[GRASS-SVN] r65295 -	grass/branches/releasebranch_7_0/gui/wxpython/modules
    svn_grass at osgeo.org
    Wed May 20 18:29:22 PDT 2015
Author: annakrat
Date: 2015-05-20 18:29:22 -0700 (Wed, 20 May 2015)
New Revision: 65295
   grass/branches/releasebranch_7_0/gui/wxpython/modules/mapsets_picker.py
g.mapsets: dialog must be destroyed, app.MainLoop seems not necessary here; remove unused imports, whitespace clean up (merge from trunk, r65291)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/mapsets_picker.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/mapsets_picker.py	2015-05-20 17:50:26 UTC (rev 65294)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/mapsets_picker.py	2015-05-21 01:29:22 UTC (rev 65295)
@@ -1,33 +1,27 @@
 #!/usr/bin/env python
-import os
-import sys
-import pwd
-from grass.script import core as grass
 import wx
-import wx.lib.mixins.listctrl as listmix
-from core.gcmd import RunCommand
+from core.gcmd import RunCommand
 from core.utils import _, GuiModuleMain
 from gui_core.preferences import MapsetAccess
 def main():
     app = wx.App()
     dlg = MapsetAccess(parent = None)
     dlg.CenterOnScreen()
     if dlg.ShowModal() == wx.ID_OK:
         ms = dlg.GetMapsets()
         RunCommand('g.mapsets',
                    parent = None,
                    mapset = '%s' % ','.join(ms),
                    operation = 'set')
-    app.MainLoop()
+    dlg.Destroy()
 if __name__ == "__main__":
     GuiModuleMain(main)
