[GRASS-SVN] r65298 - in grass/trunk/display: d.linegraph d.rast.num d.vect
svn_grass at osgeo.org
Thu May 21 02:25:50 PDT 2015
Author: marisn
Date: 2015-05-21 02:25:49 -0700 (Thu, 21 May 2015)
New Revision: 65298
grass/trunk/display/d.linegraph/main.c
grass/trunk/display/d.rast.num/main.c
grass/trunk/display/d.vect/area.c
grass/trunk/display/d.vect/lines.c
grass/trunk/display/d.vect/main.c
Rename _n macro to n_ to avoid clashes with other libs (as sugested in dev ML) (some missed files in r65297)
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2015-05-21 09:23:11 UTC (rev 65297)
+++ grass/trunk/display/d.linegraph/main.c 2015-05-21 09:25:49 UTC (rev 65298)
@@ -314,7 +314,7 @@
if (in[i].num_pnts > in[0].num_pnts)
- G_message(_n("The last point will be ignored",
+ G_message(n_("The last point will be ignored",
"The last %d points will be ignored",
(in[i].num_pnts - in[0].num_pnts)),
(in[i].num_pnts - in[0].num_pnts));
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c 2015-05-21 09:23:11 UTC (rev 65297)
+++ grass/trunk/display/d.rast.num/main.c 2015-05-21 09:25:49 UTC (rev 65298)
@@ -196,8 +196,8 @@
/* number of rows and cols in window */
if ((nrows > 75) || (ncols > 75)) {
- G_asprintf(&tmpstr1, _n("%d row", "%d rows", nrows), nrows);
- G_asprintf(&tmpstr2, _n("%d col", "%d cols", ncols), ncols);
+ G_asprintf(&tmpstr1, n_("%d row", "%d rows", nrows), nrows);
+ G_asprintf(&tmpstr2, n_("%d col", "%d cols", ncols), ncols);
/* GTC %s will be replaced by strings "X rows" and "Y cols" */
G_warning(_("Current region size: %s X %s\n"
"Your current region setting may be too large. "
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2015-05-21 09:23:11 UTC (rev 65297)
+++ grass/trunk/display/d.vect/area.c 2015-05-21 09:25:49 UTC (rev 65298)
@@ -233,7 +233,7 @@
if ((colors || cvarr_rgb) && get_num_color_rules_skipped() > 0)
- G_warning(_n("%d invalid color rule for areas skipped",
+ G_warning(n_("%d invalid color rule for areas skipped",
"%d invalid color rules for areas skipped",
get_num_color_rules_skipped()),
get_num_color_rules_skipped());
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c 2015-05-21 09:23:11 UTC (rev 65297)
+++ grass/trunk/display/d.vect/lines.c 2015-05-21 09:25:49 UTC (rev 65298)
@@ -166,21 +166,21 @@
- G_warning(_n("%d invalid color rule for lines skipped",
+ G_warning(n_("%d invalid color rule for lines skipped",
"%d invalid color rules for lines skipped",
if (n_points > 0)
- G_verbose_message(_n("%d point plotted", "%d points plotted", n_points), n_points);
+ G_verbose_message(n_("%d point plotted", "%d points plotted", n_points), n_points);
if (n_lines > 0)
- G_verbose_message(_n("%d line plotted", "%d lines plotted", n_lines), n_lines);
+ G_verbose_message(n_("%d line plotted", "%d lines plotted", n_lines), n_lines);
if (n_centroids > 0)
- G_verbose_message(_n("%d centroid plotted", "%d centroids plotted", n_centroids), n_centroids);
+ G_verbose_message(n_("%d centroid plotted", "%d centroids plotted", n_centroids), n_centroids);
if (n_boundaries > 0)
- G_verbose_message(_n("%d boundary plotted", "%d boundaries plotted", n_boundaries), n_boundaries);
+ G_verbose_message(n_("%d boundary plotted", "%d boundaries plotted", n_boundaries), n_boundaries);
if (n_faces > 0)
- G_verbose_message(_n("%d face plotted", "%d faces plotted", n_faces), n_faces);
+ G_verbose_message(n_("%d face plotted", "%d faces plotted", n_faces), n_faces);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2015-05-21 09:23:11 UTC (rev 65297)
+++ grass/trunk/display/d.vect/main.c 2015-05-21 09:25:49 UTC (rev 65298)
@@ -364,7 +364,7 @@
chcat = 1;
ret = Vect_str_to_cat_list(cat_opt->answer, Clist);
if (ret > 0)
- G_warning(_n("%d error in cat option", "%d errors in cat option", ret), ret);
+ G_warning(n_("%d error in cat option", "%d errors in cat option", ret), ret);
type = Vect_option_to_types(type_opt);
