[GRASS-SVN] r66892 - grass/trunk/scripts/db.in.ogr
svn_grass at osgeo.org
Sun Nov 22 09:43:04 PST 2015
Author: martinl
Date: 2015-11-22 09:43:04 -0800 (Sun, 22 Nov 2015)
New Revision: 66892
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
db.in.ogr: add encoding option (useful for DBF tables)
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2015-11-22 16:42:40 UTC (rev 66891)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2015-11-22 17:43:04 UTC (rev 66892)
@@ -50,6 +50,14 @@
#% guisection: Output
#%end
+#%option
+#% key: encoding
+#% type: string
+#% label: Encoding value for attribute data
+#% descriptions: Overrides encoding interpretation, useful when importing DBF tables
+#% guisection: Output
+#%end
import os
import grass.script as grass
from grass.exceptions import CalledModuleError
@@ -93,9 +101,13 @@
else:
layer = None
+ vopts = {}
+ if options['encoding']:
+ vopts['encoding'] = options['encoding']
try:
grass.run_command('v.in.ogr', flags='o', input=input, output=output,
- layer=layer, quiet=True)
+ layer=layer, quiet=True, **vopts)
except CalledModuleError:
if db_table:
grass.fatal(_("Input table <%s> not found or not readable") % input)
