[GRASS-SVN] r65258 - grass/trunk/lib/init
svn_grass at osgeo.org
Sat May 16 18:08:53 PDT 2015
Author: martinl
Date: 2015-05-16 18:08:53 -0700 (Sat, 16 May 2015)
New Revision: 65258
grass/trunk/lib/init/grass.py
grass.py: fix cleanup - must be registered when tmpdir variable is initialized
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-17 01:01:30 UTC (rev 65257)
+++ grass/trunk/lib/init/grass.py 2015-05-17 01:08:53 UTC (rev 65258)
@@ -1362,8 +1362,6 @@
if not os.getenv('SHELL'):
os.environ['SHELL'] = os.getenv('COMSPEC', 'cmd.exe')
-atexit.register(cleanup, tmpdir)
# Set default GUI
default_gui = "wxpython"
@@ -1431,6 +1429,7 @@
# Create the temporary directory and session grassrc file
tmpdir = create_tmp()
+atexit.register(cleanup, tmpdir)
# Create the session grassrc file
gisrc = create_gisrc(tmpdir, gisrcrc)
