[GRASS-SVN] r65265 - grass/branches/releasebranch_7_0/lib/cairodriver
Mon May 18 02:16:55 PDT 2015
Author: neteler
Date: 2015-05-18 02:16:55 -0700 (Mon, 18 May 2015)
New Revision: 65265
   grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
cairodriver manual: SVG example added
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html
--- grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html	2015-05-18 09:16:49 UTC (rev 65264)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.html	2015-05-18 09:16:55 UTC (rev 65265)
@@ -84,8 +84,10 @@
   </li>
 </ul>
-<h3>Examples</h3>
+<h2>EXAMPLES</h2>
+<h3>PNG Example</h3>
 Example: using the driver to generate a PNG file (bash-syntax):
 <div class="code"><pre>
@@ -101,9 +103,10 @@
 d.vect map=roadsmajor width=2
 </pre></div>
-<!-- TODO: why does it generate rasterized output?
+<h3>PDF Examples</h3>
-Example: using the driver to generate a PDF file with a vector map (bash-syntax):
+Example: using the driver to generate a PDF vector file with a vector
+map (bash-syntax):
 export GRASS_RENDER_IMMEDIATE=cairo
@@ -116,9 +119,10 @@
 d.font Vera
 d.vect map=roadsmajor layer=1 display=shape attrcolumn=ROAD_NAME lcolor=0:90:255
 </pre></div>
-Example: using the driver to generate a PDF file with a raster map (bash-syntax):
+<p>
+Example: using the driver to generate a PDF raster file with a raster
+map (bash-syntax):
@@ -131,6 +135,20 @@
 </pre></div>
+<h3>SVG Example</h3>
+Example: using the driver to generate a SVG vector file with a vector
+map (bash-syntax):
+<div class="code"><pre>
+export GRASS_RENDER_IMMEDIATE=cairo
+export GRASS_RENDER_FILE=vectormap.svg
+g.region vector=roadsmajor
+d.vect map=roadsmajor -c
+</pre></div>
 <h2>NOTES</h2>
 The driver is still in development. Enable it by specifying
