[GRASS-SVN] r65236 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Thu May 14 18:20:19 PDT 2015
Author: annakrat
Date: 2015-05-14 18:20:19 -0700 (Thu, 14 May 2015)
New Revision: 65236
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: removed item (g.region zoom) from layer context menu
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2015-05-14 13:00:38 UTC (rev 65235)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2015-05-15 01:20:19 UTC (rev 65236)
@@ -404,7 +404,7 @@
self.popupID = dict()
for key in ('remove', 'rename', 'opacity', 'nviz', 'zoom',
'region', 'export', 'attr', 'edit', 'save_ws',
- 'bgmap', 'topo', 'meta', 'null', 'zoom1', 'region1',
+ 'bgmap', 'topo', 'meta', 'null', 'zoom1',
'color', 'hist', 'univar', 'prof', 'properties', 'sql', 'copy',
'report', 'export-pg', 'pack'):
self.popupID[key] = wx.NewId()
@@ -577,8 +577,6 @@
if same:
self.popupMenu.Append(self.popupID['zoom1'], text=_("Zoom to selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id=self.popupID['zoom1'])
- self.popupMenu.Append(self.popupID['region1'], text=_("Set computational region from selected map(s) (ignore NULLs)"))
- self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID['region1'])
self.popupMenu.AppendSeparator()
@@ -699,12 +697,13 @@
self._giface.RunCmd(cmd)
def OnSetCompRegFromRaster(self, event):
- """Set computational region from selected raster map (ignore NULLs)"""
+ """Set computational region from selected raster map (ignore NULLs).
+ Unused, removed item from layer context menu"""
mapLayer = self.GetLayerInfo(self.layer_selected, key = 'maplayer')
- cmd = ['g.region',
+ cmd = ['g.region', 'raster=%s' % mapLayer.GetName(),
'zoom=%s' % mapLayer.GetName()]
# print output to command log area
self._giface.RunCmd(cmd, notification=Notification.NO_NOTIFICATION)
