[GRASS-SVN] r65288 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue May 19 12:17:22 PDT 2015
Author: wenzeslaus
Date: 2015-05-19 12:17:22 -0700 (Tue, 19 May 2015)
New Revision: 65288
grass/trunk/lib/init/grass.py
init: introduce main function, remove most of the global vars
Add docstrings. Use better names where change was trivial.
Code related to gisbase and language would still use some improvements.
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-05-19 17:47:43 UTC (rev 65287)
+++ grass/trunk/lib/init/grass.py 2015-05-19 19:17:22 UTC (rev 65288)
@@ -26,6 +26,17 @@
+Script to run GRASS session.
+Some of the functions could be used separately but import from this module
+is not safe, i.e. it has side effects (this should be changed in the future).
+# we allow for long file because we want to avoid imports if possible
+# (this makes it more stable since we have to set up paths first)
+# pylint: disable=too-many-lines
import sys
import os
import atexit
@@ -55,10 +66,7 @@
# TODO: is this needed or even desirable when we have set_language()?
gettext.install('grasslibs', os.path.join(gisbase, 'locale'))
-location = None
-grass_gui = None
def warning(text):
sys.stderr.write(_("WARNING") + ': ' + text + os.linesep)
@@ -178,12 +186,14 @@
def call(cmd, **kwargs):
+ """Wrapper for subprocess.call to deal with platform-specific issues"""
if windows:
kwargs['shell'] = True
return subprocess.call(cmd, **kwargs)
-def Popen(cmd, **kwargs):
+def Popen(cmd, **kwargs): # pylint: disable=C0103
+ """Wrapper for subprocess.Popen to deal with platform-specific issues"""
if windows:
return subprocess.Popen(cmd, **kwargs)
@@ -306,14 +316,21 @@
def get_grass_config_dir():
"""Get configuration directory
- Used also for grass env file (the non-session one)
+ Determines path of GRASS GIS user configuration directory and creates
+ it if it does not exist.
+ Configuration directory is for example used for grass env file
+ (the one which caries mapset settings from session to session).
if sys.platform == 'win32':
grass_config_dirname = "GRASS7"
- return os.path.join(os.getenv('APPDATA'), grass_config_dirname)
+ directory = os.path.join(os.getenv('APPDATA'), grass_config_dirname)
else:
grass_config_dirname = ".grass7"
- return os.path.join(os.getenv('HOME'), grass_config_dirname)
+ directory = os.path.join(os.getenv('HOME'), grass_config_dirname)
+ if not os.path.exists(directory):
+ os.mkdir(directory)
+ return directory
def create_tmp(user, gis_lock):
@@ -435,8 +452,8 @@
def read_gui(gisrc, default_gui):
grass_gui = None
# At this point the GRASS user interface variable has been set from the
- # command line, been set from an external environment variable, or is
- # not set. So we check if it is not set
+ # command line, been set from an external environment variable,
+ # or is not set. So we check if it is not set
# Check for a reference to the GRASS user interface in the grassrc file
if os.access(gisrc, os.R_OK):
kv = read_gisrc(gisrc)
@@ -465,21 +482,21 @@
return grass_gui
-def path_prepend(dir, var):
+def path_prepend(directory, var):
path = os.getenv(var)
if path:
- path = dir + os.pathsep + path
+ path = directory + os.pathsep + path
else:
- path = dir
+ path = directory
os.environ[var] = path
-def path_append(dir, var):
+def path_append(directory, var):
if path:
- path = path + os.pathsep + dir
+ path = path + os.pathsep + directory
else:
- path = dir
+ path = directory
@@ -498,7 +515,7 @@
if not windows:
path_prepend(os.path.join(addon_base, 'scripts'), 'PATH')
path_prepend(os.path.join(addon_base, 'bin'), 'PATH')
# standard installation
if not windows:
path_prepend(gpath('scripts'), 'PATH')
@@ -543,8 +560,8 @@
def find_exe(pgm):
- for dir in os.getenv('PATH').split(os.pathsep):
- path = os.path.join(dir, pgm)
+ for directory in os.getenv('PATH').split(os.pathsep):
+ path = os.path.join(directory, pgm)
if os.access(path, os.X_OK):
return path
return None
@@ -679,8 +696,7 @@
def save_gui(gisrc, grass_gui):
- # Save the user interface variable in the grassrc file - choose a temporary
- # file name that should not match another file
+ """Save the user interface variable in the grassrc file"""
if os.access(gisrc, os.F_OK):
kv['GUI'] = grass_gui
@@ -714,8 +730,8 @@
# create location using georeferenced file
gcore.create_location(gisdbase, location,
filename=geostring)
- except gcore.ScriptError as e:
- fatal(e.value.strip('"').strip("'").replace('\\n', os.linesep))
+ except gcore.ScriptError as err:
+ fatal(err.value.strip('"').strip("'").replace('\\n', os.linesep))
# interface created according to the current usage
@@ -731,7 +747,7 @@
:param location: name of a Location
return os.access(os.path.join(gisdbase, location,
- "PERMANENT", "DEFAULT_WIND"), os.F_OK)
+ "PERMANENT", "DEFAULT_WIND"), os.F_OK)
# basically checking location, possibly split into two functions
@@ -767,18 +783,27 @@
def set_mapset(gisrc, arg, geofile=None, create_new=False):
"""Selected Location and Mapset are checked and created if requested
- The gisrc (GRASS environment file) is written at the end.
+ The gisrc (GRASS environment file) is written at the end
+ (nothing is returned).
- # TODO: it does not seem that these would be ever set before calling this
- # function, so we may just delete them here (the globals are set from
- # the gisrc later on). But where is setting from environmental variables?
- global gisdbase, location_name, mapset, location
- # Try non-interactive startup
l = None
if arg == '-':
- if location:
- l = location
+ # TODO: repair or remove behavior env vars + `grass71 -` (see doc)
+ # this is broken for some time (before refactoring, e.g. r65235)
+ # is some code is added, it should be a separate function, probably
+ # called here
+ # older comment for global vars:
+ # TODO: it does not seem that these would be ever set before calling this
+ # function, so we may just delete them here (the globals are set from
+ # the gisrc later on). But where is setting from environmental variables?
+ # the following probable means if env var defined, use it
+ # originates from r37863 (Convert grass70 script to Python) but even
+ # there it seems that it will never succeed
+ # it would have to be defined also for other vars
+ # if location:
+ # l = location
+ pass
else:
l = arg
@@ -793,7 +818,7 @@
l, mapset = os.path.split(l)
l, location_name = os.path.split(l)
gisdbase = l
if gisdbase and location_name and mapset:
location = os.path.join(gisdbase, location_name, mapset)
@@ -847,6 +872,9 @@
# Check for text interface
if grass_gui == 'text':
+ # TODO: maybe this should be removed and solved from outside
+ # this depends on what we expect from this function
+ # should gisrc be ok after running or is it allowed to be still not set
pass
# Check for GUI
elif grass_gui in ('gtext', 'wxpython'):
@@ -858,6 +886,7 @@
def gui_startup(grass_gui):
+ """Start GUI for startup (setting gisrc file)"""
if grass_gui in ('wxpython', 'gtext'):
ret = call([os.getenv('GRASS_PYTHON'), wxpath("gis_set.py")])
@@ -907,6 +936,7 @@
self.mapset)
return self._full_mapset
+ # TODO: perhaps conversion to bool would be nicer
def is_valid(self):
return self.gisdbase and self.location and self.mapset
@@ -971,10 +1001,10 @@
# See discussion for Windows not following its own documentation and
# not accepting ISO codes as valid locale identifiers http://bugs.python.org/issue10466
import locale
language = 'None' # Such string sometimes is present in wx file
encoding = None
# Override value is stored in wxGUI preferences file.
# As it's the only thing required, we'll just grep it out.
try:
@@ -1003,12 +1033,12 @@
print "System locale is not usable. It indicates misconfigured environment."
print "Reported error message: %s" % e
sys.exit("Fix system locale settings and then try again.")
language, encoding = locale.getdefaultlocale()
if not language:
warning(_("Default locale settings are missing. GRASS running with C locale."))
return
else:
debug("A language override has been requested."
" Trying to switch GRASS into '%s'..." % language)
@@ -1040,7 +1070,7 @@
# language
os.environ['LANGUAGE'] = language
return
# Set up environment for subprocesses
os.environ['LANG'] = language
@@ -1059,7 +1089,7 @@
os.environ['LC_NUMERIC'] = 'C'
if os.getenv('LC_ALL'):
del os.environ['LC_ALL'] # Remove LC_ALL to not override LC_NUMERIC
# From now on enforce the new language
if encoding:
gettext.install('grasslibs', gpath('locale'), codeset=encoding)
@@ -1067,7 +1097,13 @@
gettext.install('grasslibs', gpath('locale'))
-def lock_mapset(mapset_path, force_gislock_removal, user):
+# TODO: grass_gui parameter is a hack and should be removed, see below
+def lock_mapset(mapset_path, force_gislock_removal, user, grass_gui):
+ """Lock the mapset and return name of the lock file
+ Behavior on error must be changed somehow; now it fatals but GUI case is
+ unresolved.
if not os.path.exists(mapset_path):
fatal(_("Path '%s' doesn't exist") % mapset_path)
# Check for concurrent use
@@ -1105,6 +1141,7 @@
def make_fontcap():
+ # TODO: is GRASS_FONT_CAP ever defined? It seems it must be defined in system
fc = os.getenv('GRASS_FONT_CAP')
if fc and not os.access(fc, os.R_OK):
message(_("Building user fontcap..."))
@@ -1144,10 +1181,10 @@
except:
sh = 'sh'
os.environ['SHELL'] = sh
if windows and sh:
sh = os.path.splitext(sh)[0]
if sh == "ksh":
shellname = "Korn Shell"
elif sh == "csh":
@@ -1171,6 +1208,7 @@
def get_grass_env_file(sh, grass_config_dir):
+ """Get name of the shell-specific GRASS environment (rc) file"""
if sh in ['csh', 'tcsh']:
grass_env_file = os.path.join(grass_config_dir, 'cshrc')
elif sh in ['bash', 'msh', 'cygwin', 'sh']:
@@ -1187,6 +1225,10 @@
def get_batch_job_from_env_variable():
+ """Get script to execute from batch job variable if available
+ Fails with fatal if variable is set but content unusable.
# hack to process batch jobs:
batch_job = os.getenv('GRASS_BATCH_JOB')
# variable defined, but user might not have been careful enough
@@ -1206,6 +1248,12 @@
def run_batch_job(batch_job):
+ """Runs script, module or any command
+ If *batch_job* is a string (insecure) shell=True is used for execution.
+ :param batch_job: executable and parameters in a list or a string
batch_job_string = batch_job
if not isinstance(batch_job, basestring):
batch_job_string = ' '.join(batch_job)
@@ -1224,6 +1272,10 @@
def start_gui(grass_gui):
+ """Start specified GUI
+ :param grass_gui: GUI name (allowed values: 'wxpython')
# Start the chosen GUI but ignore text
debug("GRASS GUI should be <%s>" % grass_gui)
@@ -1233,7 +1285,7 @@
def clear_screen():
- global windows
+ """Clear terminal"""
if windows:
pass
# TODO: uncomment when PDCurses works.
@@ -1244,6 +1296,7 @@
def show_banner():
+ """Write GRASS GIS ASCII name to stderr"""
sys.stderr.write(r"""
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
@@ -1255,19 +1308,22 @@
def say_hello():
+ """Write welcome to stderr including Subversion revision if in svn copy"""
sys.stderr.write(_("Welcome to GRASS GIS %s") % grass_version)
if grass_version.endswith('svn'):
try:
filerev = open(gpath('etc', 'VERSIONNUMBER'))
linerev = filerev.readline().rstrip('\n')
filerev.close()
revision = linerev.split(' ')[1]
sys.stderr.write(' (' + revision + ')')
except:
pass
def show_info(shellname, grass_gui, default_gui):
+ """Write basic infor about GRASS GIS and GRASS session to stderr"""
sys.stderr.write(
r"""
%-41shttp://grass.osgeo.org
@@ -1279,12 +1335,12 @@
shellname, os.getenv('SHELL'),
_("Help is available with the command:"),
_("See the licence terms with:")))
if grass_gui == 'wxpython':
message("%-41sg.gui wxpython" % _("If required, restart the GUI with:"))
else:
message("%-41sg.gui %s" % (_("Start the GUI with:"), default_gui))
message("%-41sexit" % _("When ready to quit enter:"))
message("")
@@ -1361,7 +1417,7 @@
f.write("PS1='ISIS-GRASS %s (%s):\w > '\n" % (grass_version, location_name))
else:
f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
f.write("""grass_prompt() {
LOCATION="`g.gisenv get=GISDBASE,LOCATION_NAME,MAPSET separator='/'`"
if test -d "$LOCATION/grid3/G3D_MASK" && test -f "$LOCATION/cell/MASK" ; then
@@ -1427,12 +1483,18 @@
nul.close()
-def grep(string,list):
- expr = re.compile(string)
- return [elem for elem in list if expr.match(elem)]
+def grep(pattern, lines):
+ """Search lines (list of strings) and return them when beginning matches.
+ >>> grep("a", ['abc', 'cab', 'sdr', 'aaa', 'sss'])
+ ['abc', 'aaa']
+ expr = re.compile(pattern)
+ return [elem for elem in lines if expr.match(elem)]
def print_params():
+ """Write compile flags and other configuration to stderr"""
plat = gpath('include', 'Make', 'Platform.make')
if not os.path.exists(plat):
fatal(_("Please install the GRASS GIS development package"))
@@ -1443,7 +1505,7 @@
params = sys.argv[2:]
if not params:
params = ['arch', 'build', 'compiler', 'path', 'revision']
for arg in params:
if arg == 'path':
sys.stdout.write("%s\n" % gisbase)
@@ -1493,7 +1555,8 @@
return user
-class Parameters:
+class Parameters(object):
+ """Structure to hold standard part of command line parameters"""
# we don't need to define any methods
# pylint: disable=R0903
def __init__(self):
@@ -1506,6 +1569,7 @@
def parse_cmdline(argv, default_gui):
+ """Parse the standard part of command line parameters"""
params = Parameters()
args = []
for i in argv:
@@ -1571,191 +1635,202 @@
# Set GISBASE
os.environ['GISBASE'] = gisbase
-# Set default GUI
-default_gui = "wxpython"
-# explain what is happening in debug mode
-debug("GRASS_DEBUG environmental variable is set. It is meant to be"
- " an internal variable for debugging only this script.\n"
- " Use 'g.gisenv set=\"DEBUG=[0-5]\"'"
- " to turn GRASS GIS debug mode on if you wish to do so.")
+def main():
+ """The main function which does the whole setup and run procedure
-# Set GRASS version number for R interface etc (must be an env_var for MS-Windows)
-os.environ['GRASS_VERSION'] = grass_version
+ Only few things are set on the module level.
+ # Set default GUI
+ default_gui = "wxpython"
-# Set the GIS_LOCK variable to current process id
-gis_lock = str(os.getpid())
-os.environ['GIS_LOCK'] = gis_lock
+ # explain what is happening in debug mode (visible only in debug mode)
+ debug("GRASS_DEBUG environmental variable is set. It is meant to be"
+ " an internal variable for debugging only this script.\n"
+ " Use 'g.gisenv set=\"DEBUG=[0-5]\"'"
+ " to turn GRASS GIS debug mode on if you wish to do so.")
-grass_config_dir = get_grass_config_dir()
-if not os.path.exists(grass_config_dir):
- os.mkdir(grass_config_dir)
+ # Set GRASS version number for R interface etc
+ # (must be an env var for MS Windows)
+ os.environ['GRASS_VERSION'] = grass_version
-batch_job = get_batch_job_from_env_variable()
+ # Set the GIS_LOCK variable to current process id
+ gis_lock = str(os.getpid())
+ os.environ['GIS_LOCK'] = gis_lock
-# Parse the command-line options and set several global variables
-BATCH_EXEC_SUBCOMMAND = 'exec'
+ grass_config_dir = get_grass_config_dir()
-try:
- # raises ValueError when not found
- index = sys.argv.index(BATCH_EXEC_SUBCOMMAND)
- batch_job = sys.argv[index + 1:]
- clean_argv = sys.argv[1:index]
- params = parse_cmdline(clean_argv, default_gui=default_gui)
-except ValueError:
- params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
+ batch_job = get_batch_job_from_env_variable()
-if params.exit_grass and not params.create_new:
- fatal(_("Flag -e requires also flag -c"))
+ # Parse the command-line options and set several global variables
+ batch_exec_subcommand = 'exec'
+ try:
+ # raises ValueError when not found
+ index = sys.argv.index(batch_exec_subcommand)
+ batch_job = sys.argv[index + 1:]
+ clean_argv = sys.argv[1:index]
+ params = parse_cmdline(clean_argv, default_gui=default_gui)
+ except ValueError:
+ params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
+ if params.exit_grass and not params.create_new:
+ fatal(_("Flag -e requires also flag -c"))
-grass_gui = params.grass_gui
+ grass_gui = params.grass_gui # put it to variable, it is used a lot
-gisrcrc = get_gisrc_from_config_dir(grass_config_dir, batch_job)
+ gisrcrc = get_gisrc_from_config_dir(grass_config_dir, batch_job)
-# Set the username
-user = get_username()
+ # Set the username
+ user = get_username()
-# TODO: this might need to be moved before processing of parameters and getting batch job
-# Set language
-# This has to be called before any _() function call!
-# Subsequent functions are using _() calls and
-# thus must be called only after Language has been set.
-set_language(grass_config_dir)
+ # TODO: this might need to be moved before processing of parameters and getting batch job
+ # Set language
+ # This has to be called before any _() function call!
+ # Subsequent functions are using _() calls and
+ # thus must be called only after Language has been set.
+ set_language(grass_config_dir)
-# Create the temporary directory and session grassrc file
-tmpdir = create_tmp(user, gis_lock)
+ # Create the temporary directory and session grassrc file
+ tmpdir = create_tmp(user, gis_lock)
-cleaner = Cleaner()
-cleaner.tmpdir = tmpdir
-# object is not destroyed when its method is registered
-atexit.register(cleaner.cleanup)
+ cleaner = Cleaner()
+ cleaner.tmpdir = tmpdir
+ # object is not destroyed when its method is registered
+ atexit.register(cleaner.cleanup)
-# Create the session grassrc file
-gisrc = create_gisrc(tmpdir, gisrcrc)
+ # Create the session grassrc file
+ gisrc = create_gisrc(tmpdir, gisrcrc)
-# Set shell (needs to be called before load_env())
-sh, shellname = get_shell()
-grass_env_file = get_grass_env_file(sh, grass_config_dir)
+ # Set shell (needs to be called before load_env())
+ sh, shellname = get_shell()
+ grass_env_file = get_grass_env_file(sh, grass_config_dir)
-# Load environmental variables from the file
-load_env(grass_env_file)
+ # Load environmental variables from the file
+ load_env(grass_env_file)
-ensure_home()
-# Set PATH, PYTHONPATH, ...
-set_paths(grass_config_dir=grass_config_dir)
-# Set GRASS_PAGER, GRASS_PYTHON, GRASS_GNUPLOT, GRASS_PROJSHARE
-set_defaults()
-set_display_defaults()
-# Set GRASS_HTML_BROWSER
-set_browser()
+ ensure_home()
+ # Set PATH, PYTHONPATH, ...
+ set_paths(grass_config_dir=grass_config_dir)
+ # Set GRASS_PAGER, GRASS_PYTHON, GRASS_GNUPLOT, GRASS_PROJSHARE
+ set_defaults()
+ set_display_defaults()
+ # Set GRASS_HTML_BROWSER
+ set_browser()
-# First time user - GISRC is defined in the GRASS script
-if not os.access(gisrc, os.F_OK):
- if grass_gui == 'text' and not params.mapset:
- fatal(_("Unable to start GRASS GIS. You have the choice to:\n"
- " - Launch the GRASS GIS interface with the '-gui' switch (`%s -gui`)\n"
- " - Launch GRASS GIS directly with path to "
- "the location/mapset as an argument (`%s /path/to/location/mapset`)\n"
- " - Create manually the GISRC file (%s)") % (cmd_name, cmd_name, gisrcrc))
- create_initial_gisrc(gisrc)
-else:
- # clean only for user who is no first time
- # (measured by presence of rc file)
- clean_temp()
+ # First time user - GISRC is defined in the GRASS script
+ if not os.access(gisrc, os.F_OK):
+ if grass_gui == 'text' and not params.mapset:
+ fatal(_("Unable to start GRASS GIS. You have the choice to:\n"
+ " - Launch the GRASS GIS interface with"
+ " the '-gui' switch (`{cmd_name} -gui`)\n"
+ " - Launch GRASS GIS directly with path to "
+ "the location/mapset as an argument"
+ " (`{cmd_name} /path/to/location/mapset`)\n"
+ " - Create manually the GISRC file ({gisrcrc})").format(
+ cmd_name=cmd_name, gisrcrc=gisrcrc))
+ create_initial_gisrc(gisrc)
+ else:
+ # clean only for user who is no first time
+ # (measured by presence of rc file)
+ clean_temp()
-if params.create_new:
- message(_("Creating new GRASS GIS location/mapset..."))
-else:
- message(_("Starting GRASS GIS..."))
+ if params.create_new:
+ message(_("Creating new GRASS GIS location/mapset..."))
+ else:
+ message(_("Starting GRASS GIS..."))
-# Ensure GUI is set
-if batch_job:
- grass_gui = 'text'
-else:
- if not grass_gui:
- # if GUI was not set previously (e.g. command line),
- # get it from rc file or env variable
- grass_gui = read_gui(gisrc, default_gui)
- # check that the GUI works but only if not doing a batch job
- grass_gui = check_gui(expected_gui=grass_gui)
- # save GUI only if we are not doibg batch job
- save_gui(gisrc, grass_gui)
+ # Ensure GUI is set
+ if batch_job:
+ grass_gui = 'text'
+ else:
+ if not grass_gui:
+ # if GUI was not set previously (e.g. command line),
+ # get it from rc file or env variable
+ grass_gui = read_gui(gisrc, default_gui)
+ # check that the GUI works but only if not doing a batch job
+ grass_gui = check_gui(expected_gui=grass_gui)
+ # save GUI only if we are not doibg batch job
+ save_gui(gisrc, grass_gui)
-# Parsing argument to get LOCATION
-if not params.mapset:
- # Try interactive startup
- # User selects LOCATION and MAPSET if not set
- set_mapset_interactive(grass_gui)
-else:
- if params.create_new and params.geofile:
- set_mapset(gisrc=gisrc, arg=params.mapset,
- geofile=params.geofile, create_new=True)
+ # Parsing argument to get LOCATION
+ if not params.mapset:
+ # Try interactive startup
+ # User selects LOCATION and MAPSET if not set
+ set_mapset_interactive(grass_gui)
else:
- create_new=params.create_new)
+ # Try non-interactive start up
+ if params.create_new and params.geofile:
+ set_mapset(gisrc=gisrc, arg=params.mapset,
+ geofile=params.geofile, create_new=True)
+ else:
+ create_new=params.create_new)
-# Set GISDBASE, LOCATION_NAME, MAPSET, LOCATION from $GISRC
-# e.g. wxGUI startup screen writes to the gisrc file,
-# so loading it is the only universal way to obtain the values
-# this suppose that both programs share the right path to gisrc file
-# TODO: perhaps gisrcrc should be removed from here
-# alternatively, we can check validity here with all the info we have
-# about what was used to create gisrc
-mapset_settings = load_gisrc(gisrc, gisrcrc=gisrcrc)
+ # Set GISDBASE, LOCATION_NAME, MAPSET, LOCATION from $GISRC
+ # e.g. wxGUI startup screen writes to the gisrc file,
+ # so loading it is the only universal way to obtain the values
+ # this suppose that both programs share the right path to gisrc file
+ # TODO: perhaps gisrcrc should be removed from here
+ # alternatively, we can check validity here with all the info we have
+ # about what was used to create gisrc
+ mapset_settings = load_gisrc(gisrc, gisrcrc=gisrcrc)
-gisdbase = mapset_settings.gisdbase
-location_name = mapset_settings.location
-mapset = mapset_settings.mapset
-location = mapset_settings.full_mapset
+ location = mapset_settings.full_mapset
-# TODO: it seems that we are claiming mapset's tmp before locking
-# (this is what the original code did but it is probably wrong)
-cleaner.mapset_path = mapset_settings.full_mapset
+ # TODO: it seems that we are claiming mapset's tmp before locking
+ # (this is what the original code did but it is probably wrong)
+ cleaner.mapset_path = mapset_settings.full_mapset
-# check and create .gislock file
-cleaner.lockfile = lock_mapset(
- mapset_settings.full_mapset, user=user,
- force_gislock_removal=params.force_gislock_removal)
+ # check and create .gislock file
+ cleaner.lockfile = lock_mapset(
+ mapset_settings.full_mapset, user=user,
+ force_gislock_removal=params.force_gislock_removal,
+ grass_gui=grass_gui)
-# build user fontcap if specified but not present
-make_fontcap()
+ # build user fontcap if specified but not present
+ make_fontcap()
-# TODO: is this really needed? Modules should call this when/if required.
-ensure_db_connected(location)
+ # TODO: is this really needed? Modules should call this when/if required.
+ ensure_db_connected(location)
-# Display the version and license info
-# only non-error, interactive version continues from here
-if batch_job:
- returncode = run_batch_job(batch_job)
- clean_temp()
- sys.exit(returncode)
-elif params.exit_grass:
- clean_temp()
- sys.exit(0)
-else:
- start_gui(grass_gui)
- clear_screen()
- show_banner()
- say_hello()
- show_info(shellname=shellname,
- grass_gui=grass_gui, default_gui=default_gui)
- if grass_gui == "wxpython":
- message(_("Launching <%s> GUI in the background, please wait...") % grass_gui)
- if sh in ['csh', 'tcsh']:
- csh_startup(mapset_settings.full_mapset, mapset_settings.location,
- mapset_settings.mapset, grass_env_file)
- elif sh in ['bash', 'msh', 'cygwin']:
- bash_startup(mapset_settings.full_mapset, mapset_settings.location,
- grass_env_file)
+ # Display the version and license info
+ # only non-error, interactive version continues from here
+ if batch_job:
+ returncode = run_batch_job(batch_job)
+ clean_temp()
+ sys.exit(returncode)
+ elif params.exit_grass:
+ clean_temp()
+ sys.exit(0)
else:
- default_startup(mapset_settings.full_mapset, mapset_settings.location)
- # here we are at the end of grass session
- clear_screen()
- # TODO: can we just register this atexit?
- # TODO: and what is difference to deleting .tmp which we do?
- clean_temp()
- # save 'last used' GISRC after removing variables which shouldn't be saved
- clean_env(gisrc)
- writefile(gisrcrc, readfile(gisrc))
- # After this point no more grass modules may be called
- done_message()
+ start_gui(grass_gui)
+ clear_screen()
+ show_banner()
+ say_hello()
+ show_info(shellname=shellname,
+ grass_gui=grass_gui, default_gui=default_gui)
+ if grass_gui == "wxpython":
+ message(_("Launching <%s> GUI in the background, please wait...")
+ % grass_gui)
+ if sh in ['csh', 'tcsh']:
+ csh_startup(mapset_settings.full_mapset, mapset_settings.location,
+ mapset_settings.mapset, grass_env_file)
+ elif sh in ['bash', 'msh', 'cygwin']:
+ bash_startup(mapset_settings.full_mapset, mapset_settings.location,
+ grass_env_file)
+ else:
+ default_startup(mapset_settings.full_mapset,
+ mapset_settings.location)
+ # here we are at the end of grass session
+ clear_screen()
+ # TODO: can we just register this atexit?
+ # TODO: and what is difference to deleting .tmp which we do?
+ clean_temp()
+ # save 'last used' GISRC after removing variables which shouldn't
+ # be saved, e.g. d.mon related
+ clean_env(gisrc)
+ writefile(gisrcrc, readfile(gisrc))
+ # After this point no more grass modules may be called
+ done_message()
+if __name__ == '__main__':
+ main()
