[GRASS-SVN] r66748 - in grass-addons/grass7/raster/r.green: . r.green.hydro/libhydro r.green.hydro/r.green.hydro.financial r.green.hydro/r.green.hydro.optimal r.green.hydro/r.green.hydro.technical r.green.hydro/r.green.hydro.theoretical
Thu Nov 5 06:05:11 PST 2015
Author: Giulia
Date: 2015-11-05 06:05:11 -0800 (Thu, 05 Nov 2015)
New Revision: 66748
Added:
   grass-addons/grass7/raster/r.green/r_green.png
   grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green: png added
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py	2015-11-05 02:46:47 UTC (rev 66747)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/optimal.py	2015-11-05 14:05:11 UTC (rev 66748)
@@ -12,6 +12,8 @@
 import numpy as np
 #from grass.script import mapcalc
+version = 70  # 71
 from grass.script import core as gcore
 from grass.pygrass.messages import get_msgr
 from grass.pygrass.raster import RasterRow
@@ -290,6 +292,7 @@
     raster_dtm.open('r')
     reg = Region()
     plants = []
+    import ipdb; ipdb.set_trace()
     for line in vec:
         count = 0
         # args is prog, h,  q
@@ -320,13 +323,19 @@
     for pla in plants:
         power = pla.potential_power(efficiency=efficiency)
         if power > min_power:
+            for cat, ink in enumerate(pla.intakes):
+                if version == 70:
+                    new_vec.write(pla.line, (pla.id, pla.id_stream, power,
+                                         float(pla.restitution.discharge),
+                                         float(ink.elevation),
+                                         float(pla.restitution.elevation)))
+                else:
+                    new_vec.write(pla.line, cat=cat, attrs=(pla.id,
+                                  pla.id_stream, power,
-            for ink in pla.intakes:
-                new_vec.write(pla.line, (pla.id, pla.id_stream, power,
-                                     float(pla.restitution.discharge),
-                                     float(ink.elevation),
-                                     float(pla.restitution.elevation)))
     new_vec.table.conn.commit()
     new_vec.comment = (' '.join(sys.argv))
     #pdb.set_trace()
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-11-05 02:46:47 UTC (rev 66747)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-11-05 14:05:11 UTC (rev 66748)
@@ -848,6 +848,7 @@
 def main(opts, flgs):
     pid = os.getpid()
     pat = "tmprgreen_%i_*" % pid
     atexit.register(cleanup,
@@ -933,6 +934,7 @@
                                alpha=opts['alpha_inlet']))
     # add total inlet costs
     # TODO: to be check to avoid to count cost more than one time I have moltiplied by 0.5
     tot = ('tot_cost = (comp_cost_sum + em_cost + '
            'lin_pipe_cost + lin_electro_cost + '
            'station_cost + inlet_cost + {grid}*0.5) * '
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2015-11-05 02:46:47 UTC (rev 66747)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py	2015-11-05 14:05:11 UTC (rev 66748)
@@ -156,19 +156,14 @@
     DEBUG = flags['d']
     c = flags['c']
     msgr = get_msgr()
     #import ipdb; ipdb.set_trace()
-    TMPVEC = ['river_clean']
-    if not gcore.overwrite():
-        for m in TMPVEC:
-            if gcore.find_file(m)['name']:
-                msgr.fatal(_("Temporary vector %s exists") % (m))
     if c:
         msgr.message("\Clean rivers\n")
-        dissolve_lines(river, 'river_clean')
-        river = 'river_clean'
+        TMPVECT = [("tmprgreen_%i_clean*" % os.getpid())]
+        pid = os.getpid()
+        dissolve_lines(river, "tmprgreen_%i_clean*" % os.getpid())
+        river = "tmprgreen_%i_clean*" % pid
         # number of cell of the river
     # range for the solution
     msgr.message("\Loop on the category of segments\n")
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2015-11-05 02:46:47 UTC (rev 66747)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py	2015-11-05 14:05:11 UTC (rev 66748)
@@ -135,7 +135,7 @@
 #%option
 #% key: roughness_penstock
 #% type: double
-#% description: Roughness of the pensotck [mm]
+#% description: Roughness of the penstock [mm]
 #% required: no
 #% answer: 0.015
 #% guisection: Head losses
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-11-05 02:46:47 UTC (rev 66747)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-11-05 14:05:11 UTC (rev 66748)
@@ -5,7 +5,7 @@
 # MODULE:      r.green.hydro.potential
 # AUTHOR(S):   Giulia Garegnani, Pietro Zambelli
-# PURPOSE:     Calculate the theorethical hydropower energy potential for each basin and segments of river
+# PURPOSE:     Calculate the theoretical hydropower energy potential for each basin and segments of river
 # COPYRIGHT:   (C) 2014 by the GRASS Development Team
 #              This program is free software under the GNU General Public
@@ -29,7 +29,7 @@
 #% type: string
 #% gisprompt: old,cell,raster
 #% key_desc: name
-#% description: Name of river discharge [m3/s]
+#% description: Name of input river discharge raster map [m3/s]
 #% required: yes
 #%end
 #%option G_OPT_V_INPUT
@@ -37,7 +37,7 @@
 #% type: string
 #% gisprompt: old,vector,vector
 #% key_desc: name
-#% description: Name of river network
+#% description: Name of river network input vector map
 #% required: no
 #%end
@@ -45,7 +45,7 @@
 #% type: string
 #% key_desc: name
-#% description: Name of lakes
+#% description: Name of lakes input vector map
 #% required: no
 #%end
 #%option
@@ -83,7 +83,7 @@
 #% key: output
 #% type: string
 #% key_desc: name
-#% description: Name of vector map with basin potential
+#% description: Name of output vector map with basin potential
 #% required: yes
 #% guisection: Basin Potential
 #%END
Added: grass-addons/grass7/raster/r.green/r_green.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.green/r_green.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
