[GRASS-SVN] r66398 - in grass/branches/releasebranch_7_0: general/g.proj lib/raster
svn_grass at osgeo.org
Fri Oct 2 10:04:11 PDT 2015
Author: martinl
Date: 2015-10-02 10:04:11 -0700 (Fri, 02 Oct 2015)
New Revision: 66398
grass/branches/releasebranch_7_0/general/g.proj/main.c
grass/branches/releasebranch_7_0/lib/raster/open.c
libgis: include <errno.h> explicitly
g.proj: fix compilation issue when OGR is disabled
(merge r66396-7 from trunk)
Modified: grass/branches/releasebranch_7_0/general/g.proj/main.c
--- grass/branches/releasebranch_7_0/general/g.proj/main.c 2015-10-02 14:44:10 UTC (rev 66397)
+++ grass/branches/releasebranch_7_0/general/g.proj/main.c 2015-10-02 17:04:11 UTC (rev 66398)
@@ -7,7 +7,7 @@
* PURPOSE: Provides a means of reporting the contents of GRASS
* projection information files and creating
* new projection information files.
- * COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2015 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -53,6 +53,7 @@
struct GModule *module;
int formats;
+ const char *epsg = NULL;
G_set_program_name(argv[0]);
G_no_gisinit(); /* We don't call G_gisinit() here because it validates the
@@ -231,6 +232,8 @@
exit(EXIT_SUCCESS);
+ epsg = inepsg->answer;
/* Input */
/* We can only have one input source, hence if..else construct */
@@ -245,9 +248,9 @@
else if (inproj4->answer)
/* Input in PROJ.4 format */
input_proj4(inproj4->answer);
- else if (inepsg->answer)
+ else if (epsg)
/* Input from EPSG code */
- input_epsg(atoi(inepsg->answer));
+ input_epsg(atoi(epsg));
else
/* Input from georeferenced file */
input_georef(ingeo->answer);
@@ -299,7 +302,7 @@
print_wkt(esristyle->answer, dontprettify->answer);
#endif
else if (location->answer)
- create_location(location->answer, inepsg->answer);
+ create_location(location->answer, epsg);
else if (create->answer)
modify_projinfo();
else
@@ -314,12 +317,12 @@
#endif
#ifdef HAVE_OGR
- if (create->answer && inepsg->answer) {
+ if (create->answer && epsg) {
#else
if (create->answer){
#endif
/* preserve epsg code for user records only (not used by grass's pj routines) */
- create_epsg(location->answer, inepsg->answer);
+ create_epsg(location->answer, epsg);
Modified: grass/branches/releasebranch_7_0/lib/raster/open.c
--- grass/branches/releasebranch_7_0/lib/raster/open.c 2015-10-02 14:44:10 UTC (rev 66397)
+++ grass/branches/releasebranch_7_0/lib/raster/open.c 2015-10-02 17:04:11 UTC (rev 66398)
@@ -19,6 +19,7 @@
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
+#include <errno.h>
#include <grass/config.h>
#include <grass/gis.h>
