[GRASS-SVN] r66907 - in grass/branches/releasebranch_7_0: db/drivers/postgres general/g.proj lib/db/sqlp scripts/db.in.ogr scripts/v.in.e00 vector/v.external vector/v.external.out vector/v.in.ogr vector/v.out.ogr vector/v.out.postgis
svn_grass at osgeo.org
Tue Nov 24 00:08:30 PST 2015
Author: neteler
Date: 2015-11-24 00:08:30 -0800 (Tue, 24 Nov 2015)
New Revision: 66907
grass/branches/releasebranch_7_0/db/drivers/postgres/grass-pg.html
grass/branches/releasebranch_7_0/general/g.proj/g.proj.html
grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
grass/branches/releasebranch_7_0/scripts/db.in.ogr/db.in.ogr.html
grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.html
grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html
grass/branches/releasebranch_7_0/vector/v.external/v.external.html
grass/branches/releasebranch_7_0/vector/v.in.ogr/v.in.ogr.html
grass/branches/releasebranch_7_0/vector/v.out.ogr/v.out.ogr.html
grass/branches/releasebranch_7_0/vector/v.out.postgis/v.out.postgis.html
manual: OGR links updated (trac #2763)
Modified: grass/branches/releasebranch_7_0/db/drivers/postgres/grass-pg.html
--- grass/branches/releasebranch_7_0/db/drivers/postgres/grass-pg.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/db/drivers/postgres/grass-pg.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -105,7 +105,7 @@
<li><a href="http://e00pg.sourceforge.net/">e00pg</a>: E00 to PostGIS filter,
see also <em><a href="v.in.e00.html">v.in.e00</a></em>.
</li>
-<li>GDAL/OGR <a href="http://www.gdal.org/ogr/">ogrinfo and ogr2ogr</a>:
+<li>GDAL/OGR <a href="http://www.gdal.org/">ogrinfo and ogr2ogr</a>:
GIS vector format converter and library, e.g. ArcInfo or SHAPE to PostGIS.<br>
<tt>ogr2ogr -f "PostgreSQL" shapefile ??</tt>
</li>
@@ -128,7 +128,7 @@
<ul>
<li><a href="http://www.postgresql.org/">PostgreSQL web site</a></li>
<li><a href="http://www.pgadmin.org/">pgAdmin graphical user interface</a></li>
-<li><a href="http://www.gdal.org/ogr/drv_pg.html">GDAL/OGR PostgreSQL
+<li><a href="http://www.gdal.org/drv_pg.html">GDAL/OGR PostgreSQL
driver documentation</a></li>
</ul>
Modified: grass/branches/releasebranch_7_0/general/g.proj/g.proj.html
--- grass/branches/releasebranch_7_0/general/g.proj/g.proj.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/general/g.proj/g.proj.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -2,7 +2,7 @@
<p><em>g.proj</em> provides a means of converting a co-ordinate system
description (i.e. projection information) between various formats.
-If compiled without <a href="http://www.gdal.org/ogr/">OGR</a> present, the
+If compiled without <a href="http://www.gdal.org/">OGR</a> present, the
functionality is limited to:
<ul>
<li>Reporting the projection information for the current location,
@@ -205,7 +205,7 @@
<a href="http://proj.maptools.org">PROJ 4</a>: Projection/datum support library<br>
<a href="http://www.gdal.org">GDAL raster library and toolset</a><br>
-<a href="http://www.gdal.org/ogr/">OGR vector library and toolset</a>
+<a href="http://www.gdal.org/">OGR vector library and toolset</a>
<p><b>Further reading</b>
<ul>
Modified: grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html
--- grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/lib/db/sqlp/sql.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -47,7 +47,7 @@
<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
<tr><td><a href="grass-ogr.html">ogr</a></td><td>Data storage in OGR files</td>
-<td><a href="http://gdal.org/ogr">http://gdal.org/ogr/</a></td></tr>
+<td><a href="http://gdal.org">http://gdal.org/</a></td></tr>
</table>
<h2>NOTES</h2>
Modified: grass/branches/releasebranch_7_0/scripts/db.in.ogr/db.in.ogr.html
--- grass/branches/releasebranch_7_0/scripts/db.in.ogr/db.in.ogr.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/scripts/db.in.ogr/db.in.ogr.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
<em>db.in.ogr</em> imports attribute tables in various formats as
-supported by the <a href="http://gdal.org/ogr">OGR library</a>
+supported by the <a href="http://www.gdal.org/">OGR library</a>
on the local system (DBF, CSV, PostgreSQL, SQLite, MySQL, ODBC,
etc.). Optionally a unique <b>key</b> (ID) column can be
added to the table.
@@ -12,7 +12,7 @@
Limited type recognition can be done for Integer, Real, String, Date, Time and DateTime
columns through a descriptive file with same name as the CSV file, but .csvt extension
-(see details <a href="http://www.gdal.org/ogr/drv_csv.html">here</a>).
+(see details <a href="http://www.gdal.org/drv_csv.html">here</a>).
<div class="code"><pre>
# NOTE: create koeppen_gridcode.csvt first for automated type recognition
Modified: grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.html
--- grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -12,7 +12,7 @@
<h2>REFERENCES</h2>
<a href="http://avce00.maptools.org">AVCE00 library</a> (providing 'avcimport' and 'e00conv')<br>
-<a href="http://www.gdal.org/ogr/">OGR vector library</a>
+<a href="http://www.gdal.org/">OGR vector library</a>
<h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/vector/v.external/v.external.html
--- grass/branches/releasebranch_7_0/vector/v.external/v.external.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/vector/v.external/v.external.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -17,7 +17,7 @@
</pre></div>
For details see
-<a href="http://www.gdal.org/ogr/ogr_formats.html">OGR web site</a>.
+<a href="http://www.gdal.org/ogr_formats.html">OGR web site</a>.
<h2>EXAMPLES</h2>
@@ -77,7 +77,7 @@
<h2>REFERENCES</h2>
-<a href="http://www.gdal.org/ogr/ogr__api_8h.html">OGR vector library C API</a> documentation
+<a href="http://www.gdal.org/ogr__api_8h.html">OGR vector library C API</a> documentation
<h2>SEE ALSO</h2>
@@ -91,7 +91,7 @@
</em>
<p>
-<a href="http://www.gdal.org/ogr/">OGR Library</a>
+<a href="http://www.gdal.org/">OGR Library</a>
<br>
<a href="http://postgis.org/">PostGIS</a>
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html
--- grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -2,7 +2,7 @@
<em>v.external.out</em> instructs GRASS to write vector maps in
external data format (e.g. ESRI Shapefile, Mapinfo, and others)
-using <a href="http://gdal.org/ogr">OGR library</a>. PostGIS data can
+using <a href="http://www.gdal.org/">OGR library</a>. PostGIS data can
be also written by
built-in <a href="http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/PostGISInterface">GRASS-PostGIS
data provider</a>.
@@ -24,11 +24,11 @@
<p>
Creation <b>options</b> refer to the output format specified
by <b>format</b> option. See the list of valid creation options
-at <a href="http://www.gdal.org/ogr/ogr_formats.html">OGR formats
+at <a href="http://www.gdal.org/ogr_formats.html">OGR formats
specification page</a>, example
-for <a href="http://www.gdal.org/ogr/drv_shapefile.html">ESRI
+for <a href="http://www.gdal.org/drv_shapefile.html">ESRI
Shapefile</a>
-or <a href="http://www.gdal.org/ogr/drv_pg.html">PostgreSQL/PostGIS</a>
+or <a href="http://www.gdal.org/drv_pg.html">PostgreSQL/PostGIS</a>
format (section "Layer Creation Options"). Options are
comma-separated pairs (<tt>key=value</tt>), the options are
case-insensitive,
@@ -181,7 +181,7 @@
<ul>
<li><a href="http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/OGRInterface">GRASS-OGR data provider</a></li>
- <li><a href="http://www.gdal.org/ogr/ogr__api_8h.html">OGR vector library C API</a> documentation</li>
+ <li><a href="http://www.gdal.org/ogr__api_8h.html">OGR vector library C API</a> documentation</li>
<li><a href="http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/PostGISInterface">GRASS-PostGIS data provider</a></li>
<li><a href="http://www.postgresql.org/docs/9.1/static/libpq.html">libpq - C Library</a></li>
</ul>
Modified: grass/branches/releasebranch_7_0/vector/v.in.ogr/v.in.ogr.html
--- grass/branches/releasebranch_7_0/vector/v.in.ogr/v.in.ogr.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/vector/v.in.ogr/v.in.ogr.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -1,7 +1,7 @@
<em>v.in.ogr</em> imports vector data
-using <a href="http://www.gdal.org/ogr/">OGR</a> library to GRASS
+using <a href="http://www.gdal.org/">OGR</a> library to GRASS
vector map. OGR (Simple Features Library) is part of the
<a href="http://www.gdal.org">GDAL</a> library, so you need to
install GDAL to use <em>v.in.ogr</em>.
@@ -46,11 +46,11 @@
<h3>Supported OGR Vector Formats</h3>
OGR library supports various vector data formats
-including <a href="http://www.gdal.org/ogr/drv_shapefile.html">ESRI
-Shapefile</a>, <a href="http://www.gdal.org/ogr/drv_mitab.html">Mapinfo
+including <a href="http://www.gdal.org/drv_shapefile.html">ESRI
+Shapefile</a>, <a href="http://www.gdal.org/drv_mitab.html">Mapinfo
File</a>, UK .NTF, SDTS, TIGER, IHO S-57 (ENC), DGN, GML, AVCBin, REC,
Memory, OGDI, and PostgreSQL depend on the local installation, for
-details see <a href="http://www.gdal.org/ogr/ogr_formats.html">OGR web
+details see <a href="http://www.gdal.org/ogr_formats.html">OGR web
site</a>.
<p>
@@ -339,8 +339,8 @@
<h2>REFERENCES</h2>
<ul>
- <li><a href="http://www.gdal.org/ogr/">OGR vector library</a></li>
+ <li><a href="http://www.gdal.org/">OGR vector library</a></li>
</ul>
<h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/v.out.ogr.html
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/v.out.ogr.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/v.out.ogr.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -1,7 +1,7 @@
<em>v.out.ogr</em> converts GRASS vector map layer to any of the
-supported <a href="http://www.gdal.org/ogr/">OGR</a> vector formats
+supported <a href="http://www.gdal.org/">OGR</a> vector formats
(like a Esri Shapefile, SpatiaLite or GML).
<p>
@@ -13,20 +13,20 @@
The OGR library supports many various formats including:
<ul>
- <li><a href="http://www.gdal.org/ogr/drv_shapefile.html">ESRI Shapefile</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_pg.html">PostGIS</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_sqlite.html">SpatiaLite</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_csv.html">CSV</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_gml.html">GML</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_kml.html">KML</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_mitab.html">Mapinfo File</a></li>
- <li><a href="http://www.gdal.org/ogr/drv_tiger.html">TIGER</a></li>
+ <li><a href="http://www.gdal.org/drv_shapefile.html">ESRI Shapefile</a></li>
+ <li><a href="http://www.gdal.org/drv_pg.html">PostGIS</a></li>
+ <li><a href="http://www.gdal.org/drv_sqlite.html">SpatiaLite</a></li>
+ <li><a href="http://www.gdal.org/drv_csv.html">CSV</a></li>
+ <li><a href="http://www.gdal.org/drv_gml.html">GML</a></li>
+ <li><a href="http://www.gdal.org/drv_kml.html">KML</a></li>
+ <li><a href="http://www.gdal.org/drv_mitab.html">Mapinfo File</a></li>
+ <li><a href="http://www.gdal.org/drv_tiger.html">TIGER</a></li>
<li>... and many others</li>
</ul>
<p>
For further available other supported formats go
-<a href="http://www.gdal.org/ogr/ogr_formats.html">here</a>.
+<a href="http://www.gdal.org/ogr_formats.html">here</a>.
<h2>NOTES</h2>
@@ -161,8 +161,8 @@
<h2>REFERENCES</h2>
<ul>
-<li><a href="http://www.gdal.org/ogr/">OGR vector library</a></li>
-<li><a href="http://www.gdal.org/ogr/ogr__api_8h.html">OGR vector library C API</a>
+<li><a href="http://www.gdal.org/">OGR vector library</a></li>
+<li><a href="http://www.gdal.org/ogr__api_8h.html">OGR vector library C API</a>
documentation</li>
</ul>
Modified: grass/branches/releasebranch_7_0/vector/v.out.postgis/v.out.postgis.html
--- grass/branches/releasebranch_7_0/vector/v.out.postgis/v.out.postgis.html 2015-11-24 08:07:58 UTC (rev 66906)
+++ grass/branches/releasebranch_7_0/vector/v.out.postgis/v.out.postgis.html 2015-11-24 08:08:30 UTC (rev 66907)
@@ -65,8 +65,8 @@
"geom". Name of the geometry column can be changed
by <b>options=</b><tt>GEOMETRY_NAME=<column></tt>. Note that for
exporting vector features as simple features can be alternatively
-used <a href="http://gdal.org/ogr/drv_pg.html">PostgreSQL driver</a>
-from <a href="http://gdal.org/ogr/">OGR</a> library
+used <a href="http://gdal.org/drv_pg.html">PostgreSQL driver</a>
+from <a href="http://gdal.org/">OGR</a> library
through <em><a href="v.out.ogr.html">v.out.ogr</a></em> module.
<p>
