[GRASS-SVN] r66755 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Thu Nov 5 19:16:35 PST 2015
Author: annakrat
Date: 2015-11-05 19:16:35 -0800 (Thu, 05 Nov 2015)
New Revision: 66755
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
pygrass: fix GridModule on Windows, merge from trunk r66753, r66754
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py 2015-11-06 03:05:21 UTC (rev 66754)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py 2015-11-06 03:16:35 UTC (rev 66755)
@@ -2,6 +2,7 @@
from __future__ import (nested_scopes, generators, division, absolute_import,
with_statement, print_function, unicode_literals)
import os
+import sys
import multiprocessing as mltp
import subprocess as sub
import shutil as sht
@@ -115,7 +116,7 @@
with open(gisrc, 'r') as gfile:
gis = dict([(k.strip(), v.strip())
- for k, v in [row.split(':') for row in gfile]])
+ for k, v in [row.split(':', 1) for row in gfile]])
return gis['MAPSET'], gis['LOCATION_NAME'], gis['GISDBASE']
@@ -346,6 +347,7 @@
src, dst = get_mapset(gisrc_src, gisrc_dst)
env = os.environ.copy()
env['GISRC'] = gisrc_dst
+ shell = True if sys.platform == 'win32' else False
if mapnames:
inputs = dict(cmd['inputs'])
# reset the inputs to
@@ -353,16 +355,16 @@
inputs[key] = mapnames[key]
cmd['inputs'] = inputs.items()
# set the region to the tile
- sub.Popen(['g,region', 'raster=%s' % key], env=env).wait()
+ sub.Popen(['g.region', 'raster=%s' % key], shell=shell, env=env).wait()
else:
# set the computational region
lcmd = ['g.region', ]
lcmd.extend(["%s=%s" % (k, v) for k, v in bbox.items()])
- sub.Popen(lcmd, env=env).wait()
+ sub.Popen(lcmd, shell=shell, env=env).wait()
if groups:
copy_groups(groups, gisrc_src, gisrc_dst)
# run the grass command
- sub.Popen(get_cmd(cmd), env=env).wait()
+ sub.Popen(get_cmd(cmd), shell=shell, env=env).wait()
# remove temp GISRC
os.remove(gisrc_dst)
