[GRASS-SVN] r65314 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Sun May 24 14:42:56 PDT 2015
Author: krejcmat
Date: 2015-05-24 14:42:56 -0700 (Sun, 24 May 2015)
New Revision: 65314
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
modify path mgr, quantile, GUI
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-05-24 12:32:46 UTC (rev 65313)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-05-24 21:42:56 UTC (rev 65314)
@@ -6,14 +6,17 @@
sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.mwprecip'))
from mw_util import *
from mw3 import *
+import tempfile
from core.gcmd import GMessage, GError
from gui_core import gselect
+import wx.lib.scrolledpanel as scrolled
-class DBconn(wx.Panel):
+class DBconn(wx.ScrolledWindow):
def __init__(self, parent, settings={}):
- wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
+ wx.ScrolledWindow.__init__(self, parent, wx.ID_ANY, wx.DefaultPosition, wx.DefaultSize, wx.HSCROLL|wx.VSCROLL)
+ self.SetScrollRate( 5, 5 )
self.settings = settings
self.database = BaseInput(self, label='Name of database')
self.schema = BaseInput(self, label='Name of schema')
@@ -81,9 +84,10 @@
return self.settings
-class PointInterpolationPanel(wx.Panel):
+class PointInterpolationPanel(wx.ScrolledWindow):
def __init__(self, parent, settings=None):
self.interpolState = wx.CheckBox(self, label='interpolate points along links')
self.interpolState.Bind(wx.EVT_CHECKBOX, self.onCheckInterpol)
@@ -126,30 +130,49 @@
-class BaselinePanel(wx.Panel):
+class BaselinePanel(wx.ScrolledWindow):
- self.dryWin = wx.RadioButton(self, label='Compute from dry windows', style=wx.RB_GROUP)
+ self.noDryWin = wx.RadioButton(self, label='Compute without dry window', style=wx.RB_GROUP)
+ self.dryWin = wx.RadioButton(self, label='Compute from dry windows')
self.fromFile = wx.RadioButton(self, label='Direct text input')
self.baselTypeTxt = wx.StaticText(self, label='Select statistic method')
self.baselType = wx.ComboBox(self, id=wx.ID_ANY, value="quantile", choices=['avg', 'mode', 'quantile'])
+ self.baselType.Bind(wx.EVT_ACTIVATE,self.onChangeStatistic)
+ self.baselType.Bind(wx.EVT_COMBOBOX,self.onChangeStatistic)
self.round = BaseInput(self, 'Round data to "n" of decimal places') # TODO MODE disable
self.quantile = BaseInput(self, 'Set quantile in %') # TODO quantile disable
self.aw = BaseInput(self, 'Antena wetting value')
- self.dryInterval = TextInput(self, 'Set interval of dry period')
+ self.dryInterval = TextInput(self, 'Set interval(s) of dry period')
self.fromFileVal = TextInput(self, 'Set baseline values in csv format')
- self.okBtt = wx.Button(self, wx.ID_OK, label='ok and close')
- self.onChangeMethod(None)
+ #self.okBtt = wx.Button(self, wx.ID_OK, label='ok and close')
+ self.onChangeMethod()
+ self.onChangeStatistic()
self.fromFile.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
self.dryWin.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
- self.okBtt.Bind(wx.EVT_BUTTON, self.saveSettings)
+ self.noDryWin.Bind(wx.EVT_RADIOBUTTON, self.onChangeMethod)
+ #self.okBtt.Bind(wx.EVT_BUTTON, self.saveSettings)
if len(settings) > 0:
self.loadSettings(None)
self._layout()
+ def onChangeStatistic(self,evt=None):
+ if self.baselType.GetValue() == 'avg':
+ self.round.Disable()
+ self.quantile.Disable()
+ if self.baselType.GetValue() == 'mode':
+ self.round.Enable()
+ if self.baselType.GetValue() == 'quantile':
+ self.quantile.Enable()
def loadSettings(self, sett=None):
if sett is not None:
@@ -157,6 +180,8 @@
self.fromFile.SetValue(self.settings['fromFile'])
if 'dryWin' in self.settings:
self.dryWin.SetValue(self.settings['dryWin'])
+ if 'noDryWin' in self.settings:
+ self.noDryWin.SetValue(self.settings['noDryWin'])
if 'quantile' in self.settings:
self.quantile.SetValue(self.settings['quantile'])
if 'baselType' in self.settings:
@@ -176,6 +201,7 @@
self.settings['fromFile'] = self.fromFile.GetValue()
self.settings['dryWin'] = self.dryWin.GetValue()
+ self.settings['noDryWin'] = self.noDryWin.GetValue()
self.settings['baselType'] = self.baselType.GetValue()
self.settings['round'] = self.round.GetValue()
@@ -186,14 +212,15 @@
def onChangeMethod(self, evt=None):
- if self.dryWin.GetValue() is False:
+ if self.fromFile.GetValue() is True:
self.baselType.Disable()
self.aw.Disable()
self.dryInterval.Disable()
self.fromFileVal.Enable()
- else:
+ elif self.dryWin.GetValue() is True:
self.baselType.Enable()
self.round.Enable()
self.aw.Enable()
@@ -201,8 +228,18 @@
self.dryInterval.Enable()
self.fromFileVal.Disable()
+ elif self.noDryWin.GetValue() is True:
+ self.baselType.Enable()
+ self.aw.Enable()
+ self.dryInterval.Disable()
+ self.fromFileVal.Disable()
def _layout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
+ sizer.Add(self.noDryWin, flag=wx.EXPAND)
sizer.Add(self.dryWin, flag=wx.EXPAND)
sizer.Add(self.fromFile, flag=wx.EXPAND)
sizer.Add(self.baselTypeTxt, flag=wx.EXPAND)
@@ -215,8 +252,8 @@
sizer.Add(self.fromFileVal, flag=wx.EXPAND)
sizer.AddSpacer(10, 0, wx.EXPAND)
# sizer.Add(self.SLpanel, flag=wx.EXPAND)
- sizer.Add(self.okBtt, flag=wx.EXPAND)
- self.SetSizerAndFit(sizer)
+ #sizer.Add(self.okBtt, flag=wx.EXPAND)
+ self.SetSizer(sizer)
@@ -227,9 +264,10 @@
-class DataMgrMW(wx.Panel):
+class DataMgrMW(wx.ScrolledWindow):
self.stBoxTWIN = wx.StaticBox(self, wx.ID_ANY, 'Time windows MW')
@@ -486,30 +524,35 @@
self.SetSizerAndFit(mainSizer)
-class MyFrame(wx.Frame):
+class MWMainFrame(wx.Frame):
def __init__(self, parent, id, title):
- wx.Frame.__init__(self, parent, id, title, size=(480, 640),style=wx.DEFAULT_FRAME_STYLE ^ wx.RESIZE_BORDER)
- self.workPath = os.path.dirname(os.path.realpath(__file__))
+ wx.Frame.__init__(self, parent, id, title,style=wx.DEFAULT_FRAME_STYLE )
+ #self.workPath = tempfile.gettempdir()
+ self.workPath = os.path.join(pathToMapset(), "temp")
self.initWorkingFoldrs()
self.settings = {}
+ self.settings['workPath']=self.workPath
self.settingsLst = []
self.mainSizer = wx.BoxSizer(wx.VERTICAL)
self.panelSizer = wx.BoxSizer(wx.VERTICAL)
self.mainPanel = wx.Panel(self,id=wx.ID_ANY)
menubar = wx.MenuBar()
settMenu = wx.Menu()
- fileMenu = wx.Menu()
databaseItem = settMenu.Append(wx.ID_ANY, 'Database', 'Set database')
- baselineItem = settMenu.Append(wx.ID_ANY, 'Baseline', 'Set baseline methods')
+ #baselineItem = settMenu.Append(wx.ID_ANY, 'Baseline', 'Set baseline methods')
geometry = settMenu.Append(wx.ID_ANY, 'Geometry', 'Create vector geometry')
+ woringPath = settMenu.Append(wx.ID_ANY, 'Working Dir', 'Set working directory')
quitItem = settMenu.Append(wx.ID_EXIT, 'Quit', 'Quit application')
- menubar.Append(settMenu, '&Options')
+ menubar.Append(settMenu, '&Menu')
self.SetMenuBar(menubar)
self.Bind(wx.EVT_MENU, self.onQuit, quitItem)
self.Bind(wx.EVT_MENU, self.onSetDatabase, databaseItem)
- self.Bind(wx.EVT_MENU, self.onSetBaseline, baselineItem)
+ self.Bind(wx.EVT_MENU, self.onSetWorkPath, woringPath)
+ #self.Bind(wx.EVT_MENU, self.onSetBaseline, baselineItem)
self.Bind(wx.EVT_MENU, self.onSetGeometry, geometry)
#def initNotebook(self):
@@ -519,11 +562,14 @@
self.dataMgrMW.getEndBtt.Bind(wx.EVT_BUTTON, self.getMaxTime)
self.dataMgrMW.getStartBtt.Bind(wx.EVT_BUTTON, self.getMinTime)
+ self.baselinePnl=BaselinePanel(self.ntb)
#self.dataMgrRG = DataMgrMW(self.ntb )
- self.pointInter = PointInterpolationPanel(self.ntb)
+ #self.pointInter = PointInterpolationPanel(self.ntb)
self.ntb.AddPage(page=self.dataMgrMW, text='MW data')
+ self.ntb.AddPage(page=self.baselinePnl, text='Baseline')
#self.ntb.AddPage(page=self.dataMgrRG, text='RG data')
- self.ntb.AddPage(page=self.pointInter, text='Points Interpolation')
+ #self.ntb.AddPage(page=self.pointInter, text='Points Interpolation')
self.grassLayers = GrassLayers(self.ntb, self.settings)
self.ntb.AddPage(page=self.grassLayers, text='Colors')
@@ -572,7 +618,10 @@
self.newScheme.Disable()
def OnLoadSettings(self, evt=None):
+ print 'combobox'
currSelId = self.profilSelection.GetSelection()
+ print(currSelId)
+ print self.settingsLst[currSelId]
self.settings = self.settingsLst[currSelId]
try:
self.dataMgrMW.loadSettings(self.settings)
@@ -594,6 +643,10 @@
self.grassLayers.loadSettings(self.settings)
except:
pass
def OnSaveSettings(self, evt=None, toFile=True):
try:
self.settings = self.dataMgrMW.saveSettings(sett=self.settings)
@@ -603,6 +656,7 @@
# self.settings=self.dataMgrRG.saveSettings(sett=self.settings)
# except:
# pass
try:
self.settings = self.databasePnl.saveSettings(sett=self.settings)
except:
@@ -615,16 +669,20 @@
self.settings = self.grassLayers.saveSettings(sett=self.settings)
except:
pass
self.settings['workSchema'] = self.profilSelection.GetValue()
+ #self.settings['workPath'] = self.workPath
if self.schema.GetValue() is not None:
self.settings['workSchema'] = self.schema.GetValue()
if toFile:
tmpPath = os.path.join(self.workPath, "save", self.settings['workSchema'])
saveDict(tmpPath, self.settings)
self.findProject()
def initWorkingFoldrs(self):
savePath = os.path.join(self.workPath, 'save')
if not os.path.exists(savePath):
os.makedirs(savePath)
@@ -692,34 +750,24 @@
pass
- def onSetBaseline(self, evt):
- self.bsDialog = wx.Dialog(self, id=wx.ID_ANY,
- title='Baseline settings',
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
- size=wx.DefaultSize,
- pos=wx.DefaultPosition)
+ def onSetWorkPath(self,evt):
- # self.bsDialog.SetSize((500, 500))
+ #f = tempfile.TemporaryFile()
+ dlg = wx.DirDialog(self,
+ message="Select working directory",
+ defaultPath=self.workPath,
+ style=wx.DD_DEFAULT_STYLE | wx.DD_NEW_DIR_BUTTON)
- if self.settings:
- self.baselinePnl = BaselinePanel(self.bsDialog, self.settings)
- else:
- self.baselinePnl = BaselinePanel(self.bsDialog)
+ if dlg.ShowModal() == wx.ID_OK:
+ self.workPath = dlg.GetPath()
+ dlg.Destroy()
+ self.initWorkingFoldrs()
+ self.profilSelection.Clear()
+ self.settingsLst=[]
+ self.findProject()
- self.baselinePnl.okBtt.Bind(wx.EVT_BUTTON, self._onSetBaselineDLG)
- dbSizer = wx.BoxSizer(wx.VERTICAL)
- dbSizer.Add(self.baselinePnl, flag=wx.EXPAND)
+ GMessage('Working path destination: %s' % self.workPath)
- self.bsDialog.SetSizer(dbSizer)
- self.bsDialog.SetBestFittingSize()
- self.bsDialog.ShowModal()
- self.bsDialog.Destroy()
- def _onSetBaselineDLG(self, evt):
- self.settings = self.baselinePnl.saveSettings()
- print self.settings
def onSetDatabase(self, evt):
self.dbDialog = wx.Dialog(self, id=wx.ID_ANY,
title='Database connection settings',
@@ -877,8 +925,8 @@
interface.initVectorGrass()
#if interpolate points along lines
- if self.pointInter.interpolState.GetValue():
- interface.initPInterpolation()
+ #if self.pointInter.interpolState.GetValue():
+ # interface.initPInterpolation()
interface.initTimeWinMW()
interface.initBaseline()
@@ -917,8 +965,10 @@
def initConnection(self, info=False):
conninfo = None
try:
conninfo = {'name': self.settings['database']}
except:
GMessage('name of database is missing')
return
@@ -934,7 +984,7 @@
conninfo['port'] = self.settings['port']
if 'passwd' in self.settings:
conninfo['password'] = self.settings['passwd']
+ conninfo['workPath']=self.settings['workPath']
if conninfo is None:
self.connStatus = False
GMessage('Database connection failed')
@@ -1000,21 +1050,29 @@
baselInit['type'] = 'values'
if 'fromFileVal' in self.settings:
baselInit['pathToFile'] = self.settings['fromFileVal']
+ methodSel = True
else:
self.errMsg('Path to file with baseline values is not defined')
- methodSel = True
if self.settings['dryWin']:
baselInit['type'] = 'fromDryWin'
if 'dryInterval' in self.settings:
baselInit['pathToFile'] = self.settings['dryInterval']
+ methodSel = True
else:
self.errMsg('Dry interval is not defined')
+ if self.settings['noDryWin']:
+ baselInit['type'] = 'noDryWin'
methodSel = True
if not methodSel:
self.errMsg('Baseline method is not selected')
print baselInit
self.baseline = Baseline(**baselInit)
@@ -1067,7 +1125,7 @@
def initTemporalMgr(self):
GrassTemporalMgr(self.dbConn, self.twin)
- GMessage('Finish')
+ #GMessage('Finish')
def errMsg(self, label):
print label
@@ -1075,7 +1133,7 @@
class MyApp(wx.App):
def OnInit(self):
- frame = MyFrame(None, -1, "MW manager")
+ frame = MWMainFrame(None, -1, "MW manager")
frame.Show(True)
self.SetTopWindow(frame)
return True
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-05-24 12:32:46 UTC (rev 65313)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-05-24 21:42:56 UTC (rev 65314)
@@ -14,6 +14,7 @@
from core.gcmd import RunCommand
from grass.pygrass.modules import Module
+import numpy as np
try:
from grass.script import core as grass
@@ -253,7 +254,7 @@
self.lon = float(f.next())
f.close()
except IOError as (errno, strerror):
- print "I/O error({0}): {1}".format(errno, strerror)
+ grass.message( "I/O error({0}): {1}".format(errno, strerror))
gaugeTMPfile = "gauge_tmp"
removeLines(old_file=path,
@@ -270,7 +271,7 @@
tmp.append(stri)
f.close()
# write list of string to database
try:
@@ -278,7 +279,7 @@
io.writelines(tmp)
io.close()
if not isTableExist(self.db.connection, self.schema, self.db.rgaugeTableName):
# #create table for raingauge stations
@@ -310,7 +311,7 @@
class Baseline():
- def __init__(self, type, pathToFile, statFce='mode', quantile=97, roundMode=3, aw=0):
+ def __init__(self, type='noDryWin', pathToFile=None, statFce='mode', quantile=97, roundMode=3, aw=0):
self.quantile = quantile
self.roundMode = roundMode
self.aw = aw
@@ -318,6 +319,7 @@
self.type = type
self.statFce = statFce
if statFce == 'mode':
if self.roundMode is None:
grass.warning('Value "round" is missing.')
@@ -330,10 +332,9 @@
if self.type == 'values':
if self.pathToFile is None:
grass.warning('Baseline values are not defined.')
print self.pathToFile
class TimeWindows():
def __init__(self, database, IDtype, sumStep, startTime=None,
endTime=None, linksIgnored=False, linksOnly=False, links=None, linksMap=None):
@@ -381,7 +382,7 @@
self.crateTimeWin()
def sumValues(self):
- # #summing values per (->user)timestep interval
+ ##summing values per (->user)timestep interval
self.viewDB = 'computed_precip_sum'
sql = "CREATE %s %s.%s as \
SELECT %s ,round(avg(precip)::numeric,3) as %s, date_trunc('%s',time)as time \
@@ -562,6 +563,8 @@
database = self.database
tMin = self.timeWin.timestamp_min
tMax = self.timeWin.timestamp_max
+ startTime=self.timeWin.startTime
+ endTime=self.timeWin.endTime
def computeBaselinFromMode(recordTable):
sql = "SELECT linkid from %s group by 1" % recordTable
@@ -591,7 +594,10 @@
# io1.write('mode|' + str(baseline.aw))
# io1.close
def computeBaselineFromTime():
def chckTimeValidity(tIn):
# print tIn
tIn = str(tIn).replace("\n", "")
@@ -623,62 +629,71 @@
tmp = []
st = ''
#print baseline.statFce
- ######## AVG ##########
+ ######## AVG #########
if baseline.statFce == 'avg':
- try:
- #print baseline.pathToFile
- f = open(baseline.pathToFile, 'r')
- except IOError as (errno, strerror):
- print baseline.pathToFile
- grass.warning('Path to file with dry-window definiton not exist; %s' % baseline.pathTofile)
- for line in f:
- st += line.replace("\n", "")
- if 'i' in line.split("\n")[0]: #get baseline form interval
- fromt = f.next()
- if not chckTimeValidity(fromt):
- return False
- st += fromt.replace("\n", "")
- tot = f.next()
- if not chckTimeValidity(tot):
- return False
- #validate input data
- if not isTimeValid(fromt) or not isTimeValid(tot):
- grass.warning("Input data are not valid. Parameter 'baselitime'")
- return False
- st += tot.replace("\n", "")
+ if baseline.type == 'noDryWin':
+ if baseline.statFce == 'avg':
sql = "SELECT linkid, avg(a) FROM %s.record \
WHERE time >='%s' AND time<='%s' group by linkid order by 1" % (
- database.schema, fromt, tot)
+ database.schema, startTime, endTime)
resu = database.connection.executeSql(sql, True, True)
tmp.append(resu)
+ else:
+ try:
+ #print baseline.pathToFile
+ f = open(baseline.pathToFile, 'r')
+ except IOError as (errno, strerror):
+ grass.warning('Path to file with dry-window definiton not exist; %s' % baseline.pathTofile)
+ for line in f:
+ st += line.replace("\n", "")
+ if 'i' in line.split("\n")[0]: #get baseline form interval
+ fromt = f.next()
+ if not chckTimeValidity(fromt):
+ return False
+ st += fromt.replace("\n", "")
+ tot = f.next()
+ if not chckTimeValidity(tot):
+ return False
+ #validate input data
+ if not isTimeValid(fromt) or not isTimeValid(tot):
+ grass.warning("Input data are not valid. Parameter 'baselitime'")
+ return False
- else: # baseline one moment
- time = line.split("\n")[0]
- if not isTimeValid(time):
- return False
- try:
- time = datetime.strptime(time, "%Y-%m-%d %H:%M:%S")
- except ValueError:
- grass.message('Wrong datetime format')
- return False
- st += str(time).replace("\n", "")
- fromt = time + timedelta(seconds=-60)
- return False
- tot = time + timedelta(seconds=+60)
- return False
- sql = "SELECT linkid, avg(a) FROM %s.record \
- WHERE time >='%s' AND time<='%s' group by linkid order by 1" % (
- resu = database.connection.executeSql(sql, True, True)
- tmp.append(resu)
- continue
+ st += tot.replace("\n", "")
+ sql = "SELECT linkid, avg(a) FROM %s.record \
+ WHERE time >='%s' AND time<='%s' group by linkid order by 1" % (
+ database.schema, fromt, tot)
+ resu = database.connection.executeSql(sql, True, True)
+ tmp.append(resu)
+ else: # baseline one moment
+ time = line.split("\n")[0]
+ if not isTimeValid(time):
+ return False
+ try:
+ time = datetime.strptime(time, "%Y-%m-%d %H:%M:%S")
+ except ValueError:
+ grass.message('Wrong datetime format')
+ return False
+ st += str(time).replace("\n", "")
+ fromt = time + timedelta(seconds=-60)
+ return False
+ tot = time + timedelta(seconds=+60)
+ return False
+ tmp.append(resu)
+ continue
mydict1 = {}
i = True
#print(tmp)
@@ -715,64 +730,70 @@
######## MODE or QUANTILE ##########
elif baseline.statFce == 'mode' or baseline.statFce == 'quantile':
#print 'mode***'
- try:
- grass.warning('Path to file with dry-window definiton not exist')
- return False
#parse input file
- for line in f:
- if 'i' in line.split("\n")[0]: #get baseline intervals
- fromt = f.next()
- return False
- tot = f.next()
- return False
- return False
- sql = "SELECT linkid, a from %s.record WHERE time >='%s' and time<='%s'" % (
- resu += resu
+ sql = "SELECT linkid, a from %s.record WHERE time >='%s' and time<='%s'" % (
+ database.connection.executeSql(sql, False, True)
+ else:
+ try:
+ grass.warning('Path to file with dry-window definiton not exist')
+ return False
+ for line in f:
+ if 'i' in line.split("\n")[0]: #get baseline intervals
+ fromt = f.next()
+ return False
+ tot = f.next()
+ return False
+ return False
+ resu += resu
- else: #get baseline one moment
- return False
- try:
- return False
- return False
- return False
+ else: #get baseline one moment
+ return False
+ try:
+ return False
+ return False
+ return False
- resu += resu
- continue
+ resu += resu
+ continue
tmp.append(resu)
- table_mode_tmp = "mode_tmp"
- sql = "CREATE TABLE %s.%s ( linkid integer,a real);" % (database.schema, table_mode_tmp)
+ table_tmp = baseline.statFce+ '_tmp'
+ sql = "CREATE TABLE %s.%s ( linkid integer,a real);" % (database.schema, table_tmp)
#write values to flat file
- io = open(os.path.join(database.pathworkSchemaDir, "mode_tmp"), 'w+')
+ io = open(os.path.join(database.pathworkSchemaDir, table_tmp), 'w+')
c = 0
for it in tmp:
for i in it:
@@ -783,15 +804,15 @@
#update table
try:
- io1 = open(os.path.join(database.pathworkSchemaDir, "mode_tmp"), "r")
- database.connection.copyfrom(io1, "%s.%s" % (database.schema, table_mode_tmp))
+ io1 = open(os.path.join(database.pathworkSchemaDir, table_tmp), "r")
+ database.connection.copyfrom(io1, "%s.%s" % (database.schema, table_tmp))
io1.close()
- os.remove(os.path.join(database.pathworkSchemaDir, "mode_tmp"))
+ os.remove(os.path.join(database.pathworkSchemaDir, table_tmp))
- grass.warning('Cannot open mode_tmp file')
+ grass.warning('Cannot open <%s> file'% table_tmp)
return False
- recname = database.schema + '.' + table_mode_tmp
+ recname = database.schema + '.' + table_tmp
if baseline.statFce == 'mode':
computeBaselinFromMode(recname)
@@ -799,16 +820,11 @@
if baseline.statFce == 'quantile':
computeBaselineFromQuentile(recname)
- sql = "DROP TABLE %s.%s" % (database.schema, table_mode_tmp)
+ sql = "DROP TABLE %s.%s" % (database.schema, table_tmp)
- #write unique mark to file
- io1 = open(os.path.join(database.pathworkSchemaDir, "compute_precip_info"), 'w+')
- st = st + '|' + str(baseline.aw)
- io1.write(st)
- io1.close
return True
def computeBaselineFromQuentile(recordTable):
sql = "SELECT linkid from %s group by linkid" % recordTable
linksid = database.connection.executeSql(sql, True, True)
@@ -826,19 +842,53 @@
ORDER BY quartile\
limit 1" % (baseline.quantile, recordTable, linkid)
- # print resu
resu = resu[0][0]
tmp.append(str(linkid) + ',' + str(resu) + '\n')
io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), 'w+')
io0.writelines(tmp)
io0.close()
+ def Quantile(data, q, precision=1.0):
+ Returns the q'th percentile of the distribution given in the argument
+ 'data'. Uses the 'precision' parameter to control the noise level.
+ #data = np.random.normal(size=2000000)
+ q=float(q)/100
+ N, bins = np.histogram(data, bins=precision*np.sqrt(len(data)))
+ norm_cumul = 1.0*N.cumsum() / len(data)
+ ret=bins[norm_cumul > q][0]
+ # print "error in %s quantile"%q, ((1.0*(data < ret).sum() / len(data)) -q)
- io1.write('quantile' + str(baseline.quantile) + '|' + str(baseline.aw))
- io1.close
+ return ret
+ def computeBaselineFromQuentile(recordTable):
+ sql = "SELECT linkid from %s group by linkid" % recordTable
+ linksid = database.connection.executeSql(sql, True, True)
+ tmp = []
+ # for each link compute baseline
+ for linkid in linksid:
+ linkid = linkid[0]
+ sql = "SELECT a from %s where linkid=%s"% (recordTable, linkid)
+ data=np.array(resu)
+ #data=[item for sublist in data for item in sublist]#merge lists
+ #print data
+ #quantileRes=Quantile(data, baseline.quantile)
+ quantileRes=np.percentile(data, (100-float(baseline.quantile))/100)
+ tmp.append(str(linkid) + ',' + str(quantileRes)+ '\n')
+ #print tmp
+ io0 = open(os.path.join(database.pathworkSchemaDir, "baseline"), 'w+')
+ io0.writelines(tmp)
+ io0.close()
def readBaselineFromText(path):
with open(path, mode='r') as infile:
reader = csv.reader(infile, delimiter=',')
@@ -849,15 +899,21 @@
# print 'valuesDirectly'
self.baselineDict = readBaselineFromText(self.baseline.pathTofile)
- elif self.baseline.type == 'fromDryWin':
- grass.message('Computing baselines "time interval" "%s"...' % self.baseline.statFce)
- # print 'fromDryWin'
+ elif self.baseline.type == 'fromDryWin' :
+ grass.message('Computing baselines "dry window" "%s"...' % self.baseline.statFce)
if computeBaselineFromTime():
self.baselineDict = readBaselineFromText(os.path.join(database.pathworkSchemaDir, 'baseline'))
return True
else:
return False
+ elif self.baseline.type == 'noDryWin':
+ grass.message('Computing baselines "no dry window" "%s"...' % self.baseline.statFce)
+ if computeBaselineFromTime():
+ self.baselineDict = readBaselineFromText(os.path.join(database.pathworkSchemaDir, 'baseline'))
+ return True
+ else:
+ return False
def logMsg(self, msg):
if self.status.get('msg') == 'Done':
self.status['msg'] = ''
@@ -865,6 +921,15 @@
grass.warning(msg)
def computePrecip(self, getData=False, dataOnly=False):
+ def checkValidity(freq, polarization):
+ if freq < 10000000:
+ return False
+ if polarization is 'V' or polarization is 'H':
+ return True
+ return False
Aw = float(self.baseline.aw)
link_num = self.database.connection.count("link")
compPrecTab = "%s.%s" % (self.database.schema, self.database.computedPrecip)
@@ -961,35 +1026,39 @@
skippedList = []
for record in resu:
curLinkData = linksDict[record[0]] # record[0] is linkid
if curLinkData[1] is None:
if not record[0] in skippedList:
curLinkData[1] = 'V' # TODO REMOVE THIS!!!!!!!!!!!!!!!!
- #self.logMsg('Polarization value is missing. Linkid<%s> wil be skipped' % record[0])
- #skippedList.append(record[0])
- continue
- # if missing baseline. Link will be skip
- if record[0] in self.baselineDict and (curLinkData[2] / 1000000) > 10: #TODO
- # coef_a_k[alpha, k]
- coef_a_k = self.computeAlphaK(curLinkData[2], curLinkData[1])
+ if record[0] in self.baselineDict:
+ coef_a_k[alpha, k]
+ record[0] is linkid
+ record[1] is time
+ record[2] is tx-rx
+ curLinkData[0] is lenght
+ curLinkData[1] is polarization
+ curLinkData[2] is frequency HZ
+ if checkValidity(curLinkData[2], curLinkData[1]):
+ coef_a_k = self.computeAlphaK(curLinkData[2], curLinkData[1])
+ else:
+ self.logMsg('Data of link <%s> are not valid'%record[0])
+ continue
#read value from dictionary
baseline_decibel = (self.baselineDict[record[0]])
#final precipiatation is R1
- Ar = record[2] - baseline_decibel - Aw
- #TODO check this condition
- '''computePrecip
- R1 = (yr / coef_a_k[1]) ** (1 / coef_a_k[0])
- ValueError: negative number cannot be raised to a fractional
- power
- if Ar > 0:
- yr = Ar / curLinkData[0]
- #print R1
+ Am = record[2] - baseline_decibel - Aw
+ yl = Am / curLinkData[0]
+ aa = yl / coef_a_k[1]
+ if aa <0:
+ aa*=-1
+ R1 = aa ** (1 / coef_a_k[0])
+ R1*=-1
else:
- R1 = 0
#string for output flatfile
out = str(record[0]) + "|" + str(record[1]) + "|" + str(R1) + "\n"
@@ -1024,7 +1093,7 @@
freq /= 1000000
- if polarization == "h":
+ if polarization == "H":
# Coefficients for kH 1
aj_kh = (-5.33980, -0.35351, -0.23789, -0.94158)
bj_kh = (-0.10008, 1.26970, 0.86036, 0.64552)
@@ -1199,7 +1268,7 @@
for win in f.read().splitlines():
layerNum += 1
win = self.database.schema + '.' + win
- print win
+ grass.message( win)
RunCommand('v.db.connect',
driver='pg',
map=self.database.linkVecMapName,
@@ -1275,9 +1344,9 @@
io1 = open(regFilePath, 'w+')
io1.writelines(regTMP), io1.close
io1.close()
- print 'datasetName', self.datasetName
- print regFilePath
- #sys.exit()
+ grass.message( 'datasetName %s'% self.datasetName)
+ grass.message(regFilePath)
RunCommand('t.register',
input=self.datasetName,
type='vector',
@@ -1289,7 +1358,7 @@
class Database():
def __init__(self, name=None, user=None, password=None,
host=None, port=None, nodeVecMapName='node', linkVecMapName='link',
- linkPointsVecName='linkPoints', workSchema=None, dataSchema=None):
+ linkPointsVecName='linkPoints',workPath=None, workSchema=None, dataSchema=None):
self.dbConnStr=name
self.dbName = name
self.user = user
@@ -1315,8 +1384,10 @@
self.nodeVecMapName = nodeVecMapName
self.linkVecMapName = linkVecMapName
self.linkPointsVecName = linkPointsVecName
- self.pathworkSchemaDir = os.path.join(os.path.dirname(os.path.realpath(__file__)), "tmp_%s" % self.schema)
+ self.pathworkSchemaDir = os.path.join(workPath, "tmp_%s" % self.schema)
+ #self.pathworkSchemaDir = os.path.join(tempfile.gettempdir(), "tmp_%s" % self.schema)
self.pyConnection()
#if self.host:
self.grassConnectionRemote()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-05-24 12:32:46 UTC (rev 65313)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py 2015-05-24 21:42:56 UTC (rev 65314)
@@ -11,8 +11,8 @@
import wx.lib.filebrowsebutton as filebrowse
import codecs
+from grass.script import core as grass
class SaveLoad(wx.Panel):
def __init__(self, parent):
@@ -383,57 +383,6 @@
self.pathInput.SetValue(value)
-class FileInput(wx.Panel):
- def __init__(self, parent, label, dir=False, tmpPath=None):
- self.dir = dir
- self.tmpPath = tmpPath
- statText = wx.StaticText(self, id=wx.ID_ANY, label=label)
- self.pathInput = wx.TextCtrl(self, id=wx.ID_ANY)
- self.browseBtt = wx.Button(self, id=wx.ID_ANY, label='Browse')
- sizer = wx.BoxSizer(wx.VERTICAL)
- sizer2 = wx.BoxSizer(wx.HORIZONTAL)
- sizer2.Add(self.pathInput, flag=wx.EXPAND, proportion=1)
- sizer2.Add(self.browseBtt, flag=wx.EXPAND)
- sizer.Add(statText, flag=wx.EXPAND)
- sizer.Add(sizer2, flag=wx.EXPAND)
- self.SetSizer(sizer)
- self.browseBtt.Bind(wx.EVT_BUTTON, self.onBrowse)
- def onBrowse(self, event):
- if self.dir:
- openFileDialog = wx.DirDialog(self, "Choose a directory:",
- style=wx.DD_DEFAULT_STYLE | wx.DD_DIR_MUST_EXIST | wx.DD_CHANGE_DIR)
- if openFileDialog.ShowModal() == wx.ID_CANCEL:
- return # the user changed idea...
- path = openFileDialog.GetPath()
- self.pathInput.SetValue(path)
- else:
- openFileDialog = wx.FileDialog(self, "Choose a file:", style=wx.FD_OPEN | wx.FD_FILE_MUST_EXIST)
- def GetPath(self):
- path = self.pathInput.GetValue()
- if len(path) != 0:
- return path
- else:
- return None
- def SetPath(self, value):
- self.pathInput.SetValue(value)
def YesNo(parent, question, caption='Yes or no?'):
dlg = wx.MessageDialog(parent, question, caption, wx.YES_NO | wx.ICON_QUESTION)
result = dlg.ShowModal() == wx.ID_YES
@@ -453,6 +402,7 @@
if full:
tmp.append(os.path.join(fpath, path))
else:
tmp.append(path)
if len(tmp) > 0:
return tmp
@@ -496,6 +446,9 @@
output_stream = (saveFileDialog.GetPath())
return output_stream
+def pathToMapset():
+ gisenvDict = grass.gisenv()
+ return os.path.join(gisenvDict['GISDBASE'], gisenvDict['LOCATION_NAME'], gisenvDict['MAPSET'])
def saveDict(fn, dict_rap):
f = open(fn, "wb")
@@ -508,18 +461,23 @@
def readDict(fn):
- f = open(fn, 'rb')
+ f = open(fn, 'r')
dict_rap = {}
- for key, val in csv.reader(f):
- try:
- dict_rap[key] = eval(val)
- except:
- val = '"' + val + '"'
- f.close()
- return (dict_rap)
+ try:
+ for key, val in csv.reader(f):
+ try:
+ dict_rap[key] = eval(val)
+ except:
+ val = '"' + val + '"'
+ f.close()
+ return (dict_rap)
+ except IOError as e:
+ print "I/O error({0}): {1}".format(e.errno, e.strerror)
def randomWord(length):
return ''.join(random.choice(string.lowercase) for i in range(length))
@@ -539,5 +497,4 @@
seconds = (dt - dt.min).seconds
# // is a floor division, not a comment on following line:
rounding = (seconds + roundTo / 2) // roundTo * roundTo # rounding floor
- return dt + timedelta(0, rounding - seconds, -dt.microsecond)
+ return dt + timedelta(0, rounding - seconds, -dt.microsecond)
\ No newline at end of file
