[GRASS-SVN] r65250 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri May 15 08:46:46 PDT 2015
Author: wenzeslaus
Date: 2015-05-15 08:46:46 -0700 (Fri, 15 May 2015)
New Revision: 65250
grass/trunk/lib/init/grass.py
init: implement functions for debugging
Solves the debug mode by proper means, not by ad hoc tests. Follows style which is in grass.script.core.
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-15 15:42:52 UTC (rev 65249)
+++ grass/trunk/lib/init/grass.py 2015-05-15 15:46:46 UTC (rev 65250)
@@ -136,6 +136,38 @@
sys.stderr.flush()
+# mechanism meant for debugging this script (only)
+# private global to store if we are debugging
+_DEBUG = None
+def is_debug():
+ """Returns True if we are in debug mode
+ For debug messages use ``debug()``.
+ global _DEBUG
+ if _DEBUG is not None:
+ return _DEBUG
+ _DEBUG = os.getenv('GRASS_DEBUG')
+ # translate to bool (no or empty variable means false)
+ if _DEBUG:
+ _DEBUG = True
+ else:
+ _DEBUG = False
+ return _DEBUG
+def debug(msg):
+ """Print a debug message if in debug mode
+ Do not use translatable strings for debug messages.
+ if is_debug():
+ sys.stderr.write("DEBUG: %s\n" % msg)
+ sys.stderr.flush()
def readfile(path):
f = open(path, 'r')
s = f.read()
@@ -808,9 +840,8 @@
return
else:
- if grass_debug:
- message(_("A language override has been requested. Trying to switch GRASS into '%s'...") % language)
+ debug("A language override has been requested."
+ " Trying to switch GRASS into '%s'..." % language)
try:
locale.setlocale(locale.LC_ALL, language)
except locale.Error as e:
@@ -987,8 +1018,7 @@
def start_gui(grass_gui):
# Start the chosen GUI but ignore text
- if grass_debug:
- message(_("GRASS GUI should be <%s>") % grass_gui)
+ debug("GRASS GUI should be <%s>" % grass_gui)
# Check for gui interface
if grass_gui == "wxpython":
@@ -996,13 +1026,13 @@
def clear_screen():
- global windows, grass_debug
+ global windows
if windows:
pass
# TODO: uncomment when PDCurses works.
# cls
else:
- if not grass_debug:
+ if not is_debug():
call(["tput", "clear"])
@@ -1325,9 +1355,11 @@
# Set default GUI
default_gui = "wxpython"
-# the following is only meant to be an internal variable for debugging this
-# script. use 'g.gisenv set="DEBUG=[0-5]"' to turn GRASS debug mode on properly
-grass_debug = os.getenv('GRASS_DEBUG')
+# explain what is happening in debug mode
+debug("GRASS_DEBUG environmental variable is set. It is meant to be"
+ " an internal variable for debugging only this script.\n"
+ " Use 'g.gisenv set=\"DEBUG=[0-5]\"'"
+ " to turn GRASS GIS debug mode on if you wish to do so.")
# Set GRASS version number for R interface etc (must be an env_var for MS-Windows)
os.environ['GRASS_VERSION'] = grass_version
