[GRASS-SVN] r66935 - grass/trunk/gui/wxpython/datacatalog
svn_grass at osgeo.org
Thu Nov 26 11:57:04 PST 2015
Author: martinl
Date: 2015-11-26 11:57:04 -0800 (Thu, 26 Nov 2015)
New Revision: 66935
grass/trunk/gui/wxpython/datacatalog/tree.py
wxGUI datacatalog cosmetics
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2015-11-26 10:44:04 UTC (rev 66934)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2015-11-26 19:57:04 UTC (rev 66935)
@@ -7,10 +7,8 @@
- datacatalog::LocationMapTree
- datacatalog::DataCatalogTree
(C) 2014-2015 by Tereza Fiedlerova, and the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -255,7 +253,7 @@
item = self._model.SearchNodes(name=location, type='location')
if item:
self.Select(item[0], select=True)
- self.ExpandNode(item[0], recursive=True)
+ self.ExpandNode(item[0], recursive=False)
else:
Debug.msg(1, "Location <%s> not found" % location)
@@ -349,7 +347,7 @@
self.selected_layer.label = self.new_name
self.selected_layer.data['name'] = self.new_name
self.RefreshNode(self.selected_layer)
- label = "g.rename " + self.selected_type.label + "=" + string + " -- completed"
+ label = "g.rename " + self.selected_type.label + "=" + string + _(" -- completed")
self.showNotification.emit(message=label)
Debug.msg(1, "LAYER RENAMED TO: " + self.new_name)
gscript.try_remove(gisrc)
@@ -398,7 +396,7 @@
self._model.SortChildren(self.selected_type)
self.RefreshNode(self.selected_type, recursive=True)
Debug.msg(1, "COPIED TO: " + self.new_name)
- label = "g.copy " + self.copy_type.label + "=" + string + " -- completed" # generate this message (command) automatically?
+ label = "g.copy " + self.copy_type.label + "=" + string + _(" -- completed") # generate this message (command) automatically?
else:
@@ -432,7 +430,7 @@
self._model.RemoveNode(self.selected_layer)
Debug.msg(1, "LAYER " + string + " DELETED")
- label = "g.remove -f type=" + self.selected_type.label + " name=" + string + " -- completed" # generate this message (command) automatically?
+ label = "g.remove -f type=" + self.selected_type.label + " name=" + string + _(" -- completed") # generate this message (command) automatically?
@@ -444,15 +442,15 @@
layerName.append(string)
label = _("Displaying {name}...").format(name=string)
- label = "d." + self.selected_type.label + " --q map=" + string + \
- " -- completed. Go to Map layers for further operations."
+ label = "d." + self.selected_type.label[:4] + " --q map=" + string + \
+ _(" -- completed. Go to Map layers for further operations.")
if self.selected_type.label == 'vector':
self._giface.lmgr.AddMaps(layerName, 'vector', True)
elif self.selected_type.label == 'raster':
self._giface.lmgr.AddMaps(layerName, 'raster', True)
else:
self._giface.lmgr.AddMaps(layerName, 'raster_3d', True)
- label = "d.rast --q map=" + string + " -- completed. Go to 'Map layers' for further operations." # generate this message (command) automatically?
+ label = "d.rast --q map=" + string + _(" -- completed. Go to 'Map layers' for further operations.") # generate this message (command) automatically?
Debug.msg(1, "LAYER " + self.selected_layer.label + " DISPLAYED")
else:
