[GRASS-SVN] r66827 - grass-addons/grass7/raster/r.agent/libagent
svn_grass at osgeo.org
Sat Nov 14 10:20:20 PST 2015
Author: mic
Date: 2015-11-14 10:20:20 -0800 (Sat, 14 Nov 2015)
New Revision: 66827
grass-addons/grass7/raster/r.agent/libagent/ant.py
grass-addons/grass7/raster/r.agent/libagent/anthill.py
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/libagent/world.py
improve documentation comments
Modified: grass-addons/grass7/raster/r.agent/libagent/ant.py
--- grass-addons/grass7/raster/r.agent/libagent/ant.py 2015-11-13 15:22:36 UTC (rev 66826)
+++ grass-addons/grass7/raster/r.agent/libagent/ant.py 2015-11-14 18:20:20 UTC (rev 66827)
@@ -15,8 +15,20 @@
#from grass.script import core as grass
class Ant(agent.Agent):
- """Implementation of an Ant Agent for an Anthill, an ACO kind of World."""
+ Implementation of an Ant like Agent for an Anthill, a kind of World
+ that works after ACO rules (see Anthill).
+ Ants are wandering around by chance until they find some goal cell,
+ then they will mark their way back home with pheromone. Following ants
+ choose the marked cells on the playground more likely then unmarked
+ spots.
+ There are several optimizations / idealizations to choose from,
+ as ACO comes from graph theory and raster layers map quite large
+ graphs (e.g. loops are a major source of sorrow).
def __init__(self, timetolive, world, position):
Create an Agent for an Anthill World
Modified: grass-addons/grass7/raster/r.agent/libagent/anthill.py
--- grass-addons/grass7/raster/r.agent/libagent/anthill.py 2015-11-13 15:22:36 UTC (rev 66826)
+++ grass-addons/grass7/raster/r.agent/libagent/anthill.py 2015-11-14 18:20:20 UTC (rev 66827)
@@ -2,7 +2,7 @@
MODULE: r.agent.*
AUTHOR(S): michael lustenberger inofix.ch
PURPOSE: library file for the r.agent.* suite
-COPYRIGHT: (C) 2011 by Michael Lustenberger and the GRASS Development Team
+COPYRIGHT: (C) 2015 by Michael Lustenberger and the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -19,8 +19,15 @@
class Anthill(world.World):
- World class for using the Ant Colony Optimization Algorithm for
- modelling Agent Based worlds.
+ This kind of world makes use of the Ant Colony Optimization (ACO)
+ algorithm for coordinating its agent's actions (for ACO, see
+ https://en.wikipedia.org/wiki/Ant_colony_optimization_algorithms).
+ The agents are implemented as ants, wandering around by chance
+ if they find a goal cell they will mark their way back home
+ with pheromone. The following ants then choose the marked cells
+ on the playground more likely then unmarked spots. The pheromone
+ evaporates over time.
# constant names for the layers
SITE = "sitemap"
@@ -29,8 +36,8 @@
def __init__(self, pg=None):
- Create a world based on the natural laws of the Ant Colony Optimization
- algorithm (plus adaptions honouring the complexity of the raster case).
+ Create a world based on the natural laws of the ACO algorithm
+ (plus adaptions honouring the complexity of the raster case).
# get all attributes from the basic world
super(Anthill, self).__init__(pg, ant.Ant)
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2015-11-13 15:22:36 UTC (rev 66826)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2015-11-14 18:20:20 UTC (rev 66827)
@@ -2,7 +2,7 @@
MODULE: r.agent.*
@@ -14,8 +14,14 @@
from grass.script import array as garray
class Grassland(playground.Playground):
- """A GrassLand is a Playground and the interface to GRASS."""
+ A GrassLand is a Playground and the interface to GRASS.
+ Besides the plain raster layers it also connects them to the
+ layer names used in GRASS and it can parse vector layers (for
+ now only point vectors though) from GRASS too.
# internal logging class name
ME = "r.agent::libagent.grassland.Grassland()"
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2015-11-13 15:22:36 UTC (rev 66826)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2015-11-14 18:20:20 UTC (rev 66827)
@@ -2,7 +2,7 @@
MODULE: r.agent.*
@@ -14,8 +14,9 @@
class Playground(object):
- A Playground is a major component of a World, defining
- and organizing space.
+ A Playground is a major component of a World, defining and organizing
+ space, i.e. it mainly consists of a set of raster layers, makes
+ them accessible and puts them in relation to one another.
STRAIGHT = 0
DIAGONAL = sqrt(2)-1
Modified: grass-addons/grass7/raster/r.agent/libagent/world.py
--- grass-addons/grass7/raster/r.agent/libagent/world.py 2015-11-13 15:22:36 UTC (rev 66826)
+++ grass-addons/grass7/raster/r.agent/libagent/world.py 2015-11-14 18:20:20 UTC (rev 66827)
@@ -2,7 +2,7 @@
MODULE: r.agent.*
@@ -16,7 +16,16 @@
from math import sqrt
class World(object):
- """Generic World class as basis for more complex worlds."""
+ Generic World class as basis for more complex worlds.
+ A world is a place where things happen. A world normally
+ consists of some playground, i.e. a setup of various
+ layers. Furthermore it holds a list of agents that will
+ act in that world, e.g. change values on layers. More
+ complex worlds might also hold lists of some artefacts
+ (e.g. attractors) or vector-coordinates to indicate points
+ on the playground...
# walking constants
## agents default ability to move
FREEDOM = 8
