[GRASS-SVN] r66764 - in grass-addons/grass7/raster/r.futures: r.futures.calib r.futures.pga
svn_grass at osgeo.org
Sat Nov 7 14:40:19 PST 2015
Author: annakrat
Date: 2015-11-07 14:40:19 -0800 (Sat, 07 Nov 2015)
New Revision: 66764
grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
grass-addons/grass7/raster/r.futures/r.futures.pga/r.futures.pga.html
r.futures: fix calibration tool (better error handling, fix writing to a file), fix documentation in PGA
Modified: grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
--- grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py 2015-11-07 12:04:10 UTC (rev 66763)
+++ grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py 2015-11-07 22:40:19 UTC (rev 66764)
@@ -214,6 +214,7 @@
import grass.script.core as gcore
import grass.script.raster as grast
import grass.script.utils as gutils
+from grass.exceptions import CalledModuleError
TMP = []
@@ -250,9 +251,15 @@
sum_dist_compactness = 0
for i in range(repeat):
gcore.message(_("Running FUTURES simulation {i}/{repeat}...".format(i=i + 1, repeat=repeat)))
- run_simulation(development_start=development_start, development_end=simulation_dev_end,
- compactness_mean=compactness_mean, compactness_range=compactness_range,
- discount_factor=discount_factor, patches_file=patches_file, fut_options=fut_options)
+ try:
+ run_simulation(development_start=development_start, development_end=simulation_dev_end,
+ compactness_mean=compactness_mean, compactness_range=compactness_range,
+ discount_factor=discount_factor, patches_file=patches_file, fut_options=fut_options)
+ except CalledModuleError, e:
+ queue.put(None)
+ cleanup(tmp=TMP_PROCESS)
+ gcore.error(_("Running r.futures.pga failed. Details: {e}").format(e=e))
+ return
new_development(simulation_dev_end, simulation_dev_diff)
temp_file = tempfile.NamedTemporaryFile(delete=False)
@@ -422,32 +429,34 @@
'input_compactness_mean', 'input_compactness_range',
'compactness_distance']))
f.write('\n')
- for com_mean in compactness_means:
- for com_range in compactness_ranges:
- for discount_factor in discount_factors:
- count += 1
- q = Queue()
- p = Process(target=run_one_combination,
- args=(repeat, dev_start, com_mean, com_range,
- discount_factor, patches_file, options, threshold,
- hist_bins_area_orig, hist_range_area_orig, hist_bins_compactness_orig,
- hist_range_compactness_orig, cell_size, histogram_area_orig, histogram_compactness_orig,
- tmp_name, q))
- p.start()
- queue_list.append(q)
- proc_list.append(p)
- proc_count += 1
- if proc_count == nprocs or count == num_all:
- for i in range(proc_count):
- proc_list[i].join()
- data = queue_list[i].get()
- f.write(' '.join([str(data['input_discount_factor']), str(data['area_distance']),
- str(data['input_compactness_mean']), str(data['input_compactness_range']),
- str(data['compactness_distance'])]))
- f.write('\n')
- proc_count = 0
- proc_list = []
- queue_list = []
+ for com_mean in compactness_means:
+ for com_range in compactness_ranges:
+ for discount_factor in discount_factors:
+ count += 1
+ q = Queue()
+ p = Process(target=run_one_combination,
+ args=(repeat, dev_start, com_mean, com_range,
+ discount_factor, patches_file, options, threshold,
+ hist_bins_area_orig, hist_range_area_orig, hist_bins_compactness_orig,
+ hist_range_compactness_orig, cell_size, histogram_area_orig, histogram_compactness_orig,
+ tmp_name, q))
+ p.start()
+ queue_list.append(q)
+ proc_list.append(p)
+ proc_count += 1
+ if proc_count == nprocs or count == num_all:
+ for i in range(proc_count):
+ proc_list[i].join()
+ data = queue_list[i].get()
+ if not data:
+ continue
+ f.write(' '.join([str(data['input_discount_factor']), str(data['area_distance']),
+ str(data['input_compactness_mean']), str(data['input_compactness_range']),
+ str(data['compactness_distance'])]))
+ f.write('\n')
+ proc_count = 0
+ proc_list = []
+ queue_list = []
if __name__ == "__main__":
options, flags = gcore.parser()
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/r.futures.pga.html
--- grass-addons/grass7/raster/r.futures/r.futures.pga/r.futures.pga.html 2015-11-07 12:04:10 UTC (rev 66763)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/r.futures.pga.html 2015-11-07 22:40:19 UTC (rev 66764)
@@ -50,9 +50,11 @@
<div class="code"><pre>
import numpy as np
power = 2
-x = np.linspace(0, 1, 1001)
-np.savetxt(fname="incentive_table.txt", fmt='%1.3f', delimiter=',',
- X=np.column_stack((x, np.power(x, power))))
+length = 1001
+x = np.linspace(0, 1, length)
+np.savetxt(fname="incentive_table.txt", fmt='%1.3f', delimiter=',',
+ X=np.column_stack((x, np.power(x, power))),
+ header=",{}".format(length), comments='')
</pre></div>
<center>
