[GRASS-SVN] r66750 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Thu Nov 5 10:25:54 PST 2015
Author: ychemin
Date: 2015-11-05 10:25:54 -0800 (Thu, 05 Nov 2015)
New Revision: 66750
grass-addons/grass7/imagery/i.spec.sam/global.h
grass-addons/grass7/imagery/i.spec.sam/main.c
grass-addons/grass7/imagery/i.spec.sam/open.c
grass-addons/grass7/imagery/i.spec.sam/spectrum.dat
fixed matrix read, now breaks at checking matrix orthogonality
Modified: grass-addons/grass7/imagery/i.spec.sam/global.h
--- grass-addons/grass7/imagery/i.spec.sam/global.h 2015-11-05 14:12:13 UTC (rev 66749)
+++ grass-addons/grass7/imagery/i.spec.sam/global.h 2015-11-05 18:25:54 UTC (rev 66750)
@@ -13,7 +13,6 @@
#define MAXFILES 255
-extern mat_struct *A;
extern vec_struct *b, *Avector;
extern int matrixsize;
extern float curr_angle;
@@ -31,5 +30,5 @@
extern int error_fd;
extern char result_name[80];
-extern char *result_prefix, *matrixfile;
+extern char *result_prefix;
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2015-11-05 14:12:13 UTC (rev 66749)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2015-11-05 18:25:54 UTC (rev 66750)
@@ -40,12 +40,10 @@
struct GModule *module;
-mat_struct *A;
int matrixsize;
float curr_angle;
-char *group;
struct Ref Ref;
CELL **cell;
@@ -58,9 +56,9 @@
int error_fd;
-char *result_prefix, *matrixfile;
+char *result_prefix;
-int open_files();
+mat_struct *open_files(char * matrixfile, char *img_grp);
void spectral_angle();
CELL myround(double x);
@@ -78,6 +76,9 @@
struct Option *group, *matrixfile, *output;
} parm;
+ mat_struct *A; /*first use in open.c G_matrix_set()*/
+ char *group;
G_gisinit (argv[0]);
module = G_define_module();
@@ -88,13 +89,10 @@
parm.group = G_define_standard_option(G_OPT_I_GROUP);
- parm.group->description = "Imagery group containing images to be analyzed with Spectral Mixture Analyis";
+ parm.group->description = "Imagery group to target for Spectral Mixture Analyis";
- parm.matrixfile = G_define_option();
- parm.matrixfile->key = "matrixfile";
- parm.matrixfile->type = TYPE_STRING;
- parm.matrixfile->required = YES;
- parm.matrixfile->description = "Matrix file containing spectral signatures ";
+ parm.matrixfile = G_define_standard_option(G_OPT_F_INPUT);
+ parm.matrixfile->description = "Matrix file containing spectral signatures";
parm.output = G_define_option();
parm.output->key = "result";
@@ -106,13 +104,11 @@
G_fatal_error("Parsing arguments error");
result_prefix = parm.output->answer;
- group = parm.group->answer;
- matrixfile = parm.matrixfile->answer;
+ G_message("%s",result_prefix);
-/* here we go... */
- open_files();
+ /*Creating A, the spectral signature matrix here*/
+ A = open_files(parm.matrixfile->answer, parm.group->answer);
/* Spectral Matrix is stored in A now */
/* Check matrix orthogonality
@@ -121,6 +117,7 @@
* TM data. Photogrammetric Engineering & Remote Sensing, Vol.63, No6.
+ G_message("/* Check matrix orthogonality*/");
for (i = 0; i < Ref.nfiles; i++) /* Ref.nfiles = matrixsize*/
Avector = G_matvect_get_row(A, i); /* go columnwise through matrix*/
@@ -229,7 +226,7 @@
/* write a color table */
G_matrix_free(A);
- make_history(result_name, group, matrixfile);
+ make_history(result_name, parm.group->answer, parm.matrixfile->answer);
return(EXIT_SUCCESS);
} /* main*/
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c 2015-11-05 14:12:13 UTC (rev 66749)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c 2015-11-05 18:25:54 UTC (rev 66750)
@@ -2,7 +2,6 @@
* (c) Oct/1998 Markus Neteler, Hannover
-#include "global.h"
#include <stdio.h>
#include <math.h>
#include <grass/gis.h>
@@ -10,25 +9,35 @@
#include <grass/imagery.h>
#include <grass/gmath.h>
#include <grass/glocale.h>
+#include "global.h"
int G_matrix_read2(FILE * fp, mat_struct * out); /* Modified version of G_matrix_read(..). */
-int open_files()
+mat_struct *open_files(char *matrixfile, char *img_grp)
char *name, *mapset;
FILE *fp;
int i;
+ mat_struct A_input, *A;
-/* read in matrix file with spectral library */
+ /* read in matrix file with spectral library */
fp=fopen(matrixfile,"r");
if (fp == NULL)
G_fatal_error("ERROR: Matrixfile %s not found.\n",matrixfile);
/* Read data and close file */
- if ((G_matrix_read2(fp, A) < 0))
+ if ((G_matrix_read2(fp, &A_input) < 0))
G_fatal_error(_("Unable to read matrix file %s."), matrixfile);
fclose(fp);
+ G_message("matrixfile read");
+ A = G_matrix_init(A_input.rows, A_input.cols, A_input.rows);
+ if (A == NULL)
+ G_fatal_error(_("Unable to allocate memory for matrix"));
+ A = G_matrix_copy(&A_input);
if(A->rows < A->cols)
G_fatal_error("Need m (rows) >= n (cols) to obtain least squares fit\n");
/*Only for debug, so temporary disabled*/
@@ -41,15 +50,16 @@
matrixsize=A->cols;
+ G_message("/* open input files from group */");
- if (!I_find_group(group))
+ if (!I_find_group(img_grp))
- G_fatal_error("group=%s - not found\n", group);
+ G_fatal_error("group=%s - not found\n", img_grp);
- I_get_group_ref(group, &Ref);
+ I_get_group_ref(img_grp, &Ref);
if (Ref.nfiles <= 1)
- G_message("Group %s\n", group);
+ G_message("Group %s\n", img_grp);
if (Ref.nfiles <= 0)
G_message("doesn't have any files\n");
else
@@ -59,10 +69,11 @@
/* Error check: input file number must be equal to matrix size */
if (Ref.nfiles != matrixsize)
- G_message("Error: Number of %i input files in group <%s>\n", Ref.nfiles, group);
+ G_message("Error: Number of %i input files in group <%s>\n", Ref.nfiles, img_grp);
G_fatal_error(" does not match matrix size (%i cols).\n", A->cols);
+ G_message("/* get memory for input files */");
cell = (CELL **) G_malloc (Ref.nfiles * sizeof (CELL *));
cellfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
@@ -76,6 +87,7 @@
G_fatal_error("Unable to proceed\n");
+ G_message("/* open files for results*/");
result_cell = (CELL **) G_malloc (Ref.nfiles * sizeof (CELL *));
resultfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
@@ -87,8 +99,8 @@
resultfd[i] = Rast_open_c_new (result_name);
- return(matrixsize); /* give back number of output files (= Ref.nfiles) */
+ G_message("open.c: Returning A");
+ return A; /* give back number of output files (= Ref.nfiles) */
@@ -97,6 +109,7 @@
int rows, cols;
int i, j, row;
double val;
+ int err;
/* skip comments */
for (;;) {
@@ -111,19 +124,20 @@
return -1;
+ G_message("Set Matrix rows:%d by cols:%d",rows,cols);
+ err = G_matrix_set(out, rows, cols, rows);
+ G_message("Set Matrix rows:%d by cols:%d is done (err:%d)",rows,cols,err);
- G_matrix_set(out, rows, cols, rows);
for (i = 0; i < rows; i++) {
if (fscanf(fp, "row%d:", &row) != 1) {
- G_warning(_("Input format error"));
+ G_warning(_("Input format error at row %d"),row);
return -1;
for (j = 0; j < cols; j++) {
- if (fscanf(fp, "%lf:", &val) != 1) {
+ if (fscanf(fp, " %lf", &val) != 1) {
+ G_warning(_("Input format error at col %d"),j);
return -1;
Modified: grass-addons/grass7/imagery/i.spec.sam/spectrum.dat
--- grass-addons/grass7/imagery/i.spec.sam/spectrum.dat 2015-11-05 14:12:13 UTC (rev 66749)
+++ grass-addons/grass7/imagery/i.spec.sam/spectrum.dat 2015-11-05 18:25:54 UTC (rev 66750)
@@ -4,9 +4,10 @@
# 2. Saltbush
# 3. Ground
# 4. Dry Grass
+#row0: 8.87 13.14 11.71 35.85
Matrix: 4 by 4
-row0: 8.87 13.14 11.71 35.85
+row0: 8.87 13.14 11.71 35.85
row1: 13.59 20.12 19.61 50.66
row2: 28.26 34.82 38.27 40.1
row3: 10.54 16.35 23.7 38.98
