[GRASS-SVN] r66703 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical
Mon Nov 2 01:00:52 PST 2015
Author: Giulia
Date: 2015-11-02 01:00:52 -0800 (Mon, 02 Nov 2015)
New Revision: 66703
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.html
r.green: small changes in the html
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.html
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.html	2015-11-02 09:00:14 UTC (rev 66702)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.html	2015-11-02 09:00:52 UTC (rev 66703)
@@ -100,7 +100,7 @@
 Potential intakes and restitutions
 </center><br><br>
-The following command that you can either put in the command console or the GUI of r.green.hydro.technical, computes the structure of the potential plants for each side of the river and includes the corrected power on the output map table:<br>
+The following command that you can either put in the command console or the GUI of r.green.hydro.technical computes the structure of the potential plants for each side of the river and includes the corrected power on the output map table:<br>
 <div class="code"><pre>r.green.hydro.technical plant=potentialplants elevation=elevation output_struct=techplants output_plant=segmentplants
 turbine_folder=/pathtothefileoftheturbine_folder  turbine_list=/pathtothefileoftheturbine_list</pre></div><br>
 The result is shown in the following vector map called techplants. The table of this map is completed as explained in the end of the NOTES part.<br><br>
