[GRASS-SVN] r66817 - in grass/trunk/lib/db: dbmi_base dbmi_driver
svn_grass at osgeo.org
Thu Nov 12 01:30:26 PST 2015
Author: glynn
Date: 2015-11-12 01:30:26 -0800 (Thu, 12 Nov 2015)
New Revision: 66817
Added:
grass/trunk/lib/db/dbmi_base/dbstubs.h
Removed:
grass/trunk/lib/db/dbmi_driver/dbstubs.h
grass/trunk/lib/db/dbmi_base/Makefile
grass/trunk/lib/db/dbmi_driver/Makefile
Move dbstubs.h to fix build failures from r66773
Modified: grass/trunk/lib/db/dbmi_base/Makefile
--- grass/trunk/lib/db/dbmi_base/Makefile 2015-11-11 20:53:45 UTC (rev 66816)
+++ grass/trunk/lib/db/dbmi_base/Makefile 2015-11-12 09:30:26 UTC (rev 66817)
@@ -6,7 +6,7 @@
include $(MODULE_TOPDIR)/include/Make/Lib.make
-default: lib
+default: lib $(ARCH_INCDIR)/dbstubs.h
Copied: grass/trunk/lib/db/dbmi_base/dbstubs.h (from rev 66816, grass/trunk/lib/db/dbmi_driver/dbstubs.h)
--- grass/trunk/lib/db/dbmi_base/dbstubs.h (rev 0)
+++ grass/trunk/lib/db/dbmi_base/dbstubs.h 2015-11-12 09:30:26 UTC (rev 66817)
@@ -0,0 +1,102 @@
+#ifndef DBSTUBS_H
+#define DBSTUBS_H
+extern int db__driver_add_column(dbString *, dbColumn *);
+extern int db__driver_bind_update(dbCursor *);
+extern int db__driver_close_cursor(dbCursor *);
+extern int db__driver_close_database(void);
+extern int db__driver_create_index(dbIndex *);
+extern int db__driver_create_table(dbTable *);
+extern int db__driver_create_database(dbHandle *);
+extern int db__driver_delete(dbCursor *);
+extern int db__driver_delete_database(dbHandle *);
+extern int db__driver_describe_table(dbString *, dbTable **);
+extern int db__driver_drop_column(dbString *, dbString *);
+extern int db__driver_drop_index(dbString *);
+extern int db__driver_drop_table(dbString *);
+extern int db__driver_execute_immediate(dbString *);
+extern int db__driver_fetch(dbCursor *, int, int *);
+extern int db__driver_find_database(dbHandle *, int *);
+extern int db__driver_finish(void);
+extern int db__driver_init(int, char **);
+extern int db__driver_insert(dbCursor *);
+extern int db__driver_list_indexes(dbString *, dbIndex **, int *);
+extern int db__driver_list_tables(dbString **, int *, int);
+extern int db__driver_list_databases(dbString *, int, dbHandle **, int *);
+extern int db__driver_open_insert_cursor(dbCursor *);
+extern int db__driver_open_select_cursor(dbString *, dbCursor *, int);
+extern int db__driver_open_update_cursor(dbString *, dbString *, dbCursor *, int);
+extern int db__driver_open_database(dbHandle *);
+extern int db__driver_grant_on_table(dbString *, int, int);
+extern int db__driver_get_num_rows(dbCursor *);
+extern int db__driver_begin_transaction(void);
+extern int db__driver_commit_transaction(void);
+extern int db__driver_update(dbCursor *);
+#ifdef DB_DRIVER_C
+int (*db_driver_add_column) (dbString *, dbColumn *) = db__driver_add_column;
+int (*db_driver_bind_update) (dbCursor *) = db__driver_bind_update;
+int (*db_driver_close_cursor) (dbCursor *) = db__driver_close_cursor;
+int (*db_driver_close_database) (void) = db__driver_close_database;
+int (*db_driver_create_index) (dbIndex *) = db__driver_create_index;
+int (*db_driver_create_table) (dbTable *) = db__driver_create_table;
+int (*db_driver_create_database) (dbHandle *) = db__driver_create_database;
+int (*db_driver_delete) (dbCursor *) = db__driver_delete;
+int (*db_driver_delete_database) (dbHandle *) = db__driver_delete_database;
+int (*db_driver_describe_table) (dbString *, dbTable **) = db__driver_describe_table;
+int (*db_driver_drop_column) (dbString *, dbString *) = db__driver_drop_column;
+int (*db_driver_drop_index) (dbString *) = db__driver_drop_index;
+int (*db_driver_drop_table) (dbString *) = db__driver_drop_table;
+int (*db_driver_execute_immediate) (dbString *) = db__driver_execute_immediate;
+int (*db_driver_fetch) (dbCursor *, int, int *) = db__driver_fetch;
+int (*db_driver_find_database) (dbHandle *, int *) = db__driver_find_database;
+int (*db_driver_finish) (void) = db__driver_finish;
+int (*db_driver_init) (int, char **) = db__driver_init;
+int (*db_driver_insert) (dbCursor *) = db__driver_insert;
+int (*db_driver_list_indexes) (dbString *, dbIndex **, int *) = db__driver_list_indexes;
+int (*db_driver_list_tables) (dbString **, int *, int) = db__driver_list_tables;
+int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *) = db__driver_list_databases;
+int (*db_driver_open_insert_cursor) (dbCursor *) = db__driver_open_insert_cursor;
+int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int) = db__driver_open_select_cursor;
+int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int) = db__driver_open_update_cursor;
+int (*db_driver_open_database) (dbHandle *) = db__driver_open_database;
+int (*db_driver_grant_on_table) (dbString *, int, int) = db__driver_grant_on_table;
+int (*db_driver_get_num_rows) (dbCursor *) = db__driver_get_num_rows;
+int (*db_driver_begin_transaction) (void) = db__driver_begin_transaction;
+int (*db_driver_commit_transaction) (void) = db__driver_commit_transaction;
+int (*db_driver_update) (dbCursor *) = db__driver_update;
+#else
+extern int (*db_driver_add_column) (dbString *, dbColumn *);
+extern int (*db_driver_bind_update) (dbCursor *);
+extern int (*db_driver_close_cursor) (dbCursor *);
+extern int (*db_driver_close_database) (void);
+extern int (*db_driver_create_index) (dbIndex *);
+extern int (*db_driver_create_table) (dbTable *);
+extern int (*db_driver_create_database) (dbHandle *);
+extern int (*db_driver_delete) (dbCursor *);
+extern int (*db_driver_delete_database) (dbHandle *);
+extern int (*db_driver_describe_table) (dbString *, dbTable **);
+extern int (*db_driver_drop_column) (dbString *, dbString *);
+extern int (*db_driver_drop_index) (dbString *);
+extern int (*db_driver_drop_table) (dbString *);
+extern int (*db_driver_execute_immediate) (dbString *);
+extern int (*db_driver_fetch) (dbCursor *, int, int *);
+extern int (*db_driver_find_database) (dbHandle *, int *);
+extern int (*db_driver_finish) (void);
+extern int (*db_driver_init) (int, char **);
+extern int (*db_driver_insert) (dbCursor *);
+extern int (*db_driver_list_indexes) (dbString *, dbIndex **, int *);
+extern int (*db_driver_list_tables) (dbString **, int *, int);
+extern int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *);
+extern int (*db_driver_open_insert_cursor) (dbCursor *);
+extern int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int);
+extern int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int);
+extern int (*db_driver_open_database) (dbHandle *);
+extern int (*db_driver_grant_on_table) (dbString *, int, int);
+extern int (*db_driver_get_num_rows) (dbCursor *);
+extern int (*db_driver_begin_transaction) (void);
+extern int (*db_driver_commit_transaction) (void);
+extern int (*db_driver_update) (dbCursor *);
+#endif
+#endif
Modified: grass/trunk/lib/db/dbmi_driver/Makefile
--- grass/trunk/lib/db/dbmi_driver/Makefile 2015-11-11 20:53:45 UTC (rev 66816)
+++ grass/trunk/lib/db/dbmi_driver/Makefile 2015-11-12 09:30:26 UTC (rev 66817)
@@ -6,5 +6,5 @@
-default: lib $(ARCH_INCDIR)/dbstubs.h
+default: lib
Deleted: grass/trunk/lib/db/dbmi_driver/dbstubs.h
--- grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-11 20:53:45 UTC (rev 66816)
+++ grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-12 09:30:26 UTC (rev 66817)
@@ -1,102 +0,0 @@
-#ifndef DBSTUBS_H
-#define DBSTUBS_H
-extern int db__driver_add_column(dbString *, dbColumn *);
-extern int db__driver_bind_update(dbCursor *);
-extern int db__driver_close_cursor(dbCursor *);
-extern int db__driver_close_database(void);
-extern int db__driver_create_index(dbIndex *);
-extern int db__driver_create_table(dbTable *);
-extern int db__driver_create_database(dbHandle *);
-extern int db__driver_delete(dbCursor *);
-extern int db__driver_delete_database(dbHandle *);
-extern int db__driver_describe_table(dbString *, dbTable **);
-extern int db__driver_drop_column(dbString *, dbString *);
-extern int db__driver_drop_index(dbString *);
-extern int db__driver_drop_table(dbString *);
-extern int db__driver_execute_immediate(dbString *);
-extern int db__driver_fetch(dbCursor *, int, int *);
-extern int db__driver_find_database(dbHandle *, int *);
-extern int db__driver_finish(void);
-extern int db__driver_init(int, char **);
-extern int db__driver_insert(dbCursor *);
-extern int db__driver_list_indexes(dbString *, dbIndex **, int *);
-extern int db__driver_list_tables(dbString **, int *, int);
-extern int db__driver_list_databases(dbString *, int, dbHandle **, int *);
-extern int db__driver_open_insert_cursor(dbCursor *);
-extern int db__driver_open_select_cursor(dbString *, dbCursor *, int);
-extern int db__driver_open_update_cursor(dbString *, dbString *, dbCursor *, int);
-extern int db__driver_open_database(dbHandle *);
-extern int db__driver_grant_on_table(dbString *, int, int);
-extern int db__driver_get_num_rows(dbCursor *);
-extern int db__driver_begin_transaction(void);
-extern int db__driver_commit_transaction(void);
-extern int db__driver_update(dbCursor *);
-#ifdef DB_DRIVER_C
-int (*db_driver_add_column) (dbString *, dbColumn *) = db__driver_add_column;
-int (*db_driver_bind_update) (dbCursor *) = db__driver_bind_update;
-int (*db_driver_close_cursor) (dbCursor *) = db__driver_close_cursor;
-int (*db_driver_close_database) (void) = db__driver_close_database;
-int (*db_driver_create_index) (dbIndex *) = db__driver_create_index;
-int (*db_driver_create_table) (dbTable *) = db__driver_create_table;
-int (*db_driver_create_database) (dbHandle *) = db__driver_create_database;
-int (*db_driver_delete) (dbCursor *) = db__driver_delete;
-int (*db_driver_delete_database) (dbHandle *) = db__driver_delete_database;
-int (*db_driver_describe_table) (dbString *, dbTable **) = db__driver_describe_table;
-int (*db_driver_drop_column) (dbString *, dbString *) = db__driver_drop_column;
-int (*db_driver_drop_index) (dbString *) = db__driver_drop_index;
-int (*db_driver_drop_table) (dbString *) = db__driver_drop_table;
-int (*db_driver_execute_immediate) (dbString *) = db__driver_execute_immediate;
-int (*db_driver_fetch) (dbCursor *, int, int *) = db__driver_fetch;
-int (*db_driver_find_database) (dbHandle *, int *) = db__driver_find_database;
-int (*db_driver_finish) (void) = db__driver_finish;
-int (*db_driver_init) (int, char **) = db__driver_init;
-int (*db_driver_insert) (dbCursor *) = db__driver_insert;
-int (*db_driver_list_indexes) (dbString *, dbIndex **, int *) = db__driver_list_indexes;
-int (*db_driver_list_tables) (dbString **, int *, int) = db__driver_list_tables;
-int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *) = db__driver_list_databases;
-int (*db_driver_open_insert_cursor) (dbCursor *) = db__driver_open_insert_cursor;
-int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int) = db__driver_open_select_cursor;
-int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int) = db__driver_open_update_cursor;
-int (*db_driver_open_database) (dbHandle *) = db__driver_open_database;
-int (*db_driver_grant_on_table) (dbString *, int, int) = db__driver_grant_on_table;
-int (*db_driver_get_num_rows) (dbCursor *) = db__driver_get_num_rows;
-int (*db_driver_begin_transaction) (void) = db__driver_begin_transaction;
-int (*db_driver_commit_transaction) (void) = db__driver_commit_transaction;
-int (*db_driver_update) (dbCursor *) = db__driver_update;
-#else
-extern int (*db_driver_add_column) (dbString *, dbColumn *);
-extern int (*db_driver_bind_update) (dbCursor *);
-extern int (*db_driver_close_cursor) (dbCursor *);
-extern int (*db_driver_close_database) (void);
-extern int (*db_driver_create_index) (dbIndex *);
-extern int (*db_driver_create_table) (dbTable *);
-extern int (*db_driver_create_database) (dbHandle *);
-extern int (*db_driver_delete) (dbCursor *);
-extern int (*db_driver_delete_database) (dbHandle *);
-extern int (*db_driver_describe_table) (dbString *, dbTable **);
-extern int (*db_driver_drop_column) (dbString *, dbString *);
-extern int (*db_driver_drop_index) (dbString *);
-extern int (*db_driver_drop_table) (dbString *);
-extern int (*db_driver_execute_immediate) (dbString *);
-extern int (*db_driver_fetch) (dbCursor *, int, int *);
-extern int (*db_driver_find_database) (dbHandle *, int *);
-extern int (*db_driver_finish) (void);
-extern int (*db_driver_init) (int, char **);
-extern int (*db_driver_insert) (dbCursor *);
-extern int (*db_driver_list_indexes) (dbString *, dbIndex **, int *);
-extern int (*db_driver_list_tables) (dbString **, int *, int);
-extern int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *);
-extern int (*db_driver_open_insert_cursor) (dbCursor *);
-extern int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int);
-extern int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int);
-extern int (*db_driver_open_database) (dbHandle *);
-extern int (*db_driver_grant_on_table) (dbString *, int, int);
-extern int (*db_driver_get_num_rows) (dbCursor *);
-extern int (*db_driver_begin_transaction) (void);
-extern int (*db_driver_commit_transaction) (void);
-extern int (*db_driver_update) (dbCursor *);
-#endif
-#endif
