[GRASS-SVN] r65306 - grass/trunk/general/g.gui
    svn_grass at osgeo.org
    Thu May 21 14:01:15 PDT 2015
Author: wenzeslaus
Date: 2015-05-21 14:01:15 -0700 (Thu, 21 May 2015)
New Revision: 65306
   grass/trunk/general/g.gui/main.c
g.gui: add -f for start in the foreground, i.e. block the command line
This is advantageos when passing g.gui as paramter to grass command (--exec, #2579, r65252, r65294). Without -f g.gui will exit which will end the GRASS session but running GUI will still be there without valid GISRC.
This is also potentially advantageous for QGIS or any other 3rd party usage of some part of GUI, most notably 3D view (NVIZ) which can be imediately invoked using (properly generated) workspace file.
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c	2015-05-21 20:32:10 UTC (rev 65305)
+++ grass/trunk/general/g.gui/main.c	2015-05-21 21:01:15 UTC (rev 65306)
@@ -25,7 +25,7 @@
 int main(int argc, char *argv[])
     struct Option *type, *rc_file;
-    struct Flag *update_ui, *nolaunch;
+    struct Flag *update_ui, *fglaunch, *nolaunch;
     struct GModule *module;
     const char *gui_type_env;
     char progname[GPATH_MAX];
@@ -61,8 +61,16 @@
     rc_file->key = "workspace";
     rc_file->required = NO;
     rc_file->key_desc = "name.gxw";
-    rc_file->description = _("Name of workspace file to load on start-up (valid only for wxGUI)");
+    rc_file->label = _("Name of workspace file to load on start-up");
+    rc_file->description = _("This is valid only for wxGUI (wxpython)");
+    fglaunch = G_define_flag();
+    fglaunch->key = 'f';
+    fglaunch->label = _("Start GUI in the foreground");
+    fglaunch->description = _("By default the GUI starts in the background"
+        " and control is immediately returned to the caller."
+        " When GUI runs in foregreound, it blocks the command line");
     update_ui = G_define_flag();
     update_ui->key = 'd';
     update_ui->description = _("Update default user interface settings");
@@ -93,20 +101,32 @@
 	exit(EXIT_SUCCESS);
-    G_message(_("Launching <%s> GUI in the background, please wait..."), type->answer);
     sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
-    if (rc_file->answer) {
-        G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
-                   "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
+    if (fglaunch->answer) {
+        G_message(_("Launching <%s> GUI, please wait..."), type->answer);
+        if (rc_file->answer) {
+            G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
+                       "--workspace", rc_file->answer, NULL);
+        else {
+                       NULL);
     else {
-                   SF_BACKGROUND, NULL);
+        G_message(_("Launching <%s> GUI in the background, please wait..."), type->answer);
+                       "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
+        else {
+                       SF_BACKGROUND, NULL);
+        /* stop the impatient from starting it again
+           before the splash screen comes up */
+        G_sleep(3);
-    /* stop the impatient from starting it again
-       before the splash screen comes up */
-    G_sleep(3);
     exit(EXIT_SUCCESS);
