[GRASS-SVN] r66879 - grass/trunk/raster/r.sun
svn_grass at osgeo.org
Fri Nov 20 07:19:46 PST 2015
Author: neteler
Date: 2015-11-20 07:19:45 -0800 (Fri, 20 Nov 2015)
New Revision: 66879
grass/trunk/raster/r.sun/main.c
r.sun: advertise the actually used values/maps as user mesgs
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2015-11-20 14:36:50 UTC (rev 66878)
+++ grass/trunk/raster/r.sun/main.c 2015-11-20 15:19:45 UTC (rev 66879)
@@ -642,18 +642,35 @@
* G_fatal_error("If you want to use a time interval both the start and end times must be defined.\n");
- if (parm.linkein->answer == NULL)
+ if (parm.linkein->answer == NULL){
sscanf(parm.lin->answer, "%lf", &singleLinke);
- if (parm.albedo->answer == NULL)
+ G_message(_("Using Linke constant: %lf"), singleLinke);
+ } else {
+ G_message(_("Using Linke map <%s>"), parm.linkein->answer);
+ if (parm.albedo->answer == NULL){
sscanf(parm.alb->answer, "%lf", &singleAlbedo);
+ G_message(_("Using albedo constant: %lf"), singleAlbedo);
+ } else {
+ G_message(_("Using albedo map <%s>"), parm.albedo->answer);
- if (parm.slopein->answer == NULL)
+ if (parm.slopein->answer == NULL){
sscanf(parm.slope->answer, "%lf", &singleSlope);
- singleSlope *= deg2rad;
+ G_message(_("Using slope constant: %lf"), singleSlope);
+ singleSlope *= deg2rad;
+ } else {
+ G_message(_("Using slope map <%s>"), parm.slopein->answer);
- if (parm.aspin->answer == NULL)
+ if (parm.aspin->answer == NULL){
sscanf(parm.aspect->answer, "%lf", &singleAspect);
- singleAspect *= deg2rad;
+ G_message(_("Using aspect constant: %lf"), singleAspect);
+ singleAspect *= deg2rad;
+ } else {
+ G_message(_("Using aspect map <%s>"), parm.aspin->answer);
if (parm.coefbh->answer == NULL)
cbh = BSKY;
