[GRASS-SVN] r66725 - grass/trunk/lib/python/temporal
Tue Nov 3 02:59:38 PST 2015
Author: huhabla
Date: 2015-11-03 02:59:38 -0800 (Tue, 03 Nov 2015)
New Revision: 66725
   grass/trunk/lib/python/temporal/univar_statistics.py
temporal framework: Added output file support for vector time series univar stats output
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py	2015-11-03 09:34:31 UTC (rev 66724)
+++ grass/trunk/lib/python/temporal/univar_statistics.py	2015-11-03 10:59:38 UTC (rev 66725)
@@ -126,7 +126,7 @@
-def print_vector_dataset_univar_statistics(input, twhere, layer, type, column,
+def print_vector_dataset_univar_statistics(input, output, twhere, layer, type, column,
                                            where, extended, no_header=False,
                                            fs="|"):
     """Print univariate statistics for a space time vector dataset
@@ -148,6 +148,9 @@
     dbif = SQLDatabaseInterfaceConnection()
     dbif.connect()
+    if output is not None:
+        out_file = open(output, "w")
     mapset = get_current_mapset()
     if input.find("@") >= 0:
@@ -187,7 +190,10 @@
                 string += fs + "first_quartile" + fs + "median" + fs + \
                     "third_quartile" + fs + "percentile_90"
-        print string
+        if output is None:
+            print string
+        else:
+            out_file.write(string + "\n")
     for row in rows:
         id = row["name"] + "@" + row["mapset"]
@@ -247,6 +253,12 @@
                 else:
                     string += fs + fs + fs + fs
-        print string
+            print string
+        else:
     dbif.close()
+        out_file.close()
\ No newline at end of file
