[GRASS-SVN] r65231 - grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact
svn_grass at osgeo.org
Wed May 13 00:55:39 PDT 2015
Author: osfraid
Date: 2015-05-13 00:55:39 -0700 (Wed, 13 May 2015)
New Revision: 65231
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py
add impact version to adapt to qgis plugin
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py 2015-05-13 06:53:03 UTC (rev 65230)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.impact/r.green.biomassfor.impact.py 2015-05-13 07:55:39 UTC (rev 65231)
@@ -28,72 +28,93 @@
#% description: Name of vector parcel map
#% label: Name of vector parcel map
#% required : yes
-#% guisection: Base
#%end
-#%option G_OPT_R_INPUT
-#% key: yield1
+#%option G_OPT_V_INPUT
+#% key: boundaries
#% type: string
-#% description: Map of forest yield (cubic meters)
+#% description: Name of vector boundaries map (boolean map)
+#% label: Name of vector boundaries map (boolean map)
#% required : yes
#%end
-#% key: yield_surface
+#%option
+#% key: forest_column_yield
#% type: string
-#% description: Map of stand surface (ha)
+#% description: Vector field of yield
#% required : yes
#%end
-#% key: management
+#%option
+#% key: forest_column_yield_surface
#% type: string
-#% description: Map of forest management (1: high forest, 2:coppice)
+#% description: Vector field of stand surface (ha)
#% required : yes
#%end
-#% key: treatment
+#%option
+#% key: forest_column_management
#% type: string
-#% description: Map of forest treatment (1: final felling, 2:thinning)
+#% description: Vector field of forest management (1: high forest, 2:coppice)
#% required : yes
#%end
+#%option
+#% key: forest_column_treatment
+#% type: string
+#% description: Vector field of forest treatment (1: final felling, 2:thinning)
+#% required : yes
+#%end
#% key: forest_roads
#% type: string
-#% description: Raster map of forest roads (0, 1)
+#% description: Vector map of forest roads
+#% label: Vector map of forest roads
#% required : yes
#%end
#%option
+#% key: forest_column_roughness
+#% type: string
+#% description: Vector field of roughness
+#% required : no
+#% guisection: Opt files
+#%end
+#% key: rivers
+#% type: string
+#% description: Vector map of rivers
+#% label: Vector map of rivers
+#% required : no
+#%end
+#% key: lakes
+#% type: string
+#% description: Vector map of lakes
+#% label: Vector map of lakes
+#% required : no
+#%end
+#%option
#% key: energy_tops_hf
#% type: double
#% description: Energy for tops and branches in high forest in MWh/m³
#% answer: 0.49
-#% required : yes
+#% guisection: Energy
#%end
#%option
#% key: energy_cormometric_vol_hf
#% type: double
#% description: Energy for tops and branches for high forest in MWh/m³
#% answer: 1.97
-#% required : yes
#%end
#%option
#% key: energy_tops_cop
#% type: double
#% description: Energy for tops and branches for Coppices in MWh/m³
#% answer: 0.55
-#% required : yes
#%end
#% key: energy_map
#% description: Bioenergy map in MWh/m³
#% required : yes
#%end
#% key: dhp
@@ -101,7 +122,6 @@
#% description: Name of vector district heating points
#% label: Name of vector district heating points
#% required : yes
#%end
#%option
#% key: output_sw_map
@@ -139,21 +159,21 @@
#% guisection: Soil and water protection
#%end
#%option G_OPT_R_OUTPUT
-#% key: output_co2_map
+#% key: output_basename_co2map
#% type: string
#% description: Name for output CO2 emissions map
#% key_desc : name
#% guisection: CO2 Emission
#%end
-#% key: output_aco2_map
+#% key: output_basename_aco2map
#% type: string
#% description: Name for output avoided CO2 emissions map
#% key_desc : name
#%end
-#% key: output_netco2_map
+#% key: output_basename_nco2map
#% type: string
#% description: Name for output net CO2 emissions map
#% key_desc : name
@@ -166,12 +186,12 @@
#% required : no
#% guisection : CO2 Emission
#%end
-#% key: roughness
+#%option
#% type: string
-#% description: Name of roughness map
#% required : no
-#% guisection: CO2 Emission
#%end
#% key: soilp2_map
@@ -194,28 +214,14 @@
#% required : no
#%end
#% key: main_roads
#% type: string
-#% description: Name of raster main roads
-#% label: Name of raster main roads
-#% required : yes
-#%end
-#% key: rivers
-#% type: string
-#% description: Raster map of rivers (0, 1)
+#% description: Vector map of main roads
+#% label: Vector map of main roads
#% required : no
#%end
-#% key: lakes
-#% type: string
-#% description: Raster map of lakes (0, 1)
-#% required : no
-#%end
#%option
#% key: slp_min_cc
#% type: double
@@ -277,6 +283,7 @@
#% type: string
#% description: Name for output reduction map of fire risk
#% key_desc : name
+#% required : no
#% guisection: Fire risk
#%end
@@ -291,6 +298,7 @@
#% type: string
#% description: Name for output total recreational map
#% key_desc : name
+#% required : no
#% guisection: Recreational
#%end
@@ -298,6 +306,7 @@
#% type: string
#% description: Name for output improved recreational map
#% key_desc : name
+#% required : no
#%end
@@ -335,6 +344,7 @@
#% description: TEV result
#% gisprompt: new
#% key_desc : name
+#% required : no
#% guisection: TEV
#%end
#%option
@@ -432,13 +442,11 @@
-def yield_pix_process(opts, flgs):
+def yield_pix_process(opts, flgs,yield_,yield_surface):
#YPIX = 'yield_pix = yield_pix1*%d + yield_pix2*%d'
YPIX = ''
- yield_surface=opts['yield_surface']
- yield_=opts['yield1']
expr_surf='analysis_surface='+opts['energy_map']+'>0'
run_command('r.mapcalc', overwrite=ow,expression=expr_surf)
@@ -473,7 +481,7 @@
management=opts['management']
treatment=opts['treatment']
- yield_pix_process(opts, flgs)
+ yield_pix_process(opts, flgs,yield_,yield_surface)
expr_prodFF='site_prod_bioenergyFF = if(('+management+'==1 || '+management+'==2) && ('+treatment+'==1 || '+treatment+'==99999), '+opts['energy_map']+'*0.9)'
expr_prodT='site_prod_bioenergyT = if('+treatment+'==2 && ('+opts['soilp_map']+'==1 || '+opts['soilp_map']+'==2), analysis_surface*yield_pix*%f*0+yield_pix*%f, if('+treatment+'==2 && '+opts['soilp_map']+'>2, analysis_surface*yield_pix*%f*0.7+yield_pix*%f))'
@@ -508,7 +516,7 @@
run_command("r.slope.aspect", flags="a", overwrite=ow,elevation=opts['dtm'], slope="slope__", format="percent")
# Soil and water protection
@@ -585,31 +593,91 @@
def avoided_CO2_emission(opts, flgs):
- vector_forest=opts['forest']
- management=opts['management']
- treatment=opts['treatment']
- roughness=opts['roughness']
+ forest=opts['forest']
+ boundaries=opts['boundaries']
+ yield_=opts['forest_column_yield']
+ management=opts['forest_column_management']
+ treatment=opts['forest_column_treatment']
+ yield_surface=opts['forest_column_yield_surface']
+ roughness=opts['forest_column_roughness']
+ forest_roads=opts['forest_roads']
+ main_roads=opts['main_roads']
tree_diam=opts['tree_diam']
tree_vol=opts['tree_vol']
soil_prod=opts['soilp2_map']
- forest_roads=opts['forest_roads']
- main_roads=opts['main_roads']
rivers=opts['rivers']
lakes=opts['lakes']
+ dhp=opts['dhp']
- if tree_diam == '':
- tree_diam="99999"
- if tree_vol == '':
- tree_vol="9.999"
- if soil_prod == '':
- soil_prod="99999"
+ vector_forest=opts['forest']
- dhp=opts['dhp']
+ ######## start import and convert ########
+ run_command("g.region",vect=boundaries)
+ run_command("v.to.rast", input=forest,output="yield", use="attr", attrcolumn=yield_,overwrite=True)
+ run_command("v.to.rast", input=forest,output="yield_surface", use="attr", attrcolumn=yield_surface,overwrite=True)
+ run_command("v.to.rast", input=forest,output="treatment", use="attr", attrcolumn=treatment,overwrite=True)
+ run_command("v.to.rast", input=forest,output="management", use="attr", attrcolumn=management,overwrite=True)
+ run_command("v.to.rast", input=forest_roads,output="forest_roads", use="val", overwrite=True)
+ run_command("v.to.rast", input=main_roads,output="main_roads", use="val", overwrite=True)
+ run_command("r.null", map='yield',null=0)
+ run_command("r.null", map='yield_surface',null=0)
+ run_command("r.null", map='treatment',null=0)
+ run_command("r.null", map='management',null=0)
+ ######## end import and convert ########
+ ######## temp patch to link map and fields ######
+ management="management"
+ treatment="treatment"
+ yield_surface="yield_surface"
+ yield_="yield"
+ forest_roads="forest_roads"
+ main_roads="main_roads"
+ ######## end temp patch to link map and fields ######
+ if roughness=='':
+ run_command("r.mapcalc",overwrite=ow,expression='roughness=0')
+ roughness='roughness'
+ else:
+ run_command("v.to.rast", input=forest,output="roughness", use="attr", attrcolumn=roughness,overwrite=True)
+ run_command("r.null", map='roughness',null=0)
+ if tree_diam=='':
+ run_command("r.mapcalc",overwrite=ow,expression='tree_diam=99999')
+ tree_diam='tree_diam'
+ if tree_vol=='':
+ run_command("r.mapcalc",overwrite=ow,expression='tree_vol=9.999')
+ tree_vol='tree_vol'
+ if soil_prod=='':
+ run_command("r.mapcalc",overwrite=ow,expression='soil_map=99999')
+ soil_prod='soil_map'
#process the yield_pix map
#control and process the slope map
run_command("r.slope.aspect", overwrite=ow,elevation=opts['dtm2'], slope="slope__", format="percent")
@@ -627,21 +695,21 @@
- if roughness=='':
- run_command("r.mapcalc",overwrite=ow,expression='roughness=0')
- roughness='roughness'
run_command("r.null", map="yield_pix1", null=0)
run_command("r.null", map="morphometric_features", null=0)
exprmap='frict_surf_extr = pix_cross + if(yield_pix1<=0, 99999) + if(morphometric_features==6, 99999)'
if rivers!='':
- run_command("r.null", map=rivers, null=0)
+ run_command("v.to.rast", input=rivers,output="rivers", use="val", overwrite=True)
+ run_command("r.null", map="rivers", null=0)
+ rivers="rivers"
exprmap+='+ if('+rivers+'>=1, 99999)'
- if lakes!='':
- run_command("r.null", map=lakes, null=0)
+ if lakes!='':
+ run_command("v.to.rast", input=lakes,output="lakes", use="val", overwrite=True)
+ run_command("r.null", map="lakes", null=0)
+ lakes="lakes"
exprmap+='+ if('+lakes+'>=1, 99999)'
@@ -682,8 +750,8 @@
#r.mapcalc --o 'fell_proc_productC = if(management at PERMANENT ==2 && soil_prod at PERMANENT <99999,((0.3-(1.1*soil_prod at PERMANENT))/(-4))*(1-(slope at PERMANENT/100)), if(management at PERMANENT ==2 && soil_prod at PERMANENT == 99999,((0.3-(1.1*3))/(-4))*(1-((1000-(90*slope at PERMANENT)/(-80))/100))))'
+ #import ipdb; ipdb.set_trace()
run_command("r.mapcalc", overwrite=ow,
expression='proc_productHFtr1 = if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'==99999, cable_crane_extraction*0.363*35^1.116, if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'<99999, cable_crane_extraction*0.363*'+tree_diam+'^1.116))')
run_command("r.null", map="proc_productHFtr1", null=0)
@@ -780,16 +848,16 @@
run_command("r.null", map='extr_forw_em', null=0)
run_command("r.null", map='extr_other_em', null=0)
run_command("r.null", map='transport_em', null=0)
- run_command("r.mapcalc", overwrite=ow, expression=opts['output_co2_map']+' = (analysis_surface*(fell_HFtr1_em + fell_HFtr2_em + fell_proc_C_em + proc_HFtr1_em + fell_proc_HFtr1_em + fell_proc_HFtr2_em + chipp_em + extr_cableHF_em + extr_cableC_em + extr_forw_em + extr_other_em + transport_em))/1000')
- run_command("r.mapcalc", overwrite=ow, expression=opts['output_aco2_map']+' = '+opts['energy_map']+'*320')
+ run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_co2map']+' = (analysis_surface*(fell_HFtr1_em + fell_HFtr2_em + fell_proc_C_em + proc_HFtr1_em + fell_proc_HFtr1_em + fell_proc_HFtr2_em + chipp_em + extr_cableHF_em + extr_cableC_em + extr_forw_em + extr_other_em + transport_em))/1000')
+ run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_aco2map']+' = '+opts['energy_map']+'*320')
#run_command("r.mapcalc", overwrite=ow, expression=opts['output_netco2_map']+' = analysis_surface*'+('+opts['output_aco2_map']+' - '+opts['output_co2_map']+')/1000')
- run_command("r.mapcalc", overwrite=ow, expression=opts['output_netco2_map']+' = analysis_surface*('+opts['output_aco2_map']+' - '+opts['output_co2_map']+')/1000')
+ run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_nco2map']+' = analysis_surface*('+opts['output_basename_aco2map']+' - '+opts['output_basename_co2map']+')/1000')
- mapco2=opts['output_co2_map']
+ mapco2=opts['output_basename_co2map']
with RasterRow(mapco2) as pT:
T = np.array(pT)
- mapaco2=opts['output_netco2_map']
+ mapaco2=opts['output_basename_nco2map']
with RasterRow(mapaco2) as pT1:
A = np.array(pT1)
@@ -881,7 +949,7 @@
# biodiversity_maintenance(opts, flgs)
# sustainable_bioenergy(opts, flgs)
- if(opts['output_co2_map'])!="":
+ if(opts['output_basename_co2map'])!="":
if(opts['output_fr_map'])!="":
