[GRASS-SVN] r65320 - grass/trunk/gui/wxpython/core
Tue May 26 00:37:18 PDT 2015
Author: martinl
Date: 2015-05-26 00:37:18 -0700 (Tue, 26 May 2015)
New Revision: 65320
   grass/trunk/gui/wxpython/core/render.py
wxGUI: skip map layers which failed to be rendered
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2015-05-25 21:13:52 UTC (rev 65319)
+++ grass/trunk/gui/wxpython/core/render.py	2015-05-26 07:37:18 UTC (rev 65320)
@@ -36,6 +36,7 @@
 from grass.script.utils import try_remove
 from grass.script.task import cmdlist_to_tuple, cmdtuple_to_list
 from grass.pydispatch.signal import Signal
+from grass.exceptions import CalledModuleError
 from core          import utils
 from core.utils import _
@@ -378,7 +379,10 @@
         self.layer.forceRender = False
     def _render(self, cmd, env):
-        return grass.run_command(cmd[0], env=env, **cmd[1])
+        try:
+            return grass.run_command(cmd[0], env=env, **cmd[1])
+        except CalledModuleError as e:
+            return 1
     def Abort(self):
         """Abort rendering process"""
@@ -399,6 +403,12 @@
         Debug.msg(1, "RenderLayerMgr.OnRenderDone(%s): ret=%d time=%f" % \
                       (self.layer, event.ret, time.time() - self._startTime))
+        if event.ret != 0:
+            try:
+                os.remove(self.layer.mapfile)
+            except:
+                pass
         self.updateProgress.emit(layer=self.layer)
 class RenderMapMgr(wx.EvtHandler):
@@ -516,7 +526,10 @@
         opacities = list()
         for layer in self.layers:
-            if layer.GetType() != 'overlay':
+            if layer.GetType() == 'overlay':
+                continue
+            if os.path.isfile(layer.mapfile):
                 maps.append(layer.mapfile)
                 masks.append(layer.maskfile)
                 opacities.append(str(layer.opacity))
