[GRASS-SVN] r65284 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue May 19 08:12:25 PDT 2015
Author: wenzeslaus
Date: 2015-05-19 08:12:24 -0700 (Tue, 19 May 2015)
New Revision: 65284
grass/trunk/lib/init/grass.py
init: move code from 'main' to functions, remove more usages of global variables
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-19 13:52:15 UTC (rev 65283)
+++ grass/trunk/lib/init/grass.py 2015-05-19 15:12:24 UTC (rev 65284)
@@ -13,6 +13,7 @@
# script from GRASS 6) by Glynn Clements
# Martin Landa <landa.martin gmail.com>
# Luca Delucchi <lucadeluge gmail.com>
+# Vaclav Petras <wenzeslaus gmail.com> (refactoring and exec)
# PURPOSE: Sets up environment variables, parses any remaining
# command line options for setting the GISDBASE, LOCATION,
# and/or MAPSET. Finally it starts GRASS with the appropriate
@@ -47,18 +48,11 @@
else:
config_projshare = "@CONFIG_PROJSHARE@"
-# configuration directory, used also for grass env file
-if sys.platform == 'win32':
- grass_config_dirname = "GRASS7"
- grass_config_dir = os.path.join(os.getenv('APPDATA'), grass_config_dirname)
-else:
- grass_config_dirname = ".grass7"
- grass_config_dir = os.path.join(os.getenv('HOME'), grass_config_dirname)
gisbase = os.path.normpath(gisbase)
# i18N
import gettext
+# TODO: is this needed or even desirable when we have set_language()?
gettext.install('grasslibs', os.path.join(gisbase, 'locale'))
location = None
@@ -103,13 +97,18 @@
for name in dirs:
try_rmdir(os.path.join(root, name))
-class Cleaner(object):
+class Cleaner(object): # pylint: disable=R0903
+ """Holds directories and files which needs to be cleaned or deleted"""
def __init__(self):
self.mapset_path = None
self.lockfile = None
self.tmpdir = None
def cleanup(self):
+ """This can be registered with atexit
+ Object can then still change and add or remove directories to clean"""
# all exits after setting up tmp dirs (system/location) should
# also tidy it up
cleanup_dir(self.tmpdir)
@@ -297,13 +296,26 @@
-def help_message():
+def help_message(default_gui):
t = string.Template(help_text)
s = t.substitute(CMD_NAME=cmd_name, DEFAULT_GUI=default_gui,
VERSION_NUMBER=grass_version)
sys.stderr.write(s)
+def get_grass_config_dir():
+ """Get configuration directory
+ Used also for grass env file (the non-session one)
+ if sys.platform == 'win32':
+ grass_config_dirname = "GRASS7"
+ return os.path.join(os.getenv('APPDATA'), grass_config_dirname)
+ else:
+ grass_config_dirname = ".grass7"
+ return os.path.join(os.getenv('HOME'), grass_config_dirname)
def create_tmp(user, gis_lock):
"""Create temporary directory
@@ -351,6 +363,17 @@
return tmpdir
+def get_gisrc_from_config_dir(grass_config_dir, batch_job):
+ """Set the global grassrc file (aka grassrcrc)"""
+ if batch_job:
+ # use individual GISRCRC files when in batch mode (r33174)
+ filename = os.path.join(grass_config_dir, "rc.%s" % platform.node())
+ if os.access(filename, os.R_OK):
+ return filename
+ # use standard file if in normal mode or the special file is not available
+ return os.path.join(grass_config_dir, "rc")
def create_gisrc(tmpdir, gisrcrc):
# Set the session grassrc file
gisrc = os.path.join(tmpdir, "gisrc")
@@ -409,7 +432,7 @@
f.close()
-def read_gui(default_gui):
+def read_gui(gisrc, default_gui):
grass_gui = None
# At this point the GRASS user interface variable has been set from the
# command line, been set from an external environment variable, or is
@@ -460,7 +483,7 @@
os.environ[var] = path
-def set_paths():
+def set_paths(grass_config_dir):
# addons (path)
addon_path = os.getenv('GRASS_ADDON_PATH')
if addon_path:
@@ -555,7 +578,15 @@
if not os.getenv('GRASS_PROJSHARE'):
os.environ['GRASS_PROJSHARE'] = config_projshare
+def set_display_defaults():
+ """ Predefine monitor size for certain architectures"""
+ if os.getenv('HOSTTYPE') == 'arm':
+ # small monitor on ARM (iPAQ, zaurus... etc)
+ os.environ['GRASS_RENDER_HEIGHT'] = "320"
+ os.environ['GRASS_RENDER_WIDTH'] = "240"
def set_browser():
# GRASS_HTML_BROWSER
browser = os.getenv('GRASS_HTML_BROWSER')
@@ -595,6 +626,12 @@
os.environ['GRASS_HTML_BROWSER'] = browser
+def ensure_home():
+ """Set HOME if not set on MS Windows"""
+ if windows and not os.getenv('HOME'):
+ os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
+ os.getenv('HOMEPATH'))
def create_initial_gisrc(filename):
# for convenience, define GISDBASE as pwd:
s = r"""GISDBASE: %s
@@ -727,7 +764,7 @@
mapset=mapset, loc=location)
-def set_mapset(arg, geofile=None, create_new=False):
+def set_mapset(gisrc, arg, geofile=None, create_new=False):
"""Selected Location and Mapset are checked and created if requested
The gisrc (GRASS environment file) is written at the end.
@@ -874,7 +911,10 @@
return self.gisdbase and self.location and self.mapset
-def load_gisrc(gisrc):
+# TODO: does it really makes sense to tell user about gisrcrc?
+# anything could have happened in between loading from gisrcrc and now
+# (we do e.g. GUI or creating loctation)
+def load_gisrc(gisrc, gisrcrc):
"""Get the settings of Location and Mapset from the gisrc file
:returns: MapsetSettings object
@@ -921,7 +961,7 @@
os.environ['LD_LIBRARY_PATH'] = libpath + os.pathsep + isislibpath + os.pathsep + isis3rdparty
-def set_language():
+def set_language(grass_config_dir):
# This function is used to override system default language and locale
# Such override can be requested only from wxGUI
# An override if user has provided correct environmental variables as
@@ -1027,11 +1067,11 @@
gettext.install('grasslibs', gpath('locale'))
-def lock_mapset(mapset_path, force_gislock_removal):
+def lock_mapset(mapset_path, force_gislock_removal, user):
if not os.path.exists(mapset_path):
- fatal(_("Path '%s' doesn't exist") % location)
+ fatal(_("Path '%s' doesn't exist") % mapset_path)
# Check for concurrent use
- lockfile = os.path.join(location, ".gislock")
+ lockfile = os.path.join(mapset_path, ".gislock")
ret = call([gpath("etc", "lock"), lockfile, "%d" % os.getpid()])
msg = None
if ret == 2:
@@ -1081,6 +1121,14 @@
def get_shell():
+ # set SHELL on ms windowns
+ # this was at the very beginning of the script but it can be anywhere
+ if windows:
+ if os.getenv('GRASS_SH'):
+ os.environ['SHELL'] = os.getenv('GRASS_SH')
+ if not os.getenv('SHELL'):
+ os.environ['SHELL'] = os.getenv('COMSPEC', 'cmd.exe')
# cygwin has many problems with the shell setup
# below, so i hardcoded everything here.
if sys.platform == 'cygwin':
@@ -1219,7 +1267,7 @@
except:
pass
-def show_info():
+def show_info(shellname, grass_gui, default_gui):
sys.stderr.write(
r"""
%-41shttp://grass.osgeo.org
@@ -1457,7 +1505,7 @@
self.geofile = None
-def parse_cmdline(argv):
+def parse_cmdline(argv, default_gui):
params = Parameters()
args = []
for i in argv:
@@ -1468,7 +1516,7 @@
sys.exit()
# Check if the user asked for help
elif i in ["help", "-h", "-help", "--help", "--h"]:
- help_message()
+ help_message(default_gui=default_gui)
sys.exit()
# Check if the -text flag was given
elif i in ["-text", "--text"]:
@@ -1511,6 +1559,9 @@
cygwin = "cygwin" in sys.platform
macosx = "darwin" in sys.platform
+# TODO: it is OK to remove this?
+# at the beginning of this file were are happily getting GISBASE
+# from the environment and we don't care about inconsistencies it might cause
### commented-out: broken winGRASS
# if 'GISBASE' in os.environ:
# sys.exit(_("ERROR: GRASS GIS is already running "
@@ -1520,18 +1571,6 @@
# Set GISBASE
os.environ['GISBASE'] = gisbase
-# set HOME
-if windows and not os.getenv('HOME'):
- os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
- os.getenv('HOMEPATH'))
-# set SHELL
-if windows:
- if os.getenv('GRASS_SH'):
- os.environ['SHELL'] = os.getenv('GRASS_SH')
- if not os.getenv('SHELL'):
- os.environ['SHELL'] = os.getenv('COMSPEC', 'cmd.exe')
# Set default GUI
default_gui = "wxpython"
@@ -1548,19 +1587,12 @@
gis_lock = str(os.getpid())
os.environ['GIS_LOCK'] = gis_lock
+grass_config_dir = get_grass_config_dir()
if not os.path.exists(grass_config_dir):
os.mkdir(grass_config_dir)
batch_job = get_batch_job_from_env_variable()
-# Set the global grassrc file
-if batch_job:
- gisrcrc = os.path.join(grass_config_dir, "rc.%s" % platform.node())
- if not os.access(gisrcrc, os.R_OK):
- gisrcrc = os.path.join(grass_config_dir, "rc")
-else:
# Parse the command-line options and set several global variables
BATCH_EXEC_SUBCOMMAND = 'exec'
@@ -1569,23 +1601,26 @@
index = sys.argv.index(BATCH_EXEC_SUBCOMMAND)
batch_job = sys.argv[index + 1:]
clean_argv = sys.argv[1:index]
- params = parse_cmdline(clean_argv)
+ params = parse_cmdline(clean_argv, default_gui=default_gui)
except ValueError:
- params = parse_cmdline(sys.argv[1:])
+ params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
-grass_gui = params.grass_gui
if params.exit_grass and not params.create_new:
fatal(_("Flag -e requires also flag -c"))
+grass_gui = params.grass_gui
+gisrcrc = get_gisrc_from_config_dir(grass_config_dir, batch_job)
# Set the username
user = get_username()
+# TODO: this might need to be moved before processing of parameters and getting batch job
# Set language
# This has to be called before any _() function call!
# Subsequent functions are using _() calls and
# thus must be called only after Language has been set.
-set_language()
+set_language(grass_config_dir)
# Create the temporary directory and session grassrc file
tmpdir = create_tmp(user, gis_lock)
@@ -1600,34 +1635,20 @@
# Set shell (needs to be called before load_env())
sh, shellname = get_shell()
-grass_env_file = get_grass_env_file(sh, grass_config_dirname)
+grass_env_file = get_grass_env_file(sh, grass_config_dir)
# Load environmental variables from the file
load_env(grass_env_file)
-# Ensure GUI is set
-if batch_job:
- grass_gui = 'text'
-elif not grass_gui:
- # if GUI was not set previously (e.g. command line),
- # get it from rc file or env variable
- grass_gui = read_gui(default_gui)
+ensure_home()
# Set PATH, PYTHONPATH, ...
-set_paths()
+set_paths(grass_config_dir=grass_config_dir)
# Set GRASS_PAGER, GRASS_PYTHON, GRASS_GNUPLOT, GRASS_PROJSHARE
set_defaults()
+set_display_defaults()
# Set GRASS_HTML_BROWSER
set_browser()
-#predefine monitor size for certain architectures
-if os.getenv('HOSTTYPE') == 'arm':
- # small monitor on ARM (iPAQ, zaurus... etc)
- os.environ['GRASS_RENDER_HEIGHT'] = "320"
- os.environ['GRASS_RENDER_WIDTH'] = "240"
# First time user - GISRC is defined in the GRASS script
if not os.access(gisrc, os.F_OK):
if grass_gui == 'text' and not params.mapset:
@@ -1638,6 +1659,8 @@
" - Create manually the GISRC file (%s)") % (cmd_name, cmd_name, gisrcrc))
create_initial_gisrc(gisrc)
else:
+ # clean only for user who is no first time
+ # (measured by presence of rc file)
clean_temp()
if params.create_new:
@@ -1645,9 +1668,17 @@
else:
message(_("Starting GRASS GIS..."))
-# check that the GUI works but only if not doing a batch job
-if not batch_job:
+# Ensure GUI is set
+if batch_job:
+ grass_gui = 'text'
+else:
+ if not grass_gui:
+ # if GUI was not set previously (e.g. command line),
+ # get it from rc file or env variable
+ grass_gui = read_gui(gisrc, default_gui)
+ # check that the GUI works but only if not doing a batch job
grass_gui = check_gui(expected_gui=grass_gui)
+ # save GUI only if we are not doibg batch job
save_gui(gisrc, grass_gui)
# Parsing argument to get LOCATION
@@ -1657,15 +1688,20 @@
set_mapset_interactive(grass_gui)
else:
if params.create_new and params.geofile:
- set_mapset(params.mapset, params.geofile, create_new=True)
+ set_mapset(gisrc=gisrc, arg=params.mapset,
+ geofile=params.geofile, create_new=True)
else:
- set_mapset(params.mapset, create_new=params.create_new)
+ create_new=params.create_new)
# Set GISDBASE, LOCATION_NAME, MAPSET, LOCATION from $GISRC
# e.g. wxGUI startup screen writes to the gisrc file,
# so loading it is the only universal way to obtain the values
# this suppose that both programs share the right path to gisrc file
-mapset_settings = load_gisrc(gisrc)
+# TODO: perhaps gisrcrc should be removed from here
+# alternatively, we can check validity here with all the info we have
+# about what was used to create gisrc
+mapset_settings = load_gisrc(gisrc, gisrcrc=gisrcrc)
gisdbase = mapset_settings.gisdbase
location_name = mapset_settings.location
@@ -1677,8 +1713,9 @@
cleaner.mapset_path = mapset_settings.full_mapset
# check and create .gislock file
-cleaner.lockfile = lock_mapset(mapset_settings.full_mapset,
- params.force_gislock_removal)
+cleaner.lockfile = lock_mapset(
+ mapset_settings.full_mapset, user=user,
+ force_gislock_removal=params.force_gislock_removal)
# build user fontcap if specified but not present
make_fontcap()
@@ -1700,7 +1737,8 @@
clear_screen()
show_banner()
say_hello()
- show_info()
+ show_info(shellname=shellname,
+ grass_gui=grass_gui, default_gui=default_gui)
if grass_gui == "wxpython":
message(_("Launching <%s> GUI in the background, please wait...") % grass_gui)
if sh in ['csh', 'tcsh']:
