[GRASS-SVN] r66967 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Sat Nov 28 08:12:56 PST 2015
Author: martinl
Date: 2015-11-28 08:12:56 -0800 (Sat, 28 Nov 2015)
New Revision: 66967
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.proj/output.c
g.proj: don't ignore epsg as parameter when printing info (-p/g)
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2015-11-28 15:18:56 UTC (rev 66966)
+++ grass/trunk/general/g.proj/local_proto.h 2015-11-28 16:12:56 UTC (rev 66967)
@@ -13,7 +13,7 @@
#endif
/* output.c */
-void print_projinfo(int);
+void print_projinfo(int, const char *);
void print_datuminfo(void);
void print_proj4(int);
#ifdef HAVE_OGR
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2015-11-28 15:18:56 UTC (rev 66966)
+++ grass/trunk/general/g.proj/main.c 2015-11-28 16:12:56 UTC (rev 66967)
@@ -292,7 +292,7 @@
create->key);
if (printinfo->answer || shellinfo->answer)
- print_projinfo(shellinfo->answer);
+ print_projinfo(shellinfo->answer, epsg);
else if (datuminfo->answer)
print_datuminfo();
else if (printproj4->answer)
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2015-11-28 15:18:56 UTC (rev 66966)
+++ grass/trunk/general/g.proj/output.c 2015-11-28 16:12:56 UTC (rev 66967)
@@ -28,7 +28,7 @@
static int check_xy(int shell);
-void print_projinfo(int shell)
+void print_projinfo(int shell, const char *force_epsg)
int i;
char path[GPATH_MAX];
@@ -50,20 +50,28 @@
the contents of this file are not used by pj_*() routines at all */
G_file_name(path, "", "PROJ_EPSG", "PERMANENT");
if (access(path, F_OK) == 0) {
- struct Key_Value *in_epsg_key;
- in_epsg_key = G_read_key_value_file(path);
+ const char *epsg_value, *epsg_key;
+ struct Key_Value *in_epsg_key;
+ if (force_epsg) {
+ epsg_key = "epgs";
+ epsg_value = force_epsg;
+ else {
+ in_epsg_key = G_read_key_value_file(path);
+ epsg_key = in_epsg_key->key[0];
+ epsg_value = in_epsg_key->value[0];
if (!shell) {
fprintf(stdout,
"-PROJ_EPSG-------------------------------------------------\n");
- fprintf(stdout, "%-11s: %s\n", in_epsg_key->key[0],
- in_epsg_key->value[0]);
+ fprintf(stdout, "%-11s: %s\n", epsg_key, epsg_value);
else
- fprintf(stdout, "%s=%s\n", in_epsg_key->key[0],
+ fprintf(stdout, "%s=%s\n", epsg_key, epsg_value);
- if (in_epsg_key != NULL)
- G_free_key_value(in_epsg_key);
+ if (!force_epsg)
+ G_free_key_value(in_epsg_key);
if (!shell)
