[GRASS-SVN] r65300 - grass/trunk/display/d.mon
Thu May 21 10:39:23 PDT 2015
Author: martinl
Date: 2015-05-21 10:39:23 -0700 (Thu, 21 May 2015)
New Revision: 65300
   grass/trunk/display/d.mon/render_cmd.py
   grass/trunk/display/d.mon/start.c
d.mon: avoid doubled rendering for standalone wx monitors
Modified: grass/trunk/display/d.mon/render_cmd.py
--- grass/trunk/display/d.mon/render_cmd.py	2015-05-21 16:34:20 UTC (rev 65299)
+++ grass/trunk/display/d.mon/render_cmd.py	2015-05-21 17:39:23 UTC (rev 65300)
@@ -1,6 +1,7 @@
 #!/usr/bin/env python
 import os
 import sys
+import tempfile
 from grass.script import core as grass
 from grass.script import task as gtask
@@ -29,14 +30,16 @@
     return width, height
 # run display command
-def render(cmd):
+def render(cmd, mapfile):
+    env = os.environ.copy()
+    env['GRASS_RENDER_FILE'] = mapfile
     try:
-        grass.run_command(cmd[0], **cmd[1])
+        grass.run_command(cmd[0], env=env, **cmd[1])
     except Exception as e:
         grass.fatal("Unable to render: {}".format(e))
 # update cmd file
-def update_cmd_file(cmd_file, cmd):
+def update_cmd_file(cmd_file, cmd, mapfile):
     if cmd[0] in ('d.colorlist', 'd.font', 'd.fontlist',
                   'd.frame', 'd.info', 'd.mon', 'd.out.file',
                   'd.redraw', 'd.to.rast', 'd.what.rast',
@@ -49,6 +52,7 @@
     if fd is None:
         grass.fatal("Unable to open file '{}'".format(cmd_file))
     if mode == 'a':
+        fd.write('# GRASS_RENDER_FILE={}\n'.format(mapfile))
         fd.write(' '.join(gtask.cmdtuple_to_list(cmd)))
         fd.write('\n')
     else:
@@ -95,8 +99,9 @@
     width, height = read_env_file(os.path.join(path, 'env'))
     if not mon.startswith('wx'):
         adjust_region(width, height)
-    render(cmd)
-    update_cmd_file(os.path.join(path, 'cmd'), cmd)
+    mapfile = tempfile.NamedTemporaryFile(dir=path).name + '.ppm'
+    render(cmd, mapfile)
+    update_cmd_file(os.path.join(path, 'cmd'), cmd, mapfile)
     sys.exit(0)
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2015-05-21 16:34:20 UTC (rev 65299)
+++ grass/trunk/display/d.mon/start.c	2015-05-21 17:39:23 UTC (rev 65300)
@@ -153,16 +153,23 @@
     if (fd < 0)
 	G_fatal_error(_("Unable to create file <%s>"), env_file);
-    if (G_strncasecmp(name, "wx", 2) == 0)
+    if (G_strncasecmp(name, "wx", 2) == 0) {
         sprintf(buf, "GRASS_RENDER_IMMEDIATE=default\n"); /* TODO: read settings from wxGUI */
-    else
+        write(fd, buf, strlen(buf));
+        sprintf(buf, "GRASS_RENDER_FILE_READ=FALSE\n");
+        sprintf(buf, "GRASS_RENDER_TRANSPARENT=TRUE\n");
+    else {
         sprintf(buf, "GRASS_RENDER_IMMEDIATE=%s\n", name);
-    write(fd, buf, strlen(buf));
+        sprintf(buf, "GRASS_RENDER_FILE_READ=TRUE\n");
     sprintf(buf, "GRASS_RENDER_FILE=%s\n", out_file);
-    sprintf(buf, "GRASS_RENDER_FILE_READ=TRUE\n");
     sprintf(buf, "GRASS_RENDER_WIDTH=%d\n", width);
     sprintf(buf, "GRASS_RENDER_HEIGHT=%d\n", height);
