[GRASS-SVN] r66709 - grass-addons/grass7/raster/r.category.trim
svn_grass at osgeo.org
Mon Nov 2 03:02:54 PST 2015
Author: pvanbosgeo
Date: 2015-11-02 03:02:54 -0800 (Mon, 02 Nov 2015)
New Revision: 66709
grass-addons/grass7/raster/r.category.trim/r.category.trim.html
fix html
Modified: grass-addons/grass7/raster/r.category.trim/r.category.trim.html
--- grass-addons/grass7/raster/r.category.trim/r.category.trim.html 2015-11-02 10:59:22 UTC (rev 66708)
+++ grass-addons/grass7/raster/r.category.trim/r.category.trim.html 2015-11-02 11:02:54 UTC (rev 66709)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
<h3>Trim redundant category labels and colors</h3>
-<p>In GRASS you can 'cut out' a subset of a larger raster layer by
+In GRASS you can 'cut out' a subset of a larger raster layer by
setting the extent to something smaller then the extent of the
original map using g.region and/or by setting a mask using r.mask,
after which you simply run r.mapcalc "newmap = oldmap".
