[GRASS-SVN] r65225 - grass/trunk/display/d.mon
svn_grass at osgeo.org
Tue May 12 11:12:22 PDT 2015
Author: martinl
Date: 2015-05-12 11:12:22 -0700 (Tue, 12 May 2015)
New Revision: 65225
grass/trunk/display/d.mon/render_cmd.py
d.mon: refactorize render command script into functions
speed-up: perform region adjustment
Modified: grass/trunk/display/d.mon/render_cmd.py
--- grass/trunk/display/d.mon/render_cmd.py 2015-05-12 18:09:17 UTC (rev 65224)
+++ grass/trunk/display/d.mon/render_cmd.py 2015-05-12 18:12:22 UTC (rev 65225)
@@ -5,48 +5,98 @@
from grass.script import core as grass
from grass.script import task as gtask
-cmd, dcmd = gtask.cmdstring_to_tuple(sys.argv[1])
-if not cmd or cmd == 'd.mon':
- sys.exit(0)
-path = os.path.dirname(os.path.abspath(__file__))
-cmd_file = os.path.join(path, 'cmd')
-env_file = os.path.join(path, 'env')
# read environment variables from file
-fd = open(env_file, 'r')
-if fd is None:
- grass.fatal("Unable to open file '%s'" % env_file)
-lines = fd.readlines()
-for l in lines:
- if l.startswith('#'):
- continue
- k, v = l.rstrip('\n').split('#', 1)[0].strip().split('=', 1)
- os.environ[k] = v
-fd.close()
+def read_env_file(env_file):
+ width = height = None
+ fd = open(env_file, 'r')
+ if fd is None:
+ grass.fatal("Unable to open file '{}'".format(env_file))
+ lines = fd.readlines()
+ for l in lines:
+ if l.startswith('#'):
+ continue
+ k, v = l.rstrip('\n').split('#', 1)[0].strip().split('=', 1)
+ os.environ[k] = v
+ if width is None and k == 'GRASS_RENDER_WIDTH':
+ width = int(v)
+ if height is None and k == 'GRASS_RENDER_HEIGHT':
+ height = int(v)
+ fd.close()
+ if width is None or height is None:
+ grass.fatal("Unknown monitor size")
+ return width, height
# run display command
-try:
- grass.run_command(cmd, **dcmd)
-except Exception as e:
- sys.exit("ERROR: %s" % e)
+def render(cmd):
+ try:
+ grass.run_command(cmd[0], **cmd[1])
+ except Exception as e:
+ grass.fatal("Unable to render: {}".format(e))
# update cmd file
-ignoredCmd = ('d.colorlist', 'd.font', 'd.fontlist',
- 'd.frame', 'd.info', 'd.mon', 'd.out.file',
- 'd.redraw', 'd.to.rast', 'd.what.rast',
- 'd.what.vect', 'd.where')
-if cmd not in ignoredCmd:
- mode = 'w' if cmd == 'd.erase' else 'a'
+def update_cmd_file(cmd_file, cmd):
+ if cmd[0] in ('d.colorlist', 'd.font', 'd.fontlist',
+ 'd.frame', 'd.info', 'd.mon', 'd.out.file',
+ 'd.redraw', 'd.to.rast', 'd.what.rast',
+ 'd.what.vect', 'd.where'):
+ return
+ mode = 'w' if cmd[0] == 'd.erase' else 'a'
# update cmd file
fd = open(cmd_file, mode)
if fd is None:
- grass.fatal("Unable to open file '%s'" % cmd_file)
+ grass.fatal("Unable to open file '{}'".format(cmd_file))
if mode == 'a':
- fd.write(sys.argv[1])
+ fd.write(' '.join(gtask.cmdtuple_to_list(cmd)))
fd.write('\n')
else:
fd.write('')
fd.close()
-sys.exit(0)
+# adjust region
+def adjust_region(width, height):
+ region = grass.region()
+ mapwidth = abs(region["e"] - region["w"])
+ mapheight = abs(region['n'] - region['s'])
+ region["nsres"] = mapheight / height
+ region["ewres"] = mapwidth / width
+ region['rows'] = int(round(mapheight / region["nsres"]))
+ region['cols'] = int(round(mapwidth / region["ewres"]))
+ region['cells'] = region['rows'] * region['cols']
+ kwdata = [('proj', 'projection'),
+ ('zone', 'zone'),
+ ('north', 'n'),
+ ('south', 's'),
+ ('east', 'e'),
+ ('west', 'w'),
+ ('cols', 'cols'),
+ ('rows', 'rows'),
+ ('e-w resol', 'ewres'),
+ ('n-s resol', 'nsres')]
+ grass_region = ''
+ for wkey, rkey in kwdata:
+ grass_region += '%s: %s;' % (wkey, region[rkey])
+ os.environ['GRASS_REGION'] = grass_region
+if __name__ == "__main__":
+ cmd = gtask.cmdstring_to_tuple(sys.argv[1])
+ if not cmd[0] or cmd[0] == 'd.mon':
+ sys.exit(0)
+ path = os.path.dirname(os.path.abspath(__file__))
+ mon = os.path.split(path)[-1]
+ width, height = read_env_file(os.path.join(path, 'env'))
+ if not mon.startswith('wx'):
+ adjust_region(width, height)
+ render(cmd)
+ update_cmd_file(os.path.join(path, 'cmd'), cmd)
+ sys.exit(0)
