[GRASS-SVN] r65277 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon May 18 19:34:47 PDT 2015
Author: wenzeslaus
Date: 2015-05-18 19:34:47 -0700 (Mon, 18 May 2015)
New Revision: 65277
grass/trunk/lib/init/grass.py
init: introduce Cleaner class to manage files to clean up, reduce scope of variables
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-18 22:27:23 UTC (rev 65276)
+++ grass/trunk/lib/init/grass.py 2015-05-19 02:34:47 UTC (rev 65277)
@@ -62,9 +62,6 @@
import gettext
gettext.install('grasslibs', os.path.join(gisbase, 'locale'))
-tmpdir = None
-lockfile = None
-remove_lockfile = True
location = None
grass_gui = None
@@ -107,23 +104,26 @@
for name in dirs:
try_rmdir(os.path.join(root, name))
+class Cleaner(object):
+ def __init__(self):
+ self.mapset_path = None
+ self.lockfile = None
+ self.tmpdir = None
-def cleanup(tmpdir):
- global lockfile, remove_lockfile
- # all exits after setting up tmp dirs (system/location) should
- # also tidy it up
- cleanup_dir(tmpdir)
- try_rmdir(tmpdir)
- if location:
- tmpdir_loc = os.path.join(location, ".tmp")
- cleanup_dir(tmpdir_loc)
- try_rmdir(tmpdir_loc)
+ def cleanup(self):
+ # all exits after setting up tmp dirs (system/location) should
+ # also tidy it up
+ cleanup_dir(self.tmpdir)
+ try_rmdir(self.tmpdir)
+ if self.mapset_path:
+ tmpdir_mapset = os.path.join(self.mapset_path, ".tmp")
+ cleanup_dir(tmpdir_mapset)
+ try_rmdir(tmpdir_mapset)
+ # remove lock-file if requested
+ if self.lockfile:
+ try_remove(self.lockfile)
- # remove lock-file if requested
- if lockfile and remove_lockfile:
- try_remove(lockfile)
def fatal(msg):
sys.stderr.write("%s: " % _('ERROR') + msg + os.linesep)
sys.exit(_("Exiting..."))
@@ -347,6 +347,8 @@
# promoting the variable even if it was not defined before
os.environ['TMPDIR'] = tmpdir
+ debug("Tmp directory '{tmpdir}' created for user '{user}'".format(
+ tmpdir=tmpdir, user=user))
return tmpdir
@@ -727,6 +729,9 @@
The gisrc (GRASS environment file) is written at the end.
+ # TODO: it does not seem that these would be ever set before calling this
+ # function, so we may just delete them here (the globals are set from
+ # the gisrc later on). But where is setting from environmental variables?
global gisdbase, location_name, mapset, location
# Try non-interactive startup
l = None
@@ -1018,11 +1023,10 @@
else:
gettext.install('grasslibs', gpath('locale'))
-def check_lock(force_gislock_removal):
- global lockfile
- if not os.path.exists(location):
+def lock_mapset(mapset_path, force_gislock_removal):
+ if not os.path.exists(mapset_path):
fatal(_("Path '%s' doesn't exist") % location)
# Check for concurrent use
lockfile = os.path.join(location, ".gislock")
ret = call([gpath("etc", "lock"), lockfile, "%d" % os.getpid()])
@@ -1043,13 +1047,18 @@
msg = _("Unable to properly access '%s'.\n"
"Please notify system personel.") % lockfile
+ # TODO: the gui decision should be done by the caller
+ # this needs some change to the function interafce, return tupple or
+ # use exceptions (better option)
if msg:
if grass_gui == "wxpython":
call([os.getenv('GRASS_PYTHON'), wxpath("gis_set_error.py"), msg])
+ # TODO: here we probably miss fatal or exit, needs to be added
else:
- global remove_lockfile
- remove_lockfile = False
fatal(msg)
+ debug("Mapset <{mapset}> locked using '{lockfile}'".format(
+ mapset=mapset_path, lockfile=lockfile))
+ return lockfile
def make_fontcap():
@@ -1059,6 +1068,15 @@
call(["g.mkfontcap"])
+def ensure_db_connected(mapset):
+ """Predefine default driver if DB connection not defined
+ :param mapset: full path to the mapset
+ if not os.access(os.path.join(mapset, "VAR"), os.F_OK):
+ call(['db.connect', '-c', '--quiet'])
def check_shell():
global sh, shellname, grass_env_file
# cygwin has many problems with the shell setup
@@ -1205,8 +1223,6 @@
def csh_startup():
- global exit_val
userhome = os.getenv('HOME') # save original home
home = location
os.environ['HOME'] = home
@@ -1253,11 +1269,10 @@
exit_val = call([gpath("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
+ return exit_val
def bash_startup():
- global exit_val
# save command history in mapset dir and remember more
os.environ['HISTFILE'] = os.path.join(location, ".bash_history")
if not os.getenv('HISTSIZE') and not os.getenv('HISTFILESIZE'):
@@ -1309,22 +1324,25 @@
+ return exit_val
def default_startup():
- global exit_val
if windows:
os.environ['PS1'] = "GRASS %s> " % (grass_version)
# "$ETC/run" doesn't work at all???
exit_val = subprocess.call([os.getenv('SHELL')])
+ # TODO: is there a difference between this and clean_temp?
+ # TODO: why this is missing in the other startups?
cleanup_dir(os.path.join(location, ".tmp")) # remove GUI session files from .tmp
else:
os.environ['PS1'] = "GRASS %s (%s):\w > " % (grass_version, location_name)
+ # TODO: this seems to be inconsistent, the other two are no fataling
if exit_val != 0:
fatal(_("Failed to start shell '%s'") % os.getenv('SHELL'))
+ return exit_val
def done_message():
@@ -1562,10 +1580,15 @@
# thus must be called only after Language has been set.
set_language()
# Create the temporary directory and session grassrc file
tmpdir = create_tmp(user, gis_lock)
-atexit.register(cleanup, tmpdir)
+cleaner = Cleaner()
+cleaner.tmpdir = tmpdir
+# object is not destroyed when its method is registered
+atexit.register(cleaner.cleanup)
# Create the session grassrc file
gisrc = create_gisrc(tmpdir, gisrcrc)
@@ -1645,27 +1668,28 @@
mapset = mapset_settings.mapset
location = mapset_settings.full_mapset
-# Check .gislock file
-check_lock(params.force_gislock_removal)
+# TODO: it seems that we are claiming mapset's tmp before locking
+# (this is what the original code did but it is probably wrong)
+cleaner.mapset_path = mapset_settings.full_mapset
+# check and create .gislock file
+cleaner.lockfile = lock_mapset(mapset_settings.full_mapset,
+ params.force_gislock_removal)
# build user fontcap if specified but not present
make_fontcap()
-# predefine default driver if DB connection not defined
-# is this really needed?? Modules should call this when/if required.
-if not os.access(os.path.join(location, "VAR"), os.F_OK):
- call(['db.connect', '-c', '--quiet'])
+# TODO: is this really needed? Modules should call this when/if required.
+ensure_db_connected(location)
# Display the version and license info
# only non-error, interactive version continues from here
if batch_job:
returncode = run_batch_job(batch_job)
clean_temp()
sys.exit(returncode)
elif params.exit_grass:
clean_temp()
sys.exit(0)
else:
start_gui(grass_gui)
@@ -1687,10 +1711,10 @@
clear_screen()
+# TODO: can we just register this atexit?
+# TODO: and what is difference to deleting .tmp which we do?
clean_temp()
-try_remove(lockfile)
# save 'last used' GISRC after removing variables which shouldn't be saved
clean_env(gisrc)
writefile(gisrcrc, readfile(gisrc))
