[GRASS-SVN] r65274 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon May 18 14:13:32 PDT 2015
Author: wenzeslaus
Date: 2015-05-18 14:13:32 -0700 (Mon, 18 May 2015)
New Revision: 65274
grass/trunk/lib/init/grass.py
init: refactor function for detecting and creating location and mapset
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-18 20:03:37 UTC (rev 65273)
+++ grass/trunk/lib/init/grass.py 2015-05-18 21:13:32 UTC (rev 65274)
@@ -645,6 +645,83 @@
write_gisrc(kv, gisrc)
+def create_location(gisdbase, location, geostring):
+ """Create GRASS Location using georeferenced file or EPSG
+ EPSG code format is ``EPSG:code`` or ``EPSG:code:datum_trans``.
+ :param gisdbase: Path to GRASS GIS database directory
+ :param location: name of new Location
+ :param geostring: path to a georeferenced file or EPSG code
+ if gpath('etc', 'python') not in sys.path:
+ sys.path.append(gpath('etc', 'python'))
+ from grass.script import core as gcore # pylint: disable=E0611
+ try:
+ if geostring and geostring.upper().find('EPSG:') > -1:
+ # create location using EPSG code
+ epsg = geostring.split(':', 1)[1]
+ if ':' in epsg:
+ epsg, datum_trans = epsg.split(':', 1)
+ else:
+ datum_trans = None
+ gcore.create_location(gisdbase, location,
+ epsg=epsg, datum_trans=datum_trans)
+ else:
+ # create location using georeferenced file
+ filename=geostring)
+ except gcore.ScriptError as e:
+ fatal(e.value.strip('"').strip("'").replace('\\n', os.linesep))
+# interface created according to the current usage
+def is_mapset_valid(full_mapset):
+ """Return True if GRASS Mapset is valid"""
+ return os.access(os.path.join(full_mapset, "WIND"), os.R_OK)
+def is_location_valid(gisdbase, location):
+ """Return True if GRASS Location is valid
+ :param location: name of a Location
+ return os.access(os.path.join(gisdbase, location,
+ "PERMANENT", "DEFAULT_WIND"), os.F_OK)
+# basically checking location, possibly split into two functions
+# (mapset one can call location one)
+def get_mapset_invalid_reason(gisdbase, location, mapset):
+ """Returns a message describing what is wrong with the Mapset
+ :param mapset: name of a Mapset
+ :returns: translated message
+ full_location = os.path.join(gisdbase, location)
+ if not os.path.exists(full_location):
+ return _("Location <%s> doesn't exist") % full_location
+ elif 'PERMANENT' not in os.listdir(full_location):
+ return _("<%s> is not a valid GRASS Location"
+ " because PERMANENT Mapset is missing") % full_location
+ elif not os.path.isdir(os.path.join(full_location, 'PERMANENT')):
+ " because PERMANENT is not a directory") % full_location
+ elif not os.path.isfile((os.path.join(full_location,
+ 'PERMANENT', 'DEFAULT_WIND'))):
+ " because PERMANENT Mapset does not have a DEFAULT_WIND file"
+ " (default computational region)") % full_location
+ else:
+ return _("Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. "
+ "A new mapset can be created by '-c' switch.").format(
+ mapset=mapset, loc=location)
def non_interactive(arg, geofile=None, create_new=False):
global gisdbase, location_name, mapset, location
# Try non-interactive startup
@@ -672,62 +749,24 @@
location = os.path.join(gisdbase, location_name, mapset)
# check if 'location' is a valid GRASS location/mapset
- if not os.access(os.path.join(location, "WIND"), os.R_OK):
+ if not is_mapset_valid(location):
if not create_new:
# 'location' is not valid, check if 'location_name' is
# a valid GRASS location
- if not os.path.exists(os.path.join(gisdbase, location_name)):
- fatal(_("Location <%s> doesn't exist") % os.path.join(gisdbase, location_name))
- elif 'PERMANENT' not in os.listdir(os.path.join(gisdbase, location_name)) or \
- not os.path.isdir(os.path.join(gisdbase, location_name, 'PERMANENT')) or \
- not os.path.isfile((os.path.join(gisdbase, location_name, 'PERMANENT',
- 'DEFAULT_WIND'))):
- fatal(_("<%s> is not a valid GRASS location") %
- os.path.join(gisdbase, location_name))
- else:
- fatal(_("Mapset <%s> doesn't exist in GRASS location <%s>. "
- "A new mapset can be created by '-c' switch.") % (mapset, location_name))
+ fatal(get_mapset_invalid_reason(gisdbase, location_name, mapset))
else:
# 'location' is not valid, the user wants to create
# mapset on the fly
- if not os.access(os.path.join(gisdbase, location_name,
- "PERMANENT",
- "DEFAULT_WIND"), os.F_OK):
+ if not is_location_valid(gisdbase, location_name):
# 'location_name' is not a valid GRASS location,
# create new location and 'PERMANENT' mapset
gisdbase = os.path.join(gisdbase, location_name)
location_name = mapset
mapset = "PERMANENT"
- if os.access(os.path.join(os.path.join(gisdbase,
- location_name,
- "PERMANENT",
- "DEFAULT_WIND")),
- os.F_OK):
+ if is_location_valid(gisdbase, location_name):
fatal(_("Failed to create new location. "
"The location <%s> already exists." % location_name))
- if gpath('etc', 'python') not in sys.path:
- sys.path.append(gpath('etc', 'python'))
- from grass.script import core as grass
- try:
- if geofile and geofile.upper().find('EPSG:') > -1:
- # create location using EPSG code
- epsg = geofile.split(':', 1)[1]
- if ':' in epsg:
- epsg, datum_trans = epsg.split(':', 1)
- else:
- datum_trans = None
- grass.create_location(gisdbase, location_name,
- epsg=epsg, datum_trans=datum_trans)
- else:
- # create location using georeferenced file
- filename=geofile)
- except grass.ScriptError as e:
- fatal(e.value.strip('"').strip("'").replace('\\n',
- os.linesep))
+ create_location(gisdbase, location_name, geofile)
else:
# 'location_name' is a valid GRASS location,
# create new mapset
@@ -1330,6 +1369,8 @@
class Parameters:
+ # we don't need to define any methods
+ # pylint: disable=R0903
def __init__(self):
self.grass_gui = None
self.create_new = None
