msg(1, "RenderWMSMgr.Render(%s): force=%d img=%s" % \
+ (self.layer, self.layer.forceRender, self.layer.mapfile))
env = copy.copy(env)
self.dstSize['cols'] = int(env["GRASS_RENDER_WIDTH"])
self.dstSize['rows'] = int(env["GRASS_RENDER_HEIGHT"])
@@ -134,7 +137,8 @@
env["GRASS_REGION"] = self._createRegionStr(region)
self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
+ self.updateProgress.emit(layer=self.layer)
def OnCmdOutput(self, event):
"""Print cmd output according to debug level.
@@ -171,7 +175,7 @@
self.fetched_data_cmd = self.fetching_cmd
- self.dataFetched.emit()
+ self.dataFetched.emit(layer=self.layer)
def _getRegionDict(self, env):
"""Parse string from GRASS_REGION env variable into dict.
