[GRASS-SVN] r66950 - grass/trunk/gui/wxpython/datacatalog
svn_grass at osgeo.org
Fri Nov 27 16:01:07 PST 2015
Author: martinl
Date: 2015-11-27 16:01:07 -0800 (Fri, 27 Nov 2015)
New Revision: 66950
grass/trunk/gui/wxpython/datacatalog/tree.py
wxGUI/datacatalog: enable rename, delete, remove in the current mapset
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2015-11-27 23:53:04 UTC (rev 66949)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2015-11-28 00:01:07 UTC (rev 66950)
@@ -243,7 +243,7 @@
"""Display popup menu."""
self.DefineItems(node)
if self.selected_layer:
- self._popupMenuLayer()
+ self._popupMenuLayer(self.selected_mapset.label == self.gmapset)
elif self.selected_mapset and not self.selected_type:
self._popupMenuMapset()
@@ -360,7 +360,8 @@
if self.selected_location == self.copy_location and self.selected_mapset:
if self.selected_type:
if self.copy_type.label != self.selected_type.label: # copy raster to vector or vice versa
- GError(_("Failed to copy layer: invalid type."), parent=self)
+ GError(_("Failed to copy map: invalid map type "
+ "({} vs. {}).".format(self.copy_type.label, self.selected_type.label)), parent=self)
return
self.new_name = self._getUserEntry(_('New name'), _('Copy map'),
self.copy_layer.label + '_copy')
@@ -504,7 +505,7 @@
dlg.Destroy()
return res
- def _popupMenuLayer(self):
+ def _popupMenuLayer(self, current_mapset):
"""Create popup menu for layers"""
menu = wx.Menu()
@@ -515,14 +516,20 @@
item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
menu.AppendItem(item)
self.Bind(wx.EVT_MENU, self.OnPaste, item)
+ if not current_mapset:
+ item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
self.Bind(wx.EVT_MENU, self.OnDelete, item)
item = wx.MenuItem(menu, wx.NewId(), _("&Rename"))
self.Bind(wx.EVT_MENU, self.OnRename, item)
if not isinstance(self._giface, StandaloneGrassInterface):
item = wx.MenuItem(menu, wx.NewId(), _("&Display layer"))
