[GRASS-SVN] r65252 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri May 15 13:57:09 PDT 2015
Author: wenzeslaus
Date: 2015-05-15 13:57:09 -0700 (Fri, 15 May 2015)
New Revision: 65252
grass/trunk/lib/init/grass.py
init: execute command specified as parameter, see #2579
Implements parameter (subcommand) exec for executing 'batch jobs' from command line. The current syntax is:
grass71 /grassdata/location/mapset exec g.region -p
where any original grass71 parameter can stand before exec and after exec arbitrary command line parameters can be placed (first is considered to be the executable).
Tested for modules and Python scripts. Probably cannot work under MS Windows for Python (modules and user scripts) but it should work when an interpreter is specified explicitly.
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-15 16:04:27 UTC (rev 65251)
+++ grass/trunk/lib/init/grass.py 2015-05-15 20:57:09 UTC (rev 65252)
@@ -999,21 +999,21 @@
def run_batch_job(batch_job):
- # defined, but ...
- if not os.access(batch_job, os.F_OK):
- # wrong file
- fatal(_("Job file '%s' has been defined in "
- "the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n\n"
- "Use 'unset GRASS_BATCH_JOB' to disable batch job processing.") % batch_job)
- elif not os.access(batch_job, os.X_OK):
- # right file, but ...
- fatal(_("Change file permission to 'executable' for '%s'") % batch_job)
+ batch_job_string = batch_job
+ if not isinstance(batch_job, basestring):
+ batch_job_string = ' '.join(batch_job)
+ message(_("Executing <%s> ...") % batch_job_string)
+ if isinstance(batch_job, basestring):
+ proc = Popen(batch_job, shell=True)
else:
- message(_("Executing '%s' ...") % batch_job)
- shell = batch_job
- bj = Popen(shell, shell=True)
- bj.wait()
- message(_("Execution of '%s' finished.") % batch_job)
+ try:
+ proc = Popen(batch_job, shell=False)
+ except OSError as error:
+ fatal(_("Execution of <{cmd}> failed:\n"
+ "{error}").format(cmd=batch_job_string, error=error))
+ returncode = proc.wait()
+ message(_("Execution of <%s> finished.") % batch_job_string)
+ return returncode
def start_gui(grass_gui):
@@ -1285,10 +1285,10 @@
user = "user_%d" % os.getuid()
-def parse_cmdline():
+def parse_cmdline(argv):
global args, grass_gui, create_new, exit_grass, force_gislock_removal
args = []
- for i in sys.argv[1:]:
+ for i in argv:
# Check if the user asked for the version
if i in ["-v", "--version"]:
message("GRASS GIS %s" % grass_version)
@@ -1323,6 +1323,7 @@
else:
args.append(i)
### MAIN script starts here
# Get the system name
@@ -1373,6 +1374,18 @@
batch_job = get_batch_job()
+# variable defined, but user might not have been careful enough
+if batch_job:
+ if not os.access(batch_job, os.F_OK):
+ # wrong file
+ fatal(_("Job file '%s' has been defined in "
+ "the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n\n"
+ "Use 'unset GRASS_BATCH_JOB' to disable batch job processing.") % batch_job)
+ elif not os.access(batch_job, os.X_OK):
+ # right file, but ...
+ fatal(_("Change file permission to 'executable' for '%s'") % batch_job)
# Set the global grassrc file
if batch_job:
gisrcrc = os.path.join(grass_config_dir, "rc.%s" % platform.node())
@@ -1381,14 +1394,24 @@
else:
gisrcrc = os.path.join(grass_config_dir, "rc")
-# Set the username and working directory
-get_username()
+# Parse the command-line options and set several global variables
+BATCH_EXEC_SUBCOMMAND = 'exec'
-# Parse the command-line options
-parse_cmdline()
+try:
+ # raises ValueError when not found
+ index = sys.argv.index(BATCH_EXEC_SUBCOMMAND)
+ batch_job = sys.argv[index + 1:]
+ clean_argv = sys.argv[1:index]
+ parse_cmdline(clean_argv)
+except ValueError:
+ parse_cmdline(sys.argv[1:])
if exit_grass and not create_new:
fatal(_("Flag -e required also flag -c"))
+# Set the username and working directory
+get_username()
# Set language
# This has to be called before any _() function call!
# Subsequent functions are using _() calls and
@@ -1489,10 +1512,10 @@
# Display the version and license info
# only non-error, interactive version continues from here
if batch_job:
- run_batch_job(batch_job)
+ returncode = run_batch_job(batch_job)
clean_temp()
try_remove(lockfile)
- sys.exit(0)
+ sys.exit(returncode)
elif exit_grass:
clean_temp()
