[GRASS-SVN] r66780 - grass/trunk/lib/init
Wed Nov 11 07:15:48 PST 2015
Author: martinl
Date: 2015-11-11 07:15:48 -0800 (Wed, 11 Nov 2015)
New Revision: 66780
   grass/trunk/lib/init/variables.html
variables: formatting cosmetics
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2015-11-11 15:15:19 UTC (rev 66779)
+++ grass/trunk/lib/init/variables.html	2015-11-11 15:15:48 UTC (rev 66780)
@@ -299,17 +299,14 @@
     GRASS session is quited.</dd>
   <dt>GRASS_VECTOR_TMPDIR_MAPSET</dt>
-  <dd> By default GRASS temporary directory is located in
+  <dd>[vectorlib]<br> By default GRASS temporary directory is located in
   <tt>$LOCATION/$MAPSET/.tmp/$HOSTNAME</tt>. If GRASS_VECTOR_TMPDIR_MAPSET is
   set to '0', the temporary directory is located in TMPDIR
   (environmental variable defined by the user or GRASS initialization
-  script if not given).
-  <p>
+  script if not given).<br>
   Important note: This variable is currently used only in vector
   library. In other words the variable is ignored by raster or
-  raster3d library.
-  </dd>
+  raster3d library.</dd>
   <dt>GRASS_VECTOR_TOPO_DEBUG</dt>
   <dd>[vectorlib, v.generalize]<br> If the environment variable
