[GRASS-SVN] r66900 - grass/trunk/scripts/db.in.ogr
svn_grass at osgeo.org
Mon Nov 23 06:05:30 PST 2015
Author: martinl
Date: 2015-11-23 06:05:30 -0800 (Mon, 23 Nov 2015)
New Revision: 66900
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
db.in.ogr: cosmetics when db connection is not defined
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2015-11-23 13:50:54 UTC (rev 66899)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2015-11-23 14:05:30 UTC (rev 66900)
@@ -80,7 +80,9 @@
# check if table exists
try:
- s = grass.read_command('db.tables', flags = 'p', quiet=True)
+ nuldev = file(os.devnull, 'w+')
+ s = grass.read_command('db.tables', flags = 'p', quiet=True, stderr=nuldev)
+ nuldev.close()
except CalledModuleError:
# check connection parameters, set if uninitialized
grass.read_command('db.connect', flags='c')
