[GRASS-SVN] r66917 - in grass/trunk: gui/wxpython gui/wxpython/lmgr gui/wxpython/xml lib/init
svn_grass at osgeo.org
Tue Nov 24 13:56:53 PST 2015
Author: martinl
Date: 2015-11-24 13:56:53 -0800 (Tue, 24 Nov 2015)
New Revision: 66917
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/toolboxes.xml
grass/trunk/gui/wxpython/xml/wxgui_items.xml
grass/trunk/lib/init/grass.py
wxGUI: add experimental option to exit GRASS shell from GUI session
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2015-11-24 21:54:25 UTC (rev 66916)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2015-11-24 21:56:53 UTC (rev 66917)
@@ -84,9 +84,10 @@
commands, tree widget page for managing map layers.
def __init__(self, parent, id = wx.ID_ANY, title = None,
- workspace = None,
+ workspace = None, shellPid = None,
size = globalvar.GM_WINDOW_SIZE, style = wx.DEFAULT_FRAME_STYLE, **kwargs):
self.parent = parent
+ self._shellPid = shellPid # process id of shell running on the background
if title:
self.baseTitle = title
else:
@@ -2203,6 +2204,9 @@
def OnCloseWindow(self, event):
"""Cleanup when wxGUI is quitted"""
+ self._closeWindow()
+ def _closeWindow(self):
# save command protocol if actived
if self.goutput.btnCmdProtocol.GetValue():
self.goutput.CmdProtocolSave()
@@ -2250,10 +2254,19 @@
self.OnDisplayCloseAll()
self.notebookLayers.DeleteAllPages()
self._auimgr.UnInit()
self.Destroy()
+ def OnCloseWindowExitGRASS(self, event):
+ """Close wxGUI and exit GRASS shell."""
+ if self._shellPid:
+ Debug.msg(1, "Exiting shell with pid={}".format(self._shellPid))
+ import signal
+ os.kill(self._shellPid, signal.SIGTERM)
+ else:
+ grass.warning(_("Unable to exit GRASS shell: unknown PID"))
def MsgNoLayerSelected(self):
"""Show dialog message 'No layer selected'"""
wx.MessageBox(parent = self,
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2015-11-24 21:54:25 UTC (rev 66916)
+++ grass/trunk/gui/wxpython/wxgui.py 2015-11-24 21:56:53 UTC (rev 66917)
@@ -35,13 +35,15 @@
class GMApp(wx.App):
- def __init__(self, workspace = None):
+ def __init__(self, workspace=None, shellPid=None):
""" Main GUI class.
:param workspace: path to the workspace file
+ :param shellPid: process id of shell running on background
self.workspaceFile = workspace
# call parent class initializer
wx.App.__init__(self, False)
@@ -77,8 +79,8 @@
# create and show main frame
from lmgr.frame import GMFrame
- mainframe = GMFrame(parent = None, id = wx.ID_ANY,
- workspace = self.workspaceFile)
+ mainframe = GMFrame(parent=None, id=wx.ID_ANY,
+ workspace=self.workspaceFile, shellPid=self._shellPid)
mainframe.Show()
self.SetTopWindow(mainframe)
@@ -97,20 +99,26 @@
def process_opt(opts, args):
""" Process command-line arguments"""
- workspaceFile = None
+ workspaceFile = shellPid = None
for o, a in opts:
if o in ("-h", "--help"):
printHelp()
- if o in ("-w", "--workspace"):
+ elif o in ("-w", "--workspace"):
if a != '':
workspaceFile = str(a)
else:
workspaceFile = args.pop(0)
- return (workspaceFile,)
+ elif o in ("-p", "--pid"):
+ if a != '':
+ shellPid = int(a)
+ else:
+ shellPid = int(args.pop(0))
+ return (workspaceFile, shellPid)
def main(argv = None):
if argv is None:
@@ -118,18 +126,17 @@
try:
try:
opts, args = getopt.getopt(argv[1:], "hw:",
- ["help", "workspace"])
+ ["help", "workspace", "pid"])
except getopt.error as msg:
raise Usage(msg)
except Usage as err:
print >> sys.stderr, err.msg
print >> sys.stderr, "for help use --help"
printHelp()
- workspaceFile = process_opt(opts, args)[0]
- app = GMApp(workspaceFile)
+ workspaceFile, shellPid = process_opt(opts, args)
+ app = GMApp(workspaceFile, shellPid)
# suppress wxPython logs
q = wx.LogNull()
set_raise_on_error(True)
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2015-11-24 21:54:25 UTC (rev 66916)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2015-11-24 21:56:53 UTC (rev 66917)
@@ -41,6 +41,7 @@
<separator/>
<wxgui-item name="LaunchScript"/>
<separator/>
+ <wxgui-item name="CloseGUI"/>
<wxgui-item name="Quit"/>
</items>
</toolbox>
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml 2015-11-24 21:54:25 UTC (rev 66916)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml 2015-11-24 21:56:53 UTC (rev 66917)
@@ -62,10 +62,16 @@
<handler>OnRunScript</handler>
<description>Launches script file.</description>
</wxgui-item>
+ <wxgui-item name="CloseGUI">
+ <label>Close GUI</label>
+ <handler>OnCloseWindow</handler>
+ <description>Quit wxGUI session.</description>
+ <shortcut>Ctrl+W</shortcut>
+ </wxgui-item>
<wxgui-item name="Quit">
- <label>Exit GUI</label>
- <handler>OnCloseWindow</handler>
- <description>Quit the GRASS wxGUI session.</description>
+ <label>Quit GRASS GIS</label>
+ <handler>OnCloseWindowExitGRASS</handler>
+ <description>Quit wxGUI session and exit GRASS shell.</description>
<shortcut>Ctrl+Q</shortcut>
<wx-id>ID_EXIT</wx-id>
</wxgui-item>
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-11-24 21:54:25 UTC (rev 66916)
+++ grass/trunk/lib/init/grass.py 2015-11-24 21:56:53 UTC (rev 66917)
@@ -1338,7 +1338,7 @@
return returncode
-def start_gui(grass_gui):
+def start_gui(grass_gui, shell_pid=None):
"""Start specified GUI
:param grass_gui: GUI name (allowed values: 'wxpython')
@@ -1348,9 +1348,14 @@
# Check for gui interface
if grass_gui == "wxpython":
- Popen([os.getenv('GRASS_PYTHON'), wxpath("wxgui.py")])
+ cmd = [os.getenv('GRASS_PYTHON'), wxpath("wxgui.py")]
+ if shell_pid:
+ cmd.append('--pid')
+ cmd.append(str(shell_pid))
+ Popen(cmd)
def clear_screen():
"""Clear terminal"""
if windows:
@@ -1456,10 +1461,11 @@
f.close()
writefile(tcshrc, readfile(cshrc))
- exit_val = call([gpath("etc", "run"), os.getenv('SHELL')])
+ process = Popen([gpath("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
- return exit_val
+ return process
def bash_startup(location, location_name, grass_env_file):
@@ -1512,29 +1518,27 @@
f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
f.close()
- return exit_val
+ return process
def default_startup(location, location_name):
if windows:
os.environ['PS1'] = "GRASS %s> " % (grass_version)
# "$ETC/run" doesn't work at all???
- exit_val = subprocess.call([os.getenv('SHELL')])
+ process = subprocess.Popen([os.getenv('SHELL')])
# TODO: is there a difference between this and clean_temp?
# TODO: why this is missing in the other startups?
cleanup_dir(os.path.join(location, ".tmp")) # remove GUI session files from .tmp
else:
os.environ['PS1'] = "GRASS %s (%s):\\w > " % (grass_version, location_name)
- # TODO: this seems to be inconsistent, the other two are no fataling
- if exit_val != 0:
- fatal(_("Failed to start shell '%s'") % os.getenv('SHELL'))
- return exit_val
+ return process
def done_message():
@@ -1875,7 +1879,6 @@
clean_temp()
sys.exit(0)
else:
- start_gui(grass_gui)
clear_screen()
show_banner()
say_hello()
@@ -1885,14 +1888,23 @@
message(_("Launching <%s> GUI in the background, please wait...")
% grass_gui)
if sh in ['csh', 'tcsh']:
- csh_startup(mapset_settings.full_mapset, mapset_settings.location,
- mapset_settings.mapset, grass_env_file)
+ shell_process = csh_startup(mapset_settings.full_mapset,
+ mapset_settings.location,
+ mapset_settings.mapset,
+ grass_env_file)
elif sh in ['bash', 'msh', 'cygwin']:
- bash_startup(mapset_settings.full_mapset, mapset_settings.location,
- grass_env_file)
+ shell_process = bash_startup(mapset_settings.full_mapset,
+ grass_env_file)
else:
- default_startup(mapset_settings.full_mapset,
- mapset_settings.location)
+ shell_process = default_startup(mapset_settings.full_mapset,
+ mapset_settings.location)
+ start_gui(grass_gui, shell_process.pid)
+ exit_val = shell_process.wait()
+ if exit_val != 0:
+ warning(_("Failed to start shell '%s'") % os.getenv('SHELL'))
# here we are at the end of grass session
clear_screen()
# TODO: can we just register this atexit?
