[GRASS-SVN] r66760 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Fri Nov 6 06:21:23 PST 2015
Author: ychemin
Date: 2015-11-06 06:21:23 -0800 (Fri, 06 Nov 2015)
New Revision: 66760
grass-addons/grass7/imagery/i.spec.sam/global.h
grass-addons/grass7/imagery/i.spec.sam/main.c
grass-addons/grass7/imagery/i.spec.sam/open.c
grass-addons/grass7/imagery/i.spec.sam/spec_angle.c
Fixed CELL to DCELL throughout, fixed spec_angle tmp vect
Modified: grass-addons/grass7/imagery/i.spec.sam/global.h
--- grass-addons/grass7/imagery/i.spec.sam/global.h 2015-11-06 13:59:48 UTC (rev 66759)
+++ grass-addons/grass7/imagery/i.spec.sam/global.h 2015-11-06 14:21:23 UTC (rev 66760)
@@ -20,13 +20,13 @@
extern char *group;
extern struct Ref Ref;
-extern CELL **cell;
+extern DCELL **cell;
extern int *cellfd;
-extern CELL **result_cell;
+extern DCELL **result_cell;
extern int *resultfd;
-extern CELL **error_cell;
+extern DCELL **error_cell;
extern int error_fd;
extern char result_name[80];
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2015-11-06 13:59:48 UTC (rev 66759)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2015-11-06 14:21:23 UTC (rev 66760)
@@ -45,21 +45,21 @@
struct Ref Ref;
-CELL **cell;
+DCELL **cell;
int *cellfd;
-CELL **result_cell;
+DCELL **result_cell;
int *resultfd;
-CELL **error_cell;
+DCELL **error_cell;
int error_fd;
char *result_prefix;
mat_struct *open_files(char * matrixfile, char *img_grp);
-float spectral_angle();
-CELL myround(double x);
+float spectral_angle(vec_struct * Avector1, vec_struct * Avector2, int vtype);
+DCELL myround(double x);
int main(int argc,char * argv[])
@@ -125,7 +125,7 @@
if (j !=i)
b = G_matvect_get_row(A, j); /* compare with next col in A */
- spectangle = spectral_angle(Avector, b);
+ spectangle = spectral_angle(Avector, b, RVEC);
anglefield[i][j]= spectangle;
G_vector_free(b);
@@ -161,9 +161,9 @@
* using singular value decomposition. IGARSS 1989: 12th Canadian
* symposium on Remote Sensing. Vol.4 pp.2069-2072
- G_message("Singular values ouput vector init");
+ G_verbose_message("Singular values ouput vector init");
double *svdvalues = G_alloc_vector(A->cols);
- G_message("Singular values of Matrix A: copy A into double **");
+ G_verbose_message("Singular values of Matrix A: copy A into double **");
double **Avals = G_alloc_matrix(A->cols,A->rows);
int count=0;
for (i = 0; i < A->cols ; i++){
@@ -172,35 +172,34 @@
count++;
- G_message("Singular values of Matrix A: run svdval");
- if(G_math_svdval( svdvalues, Avals, A->cols, A->rows))
+ G_verbose_message("Singular values of Matrix A: run svdval");
+ if(G_math_svdval(svdvalues, Avals, A->cols, A->rows))
G_fatal_error("Error in singular value decomposition, exiting...\n");
- G_message("/*Experimental: display values (replace v_output() in original version)*/");
- /*Experimental: display values (replace v_output() in original version)*/
+ G_verbose_message("/*display values (replace v_output() in original version)*/");
+ /*display values (replace v_output() in original version)*/
for(i=0;i<A->cols;i++)
G_message("%f", svdvalues[i]);
- G_message("/* alright, start Spectral angle mapping */");
+ G_verbose_message("/* alright, start Spectral angle mapping */");
nrows = Rast_window_rows();
ncols = Rast_window_cols();
G_verbose_message("Calculating for %i x %i = %i pixels:\n",nrows,ncols, (ncols * ncols));
G_verbose_message("%s ... ", G_program_name());
- G_message("Calculating for %i x %i = %i pixels:\n",nrows,ncols, (ncols * ncols));
G_message("%s ... ", G_program_name());
for (row = 0; row < nrows; row++) /* rows loop*/
G_percent(row, nrows, 2);
for (band = 0; band < Ref.nfiles; band++) /* get row for all bands*/
- Rast_get_c_row (cellfd[band], cell[band], row);
+ Rast_get_d_row (cellfd[band], cell[band], row);
for (col = 0; col < ncols; col++) /* cols loop, work pixelwise for all bands */
/* get pixel values of each band and store in b vector: */
/*b = v_get(A->m);*/ /* m=rows; dimension of vector = matrix size = Ref.nfiles*/
- b = G_vector_init(A->rows,A->rows,RVEC);
+ b = G_vector_init(A->cols,A->cols,CVEC);
for (band = 0; band < Ref.nfiles-1; band++)
b->vals[band] = cell[band][col]; /* read input vector */
@@ -209,8 +208,9 @@
* and write result in full degree */
for (i = 0; i < Ref.nfiles; i++) /* Ref.nfiles = matrixsize*/
- Avector = G_matvect_get_row(A, i); /* go row-wise through matrix*/
+ Avector = G_matvect_get_column(A, i); /* go row-wise through matrix*/
+ G_verbose_message("Av: %f %f %f %f",Avector->vals[0],Avector->vals[1],Avector->vals[2],Avector->vals[3]);
+ spectangle = spectral_angle(Avector, b, CVEC);
result_cell[i][col] = myround (spectangle);
G_vector_free(Avector);
@@ -220,7 +220,8 @@
/* write the resulting rows: */
- Rast_put_c_row (resultfd[i], result_cell[i]);
+ for (i = 0; i < Ref.nfiles; i++)
+ Rast_put_d_row (resultfd[i], result_cell[i]);
} /* rows loop */
@@ -242,9 +243,9 @@
} /* main*/
-CELL myround (double x)
+DCELL myround (double x)
- CELL n;
+ DCELL n;
if (x >= 0.0)
n = x + .5;
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c 2015-11-06 13:59:48 UTC (rev 66759)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c 2015-11-06 14:21:23 UTC (rev 66760)
@@ -32,11 +32,11 @@
G_message("matrixfile read");
- A = G_matrix_init(A_input.rows, A_input.cols, A_input.rows);
+ A = G_matrix_init(A_input.cols, A_input.rows, A_input.cols);/*changed r/c*/
if (A == NULL)
G_fatal_error(_("Unable to allocate memory for matrix"));
- A = G_matrix_copy(&A_input);
+ A = G_matrix_transpose(&A_input);/*transposed for spec angle process*/
if(A->rows < A->cols)
G_fatal_error("Need m (rows) >= n (cols) to obtain least squares fit\n");
@@ -48,7 +48,7 @@
m_output(A);
- matrixsize=A->cols;
+ matrixsize=A->rows; /*changed cols to rows*/
G_message("/* open input files from group */");
@@ -75,11 +75,11 @@
G_message("/* get memory for input files */");
- cell = (CELL **) G_malloc (Ref.nfiles * sizeof (CELL *));
+ cell = (DCELL **) G_malloc (Ref.nfiles * sizeof (DCELL *));
cellfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
for (i=0; i < Ref.nfiles; i++)
- cell[i] = Rast_allocate_c_buf();
+ cell[i] = Rast_allocate_d_buf();
name = Ref.file[i].name;
mapset = Ref.file[i].mapset;
G_verbose_message("Opening input file no. %i [%s]\n", (i+1), name);
@@ -89,14 +89,14 @@
G_message("/* open files for results*/");
- result_cell = (CELL **) G_malloc (Ref.nfiles * sizeof (CELL *));
+ result_cell = (DCELL **) G_malloc (Ref.nfiles * sizeof (DCELL *));
resultfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
sprintf(result_name, "%s.%d", result_prefix, (i+1));
G_verbose_message("Opening output file [%s]\n", result_name);
- result_cell[i] = Rast_allocate_c_buf();
- resultfd[i] = Rast_open_c_new (result_name);
+ result_cell[i] = Rast_allocate_d_buf();
+ resultfd[i] = Rast_open_new (result_name, DCELL_TYPE);
G_message("open.c: Returning A");
Modified: grass-addons/grass7/imagery/i.spec.sam/spec_angle.c
--- grass-addons/grass7/imagery/i.spec.sam/spec_angle.c 2015-11-06 13:59:48 UTC (rev 66759)
+++ grass-addons/grass7/imagery/i.spec.sam/spec_angle.c 2015-11-06 14:21:23 UTC (rev 66760)
@@ -30,7 +30,7 @@
* Geocarto International, Vol.12, no.3 (Sept.). pp. 27-40
-float spectral_angle(vec_struct * Avector1, vec_struct * Avector2)
vec_struct *vtmp1;
double norm1, norm2, norm3;
@@ -38,8 +38,16 @@
/* Measure spectral angle */
/* multiply one A column with second */
- vtmp1 = G_vector_init (Avector1->cols, Avector1->cols, RVEC);
- vtmp1 = G_vector_product(Avector1, Avector2,vtmp1);
+ if(vtype == RVEC){
+ G_verbose_message("spec_angle.c: Using RVEC type for vtmp1");
+ /*vtmp1 = G_vector_init (Avector1->cols, Avector1->cols, RVEC);*/
+ vtmp1 = G_vector_copy(Avector1, RVEC);
+ }else{
+ G_verbose_message("spec_angle.c: Using CVEC type for vtmp1");
+ /*vtmp1 = G_vector_init (Avector1->cols, Avector1->cols, CVEC);*/
+ vtmp1 = G_vector_copy(Avector1, CVEC);
+ vtmp1 = G_vector_product(Avector1, Avector2, vtmp1);
norm1 = G_vector_norm1(vtmp1); /* calculate 1-norm */
norm2 = G_vector_norm_euclid(Avector1); /* calculate 2-norm (Euclidean) */
norm3 = G_vector_norm_euclid(Avector2); /* calculate 2-norm (Euclidean) */
