[GRASS-SVN] r66790 - grass-addons/grass7/raster/r.subdayprecip.design
svn_grass at osgeo.org
Wed Nov 11 08:48:45 PST 2015
Author: martinl
Date: 2015-11-11 08:48:45 -0800 (Wed, 11 Nov 2015)
New Revision: 66790
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
r.subdayprecip.design: move coeffictient compupation into separate function
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2015-11-11 16:46:52 UTC (rev 66789)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2015-11-11 16:48:45 UTC (rev 66790)
@@ -48,6 +48,71 @@
from grass.pygrass.modules import Module
from grass.exceptions import CalledModuleError
+def coeff(name, rl):
+ a = c = None
+ if name == 'H_002':
+ if rl < 40:
+ a = 0.166
+ c = 0.701
+ elif rl < 120:
+ a = 0.237
+ c = 0.803
+ elif rl < 1440:
+ a = 0.235
+ c = 0.801
+ elif name == 'H_005':
+ if rl < 40:
+ a = 0.171
+ c = 0.688
+ elif rl <120:
+ a = 0.265
+ c = 0.803
+ elif rl < 1440:
+ a = 0.324
+ c = 0.845
+ elif name == 'H_010':
+ if rl < 40:
+ a = 0.163
+ c = 0.656
+ elif rl <120:
+ a = 0.280
+ c = 0.803
+ elif rl < 1440:
+ a = 0.380
+ c = 0.867
+ elif name == 'H_020':
+ if rl < 40:
+ a = 0.169
+ c = 0.648
+ elif rl > 40 and rl < 120:
+ a = 0.300
+ c = 0.803
+ elif rl < 1440:
+ a = 0.463
+ c = 0.894
+ elif name == 'H_050':
+ if rl < 40:
+ a = 0.174
+ c = 0.638
+ elif rl < 120:
+ a = 0.323
+ c = 0.803
+ elif rl < 1440:
+ a = 0.580
+ c = 0.925
+ elif name == 'H_100':
+ if rl < 40:
+ a = 0.173
+ c = 0.625
+ elif rl < 120:
+ a = 0.335
+ c = 0.803
+ elif rl < 1440:
+ a = 0.642
+ c = 0.939
+ return a, c
def main():
# get list of existing columns
try:
@@ -73,9 +138,12 @@
# perform zonal statistics
grass.message('Processing <{}>...'.format(rast))
table = '{}_table'.format(name)
- # TODO: handle null values
Module('v.rast.stats', flags='c', map=opt['map'], raster=rast,
column_prefix=name, method='average', quiet=True)
+ # TODO: handle null values (very small areas)
+ # Module('v.what.rast', map=opt['map'], raster=rast, type='centroid',
+ # column='{}_average'.format(name),
+ # where='{}_average is NULL'.format(name))
# add column to the attribute table if not exists
rl = float(opt['rainlength'])
@@ -85,68 +153,7 @@
columns='{} double precision'.format(field_name))
# determine coefficient for calculation
- a = c = None
- if name == 'H_002':
- if rl < 40:
- a = 0.166
- c = 0.701
- elif rl < 120:
- a = 0.237
- c = 0.803
- elif rl < 1440:
- a = 0.235
- c = 0.801
- elif name == 'H_005':
- if rl < 40:
- a = 0.171
- c = 0.688
- elif rl <120:
- a = 0.265
- c = 0.803
- elif rl < 1440:
- a = 0.324
- c = 0.845
- elif name == 'H_010':
- if rl < 40:
- a = 0.163
- c = 0.656
- elif rl <120:
- a = 0.280
- c = 0.803
- elif rl < 1440:
- a = 0.380
- c = 0.867
- elif name == 'H_020':
- if rl < 40:
- a = 0.169
- c = 0.648
- elif rl > 40 and rl < 120:
- a = 0.300
- c = 0.803
- elif rl < 1440:
- a = 0.463
- c = 0.894
- elif name == 'H_050':
- if rl < 40:
- a = 0.174
- c = 0.638
- elif rl < 120:
- a = 0.323
- c = 0.803
- elif rl < 1440:
- a = 0.580
- c = 0.925
- elif name == 'H_100':
- if rl < 40:
- a = 0.173
- c = 0.625
- elif rl < 120:
- a = 0.335
- c = 0.803
- elif rl < 1440:
- a = 0.642
- c = 0.939
+ a, c = coeff(rast, rl)
if a is None or c is None:
grass.fatal("Unable to calculate coefficients")
