[GRASS-SVN] r66722 - in grass/trunk: raster/r.univar/testsuite scripts/v.rast.stats/testsuite temporal/t.unregister/testsuite
svn_grass at osgeo.org
Tue Nov 3 01:30:41 PST 2015
Author: neteler
Date: 2015-11-03 01:30:41 -0800 (Tue, 03 Nov 2015)
New Revision: 66722
grass/trunk/raster/r.univar/testsuite/test_r_univar.py
grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
testsuite: g.remove (and likely also t.remove) require -f flag
Modified: grass/trunk/raster/r.univar/testsuite/test_r_univar.py
--- grass/trunk/raster/r.univar/testsuite/test_r_univar.py 2015-11-03 08:46:17 UTC (rev 66721)
+++ grass/trunk/raster/r.univar/testsuite/test_r_univar.py 2015-11-03 09:30:41 UTC (rev 66722)
@@ -19,9 +19,9 @@
def tearDown(self):
pass
- self.runModule("g.remove", type="raster", name="map_a")
- self.runModule("g.remove", type="raster", name="map_b")
- self.runModule("g.remove", type="raster", name="zone_map")
+ self.runModule("g.remove", flags='f', type="raster", name="map_a")
+ self.runModule("g.remove", flags='f', type="raster", name="map_b")
+ self.runModule("g.remove", flags='f', type="raster", name="zone_map")
def setUp(self):
"""Create input data
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2015-11-03 08:46:17 UTC (rev 66721)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2015-11-03 09:30:41 UTC (rev 66722)
@@ -20,9 +20,9 @@
def tearDown(self):
pass
def setUp(self):
Modified: grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
--- grass/trunk/temporal/t.unregister/testsuite/test_unregister.py 2015-11-03 08:46:17 UTC (rev 66721)
+++ grass/trunk/temporal/t.unregister/testsuite/test_unregister.py 2015-11-03 09:30:41 UTC (rev 66722)
@@ -59,7 +59,7 @@
def tearDown(self):
"""Remove generated data"""
name="a1,a2,a3,a4,a5,a6")
def test_1(self):
@@ -117,7 +117,7 @@
self.assertEqual(a456, lister.outputs.stdout)
- # Remove STRDS A and B and chceck if maps a4, a5 and a6 are still in the temporal database
+ # Remove STRDS A and B and check if maps a4, a5 and a6 are still in the temporal database
self.assertModule("t.remove", type="strds", inputs="A,B")
lister = SimpleModule("t.list", type="raster", columns="name",
