[GRASS-SVN] r66957 - in grass/branches/releasebranch_7_0: general/g.gui lib/gis lib/init
svn_grass at osgeo.org
Sat Nov 28 01:37:45 PST 2015
Author: martinl
Date: 2015-11-28 01:37:45 -0800 (Sat, 28 Nov 2015)
New Revision: 66957
grass/branches/releasebranch_7_0/general/g.gui/main.c
grass/branches/releasebranch_7_0/lib/gis/parser.c
grass/branches/releasebranch_7_0/lib/init/grass.py
grass.py: fix initialization script when gis_set.py is not available, explain to the user how to solve this issue
g.gui: ends with fatal error, when GUI is not available
libgis: fix parser when GUI is not available and asked by user
(merge r66912:4, r66916)
Modified: grass/branches/releasebranch_7_0/general/g.gui/main.c
--- grass/branches/releasebranch_7_0/general/g.gui/main.c 2015-11-28 09:18:14 UTC (rev 66956)
+++ grass/branches/releasebranch_7_0/general/g.gui/main.c 2015-11-28 09:37:45 UTC (rev 66957)
@@ -18,6 +18,8 @@
#include <stdlib.h>
#include <string.h>
+#include <unistd.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/spawn.h>
@@ -95,6 +97,8 @@
G_message(_("Launching <%s> GUI in the background, please wait..."), type->answer);
sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
+ if (access(progname, F_OK) == -1)
+ G_fatal_error(_("Your installation doesn't include GUI, exiting."));
if (rc_file->answer) {
G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
"--workspace", rc_file->answer, SF_BACKGROUND, NULL);
Modified: grass/branches/releasebranch_7_0/lib/gis/parser.c
--- grass/branches/releasebranch_7_0/lib/gis/parser.c 2015-11-28 09:18:14 UTC (rev 66956)
+++ grass/branches/releasebranch_7_0/lib/gis/parser.c 2015-11-28 09:37:45 UTC (rev 66957)
@@ -119,7 +119,7 @@
static int check_overwrite(void);
static void define_keywords(void);
static void split_gisprompt(const char *, char *, char *, char *);
-static void module_gui_wx(void);
+static int module_gui_wx(void);
static void append_error(const char *);
static const char *get_renamed_option(const char *);
@@ -433,10 +433,11 @@
if (argc < 2 && (st->has_required || G__has_required_rule())
&& !st->no_interactive && isatty(0)) {
- module_gui_wx();
- return -1;
+ if (module_gui_wx() == 0)
+ return -1;
- else if (argc < 2 && st->has_required && isatty(0)) {
+ if (argc < 2 && st->has_required && isatty(0)) {
G_usage();
return -1;
@@ -573,7 +574,8 @@
/* Run the gui if it was specifically requested */
if (force_gui) {
- module_gui_wx();
+ if (module_gui_wx() != 0)
return -1;
@@ -826,7 +828,7 @@
\brief Invoke GUI dialog
-void module_gui_wx(void)
+int module_gui_wx(void)
char script[GPATH_MAX];
@@ -836,8 +838,14 @@
G_fatal_error(_("Unable to determine program name"));
sprintf(script, "%s/gui/wxpython/gui_core/forms.py",
- getenv("GISBASE"));
- G_spawn(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), script, G_recreate_command(), NULL);
+ getenv("GISBASE"));
+ if (access(script, F_OK) != -1)
+ G_spawn(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"),
+ script, G_recreate_command(), NULL);
+ else
+ return -1;
+ return 0;
void set_flag(int f)
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2015-11-28 09:18:14 UTC (rev 66956)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2015-11-28 09:37:45 UTC (rev 66957)
@@ -672,7 +672,13 @@
pass
# Check for GUI
elif grass_gui in ('gtext', 'wxpython'):
- gui_startup(grass_gui == 'gtext')
+ if not os.path.exists(gfile(wxpython_base, "gis_set.py")):
+ # No GUI available, update gisrc file
+ fatal(_("<{}> requested, but not available. Run GRASS in text "
+ "mode (-text) or install missing package (usually "
+ "'grass-gui').").format(grass_gui))
+ else:
+ gui_startup(grass_gui == 'gtext')
else:
# Shouldn't need this but you never know
fatal(_("Invalid user interface specified - <%s>. "
