[GRASS-SVN] r65267 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon May 18 08:39:41 PDT 2015
Author: wenzeslaus
Date: 2015-05-18 08:39:41 -0700 (Mon, 18 May 2015)
New Revision: 65267
grass/trunk/lib/init/grass.py
init: remove global variables from user, tmpdir and check GUI functions
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-18 12:52:31 UTC (rev 65266)
+++ grass/trunk/lib/init/grass.py 2015-05-18 15:39:41 UTC (rev 65267)
@@ -194,13 +194,32 @@
def gpath(*args):
+ """Costruct path to file or directory in GRASS GIS installation
+ Can be called only after gisbase was set.
return os.path.join(gisbase, *args)
+# for wxpath
+_WXPYTHON_BASE = None
def wxpath(*args):
- return os.path.join(wxpython_base, *args)
+ """Costruct path to file or directory in GRASS wxGUI
+ This function does not check if the directories exist or if GUI works
+ this must be done by the caller if needed.
+ global _WXPYTHON_BASE
+ if not _WXPYTHON_BASE:
+ # this can be called only after gisbase was set
+ _WXPYTHON_BASE = gpath("gui", "wxpython")
+ return os.path.join(_WXPYTHON_BASE, *args)
help_text = r"""GRASS GIS %s
Geographic Resources Analysis Support System (GRASS GIS).
@@ -274,8 +293,13 @@
sys.stderr.write(s)
-def create_tmp():
- ## use $TMPDIR if it exists, then $TEMP, otherwise /tmp
+def create_tmp(user, gis_lock):
+ """Create temporary directory
+ :param user: user name to be used in the directory name
+ :param gis_lock: session lock filename to be used in the directory name
+ # use $TMPDIR if it exists, then $TEMP, otherwise /tmp
tmp = os.getenv('TMPDIR')
if not tmp:
tmp = os.getenv('TEMP')
@@ -283,7 +307,7 @@
tmp = os.getenv('TMP')
if not tmp:
tmp = tempfile.gettempdir()
if tmp:
tmpdir = os.path.join(tmp, "grass7-%(user)s-%(lock)s" % {'user': user,
'lock': gis_lock})
@@ -291,7 +315,7 @@
os.mkdir(tmpdir, 0700)
except:
tmp = None
if not tmp:
for ttmp in ("/tmp", "/var/tmp", "/usr/tmp"):
tmp = ttmp
@@ -303,13 +327,14 @@
tmp = None
if tmp:
break
if not tmp:
fatal(_("Unable to create temporary directory <grass7-%(user)s-"
"%(lock)s>! Exiting.") % {'user': user, 'lock': gis_lock})
+ # promoting the variable even if it was not defined before
os.environ['TMPDIR'] = tmpdir
return tmpdir
@@ -563,7 +588,6 @@
def check_gui(expected_gui):
- global wxpython_base
grass_gui = expected_gui
# Check if we are running X windows by checking the DISPLAY variable
if os.getenv('DISPLAY') or windows or macosx:
@@ -576,10 +600,7 @@
p.stdin.write("variable=True")
p.stdin.close()
p.wait()
- if p.returncode == 0:
- # Set the wxpython base directory
- wxpython_base = gpath("gui", "wxpython")
- else:
+ if p.returncode != 0:
# Python was not found - switch to text interface mode
warning(_("The python command does not work as expected!\n"
"Please check your GRASS_PYTHON environment variable.\n"
@@ -1274,7 +1295,7 @@
def get_username():
- global user
+ """Get name of the current user"""
if windows:
user = os.getenv('USERNAME')
if not user:
@@ -1293,6 +1314,7 @@
pass
if not user:
user = "user_%d" % os.getuid()
+ return user
def parse_cmdline(argv):
@@ -1419,7 +1441,7 @@
fatal(_("Flag -e requires also flag -c"))
# Set the username
-get_username()
+user = get_username()
# Set language
# This has to be called before any _() function call!
@@ -1428,7 +1450,7 @@
set_language()
# Create the temporary directory and session grassrc file
-tmpdir = create_tmp()
+tmpdir = create_tmp(user, gis_lock)
atexit.register(cleanup, tmpdir)
# Create the session grassrc file
