[GRASS-SVN] r66778 - grass-addons/grass7/imagery/i.segment.stats
Wed Nov 11 06:36:09 PST 2015
Author: mlennert
Date: 2015-11-11 06:36:09 -0800 (Wed, 11 Nov 2015)
New Revision: 66778
   grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
correct use of findfile for rasters ('cell') and respect region settings except if flag is used
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py	2015-11-10 21:53:54 UTC (rev 66777)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py	2015-11-11 14:36:09 UTC (rev 66778)
@@ -69,7 +69,12 @@
 #%rules
 #% required: csvfile,vectormap
 #%end
+#% flag
+#% key: r
+#% description: Adjust region to input map
+#%END
 import os
 import atexit
 import collections
@@ -82,7 +87,7 @@
     if grass.find_file(temporary_vect, element='vector')['name']:
             grass.run_command('g.remove', flags='f', type_='vector',
                     name=temporary_vect, quiet=True)
-    if grass.find_file(temporary_clumped_rast, element='raster')['name']:
+    if grass.find_file(temporary_clumped_rast, element='cell')['name']:
             grass.run_command('g.remove', flags='f', type_='raster',
                     name=temporary_clumped_rast, quiet=True)
     if insert_sql:
@@ -91,7 +96,6 @@
 def main():
-    grass.use_temp_region()
     segment_map = options['map']
     csvfile = options['csvfile'] if options['csvfile'] else []
@@ -117,7 +121,10 @@
             'coeff_var': 11, 'variance': 10, 'sum_abs': 13, 'perc_90': 17,
             'mean': 7}
-    grass.run_command('g.region', raster=segment_map)
+    if flags['r']:
+        grass.use_temp_region()
+        grass.run_command('g.region', raster=segment_map)
     grass.run_command('r.clump',
                       input_=segment_map,
                       output=temporary_clumped_rast,
